Serious electrical problem
Old Apr 7, 2017 | 08:07 PM
Ls5speed's Avatar
Hey guys, I recently posted a thread about having battery issues, and i got a new battery. Now my car almost killed me today. I was driving on the e-way and all of a sudden the car just shut off (doing about 75)... everything was dead. No power steering, turned the key and nothing happened. Radio was off, dome light wouldn't even turn on. I was able to pull over and try to start it but nothing happened. I thought i could have a bad alternator and the car was running off of the battery and it just died, but about 2 minutes of fiddling with the key in the ignition it started. I WAS PISSED. So, being only about 3 minutes from work, i went to work. On the way home, i took the car to a mechanic shop, but when i tried to start it...nothing happened. Car acted like battery was dead until about 1 minute or so and then it started fine. RPM and Speedo gauges turn on and off while driving and my dash lights randomly come on and off. I love my car but am frustrated because it's not safe to drive currently. PLEASE HELP
Old Apr 7, 2017 | 09:43 PM
Sounds like your battery connections could be a bit loose. Try loosening the clamps, pushing the terminals down onto the posts firmly, and re tightening the clamps.
Old Apr 7, 2017 | 10:31 PM
Ls5speed's Avatar
Could a loose terminal really cause that big of a problem?
Old Apr 7, 2017 | 10:39 PM
To me it sounds like a alternator problem or maybe the ignition
Old Apr 7, 2017 | 10:55 PM
Sharkey's Avatar
a bad alternator or loose battery connection wont cause that. my vote would be on ignition switch.
Old Apr 7, 2017 | 10:57 PM
Ls5speed's Avatar
I looked it up online and it said that my VIN had the ignition recall done. Should I go to a dealer?
Old Apr 7, 2017 | 11:47 PM
Ive had the starting hesitation and wacky lights happen because of this, but youre right, it wouldnt cause the car to die.
I really just suggested it because OP said it started after he changed the battery. Worth a quick check.
Old Apr 7, 2017 | 11:48 PM
Check the terminals and make sure the smaller gauge wire is connected right. That smaller wire controls the ECM, BCM, and accessories.
Old Apr 8, 2017 | 12:17 AM
Ls5speed's Avatar
ok thanks. I'll check that in the morning.
Old Apr 8, 2017 | 07:43 AM
97n06ss's Avatar
Check connections to the computer. Unplug and replug them, make sure they are clean. Could be a bad computer possibly. I know when my computer went bad my car wouldn't do anything, and when I did get it started it ran for a little bit then everything would shut off without warning.
Old Apr 8, 2017 | 10:19 AM
Ls5speed's Avatar
ok thanks a lot. I will try this right away.
Old Apr 8, 2017 | 01:20 PM
Ls5speed's Avatar
Well this morning I checked battery terminals, plugged and unplugged wires to the computer, and my car wouldn't start. All dash lights lit up, dome light and everything worked, just no crank. I was able to get some jumper cables on it, started right up. Had to run to store, and my rpm gauge and speedometer kept cutting in and out. I guess I'm calling the dealer.
Old Apr 16, 2017 | 07:30 PM
Ls5speed's Avatar
I think this problem could be my run/crank relay. Has anyone else had a problem similar to mine and solved it with this relay? Thanks
Old Apr 16, 2017 | 07:43 PM
Try swapping it for a fan relay or something and see if it fixes it. All relays are the same.
Old Apr 16, 2017 | 08:02 PM
HeavyChevyLNF's Avatar
If it happened after the battery swap the connections, the cables or the battery would be my first guess. A bad ground can cause all kinds of wacky issues. I know of you said you've checked the terminals. How is the condition of the wiring? What does the negative chassis ground connection look like?
Old Apr 17, 2017 | 07:57 PM
Ls5speed's Avatar
I cleaned all the battery connection, and the terminals look pretty good. I made sure they were as tight as i could get them. I also checked all my grounds about a week ago and I ended up having to clean several of them.
Old Apr 17, 2017 | 07:58 PM
Ls5speed's Avatar
ok, I just did this and took the car for a drive. I also tried starting it and it started every time. Thanks for the advice, this may have solved it, I guess I will find out in a few days lol. If it was a bad relay, is it ok that I gave the fan a bad relay?
Old Apr 17, 2017 | 09:46 PM
cluelessk's Avatar
No. Just replace it. They're cheap.
Old Apr 17, 2017 | 10:14 PM
Ls5speed's Avatar
Also, I just tightened my positive post on my fuse box, it was very loose. Being that it was so loose, I decided to take off my fuse box and re tighten everything. Could a loose positive post contribute to this problem?
Old Apr 18, 2017 | 03:45 PM
07blackg5's Avatar
Slobodan Milošević
yes
Old Apr 18, 2017 | 05:14 PM
Jbishop0352's Avatar
Hey I am not sure if this was mentioned already but it will kill the car exactly like you described. The ground cable to the car/chassis can kill power instantly and has done that to me before. The battery cable to the terminal is one but there is also a grounding strip that you can check, if loose that bad boy will make for rainy days.
Of course that is if the relay didn't fix it. I didn't get to read through all the post but maybe this will help.
Old Apr 19, 2017 | 02:14 PM
Ls5speed's Avatar
thanks a ton for your advice. Really appreciate the help man.
Old Apr 20, 2017 | 05:28 AM
63 Nova SS's Avatar
I would also suspect a corroded ground wire.
