Shift Knob?
Old Apr 11, 2014 | 04:11 PM
TheSuit's Avatar
Shift Knob?
My stock shift knob is complete ****. I like it, but it's so worn that it just looks terrible. I would like to get a momo shift knob, specifically either the Gotham or Nero knob. But I'm unsure if it will fit on the stock shifter without having to grind anything.
Could anybody tell me if this would be a good idea, or maybe what size the rod is or something that might help me out? Also, how would it work if I wanted to keep the reverse lockout. I know they have a reverse lockout version of the momo shift knobs but I don't know if it would fit.
06 SS/SC if it matters.
Old Apr 11, 2014 | 04:13 PM
double clutch's Avatar
There is a how to somewhere on here to make reverse lockout work with any shift knob.
Old Apr 11, 2014 | 05:31 PM
BlackielawlessSS's Avatar
Cobalt SS Network - Search Forums
Old Apr 11, 2014 | 05:43 PM
the stock shifter unfortunately is not threaded on, but pressed on. so nothing else really works with it i think. never a bad time to get a short throw shifter
Old Apr 11, 2014 | 11:41 PM
Any knob that uses set screws will work. Otherwise you would have to use a die and thread the rod to the right size for your shift knob
Old Apr 11, 2014 | 11:53 PM
SPDDMN36's Avatar
Bps makes an adapter so you can use their threaded knobs on a stock shifter.
Old Apr 12, 2014 | 11:41 AM
craig825's Avatar
Have fun getting your old one off. They could not have made it more complicated. I almost burned my car to the ground trying to get mine off.
Old Apr 12, 2014 | 11:57 AM
MaxDugas's Avatar
I replaced my stock one by a MOMO Gotham, thats what i'm rocking now, so yes it fits really easy with the screw to adjust it. The thing you'll have more work on is to remove the stock one from there lol.
Old Apr 12, 2014 | 06:36 PM
I got the stock one off in 20 minutes. Pop the top off, remove torx screw, vice grip bottom of shifter and hammer off.
Old Apr 12, 2014 | 08:39 PM
TheSuit's Avatar
Did you buy the reverse lockout version or the normal version? I'm hesitant to buy it because I don't know if the r-version will fit onto the stock r-lockout piece.
Also, how exactly do momo shift knobs attach? Are they set screws, torx screw, or something else?
Old Apr 12, 2014 | 09:09 PM
MaxDugas's Avatar
I have the reverse lock out version, it fits nicely, and now i have a BPS STS, you set it with one set screw, really easy to do!
Old Apr 12, 2014 | 09:26 PM
TheSuit's Avatar
Thanks for the info. I'm gonna order mine tonight and go from there. I was just out cruising around town and my stock knob came off in my hand when I shifted to second. I had to pull over because I was laughing so hard xD
Old Apr 12, 2014 | 11:17 PM
Lmao i had that happen in my jeep. I went to shift into 2nd and the top of the knob just came off and i was stunned until i realized i was still in first gear at redline
Old Apr 18, 2014 | 08:46 AM
TheSuit's Avatar
Hopefully somebody will see this bump and help.
I got a momo Nero knob and it fits great on my stock shifter, but whenever I tighten the set screw, the reverse lockout will be very difficult to lift and it won't spring back out. I'm totally baffled because the set screw doesn't come into contact with the reverse lockout lifter at all.
Old Apr 18, 2014 | 09:24 AM
MaxDugas's Avatar
maye its the angle given buy it when you tight the screw, have you tried the others screw? Normally you have 3 different lenght for them.
Old Apr 18, 2014 | 10:40 AM
TheSuit's Avatar
They only gave me two different lengths and both did the same thing, but I figured out what it is. The screw changes the angle of the knob when it's tightened just barely enough to be too tight up against the front of the lockout piece. So I guess I'll have to file the plastic to give it more room. Hopefully that will work
Old Apr 18, 2014 | 04:53 PM
MaxDugas's Avatar
Should work, worked on mine so I don't see why it souldn't work on yours!
Old Jul 12, 2014 | 06:08 PM
Kregisen's Avatar
Bumping this old thread instead of creating a new one.
I have an 05 SS/SC and have a stock shift knob - that comes off on a daily basis when shifting. I think some part holding it on is broken so every time I put it back it typically stays for a day until it comes off again. I can live with it but I'd rather buy a replacement. Any idea where to get OEM manual shift knobs? Can't find any on ebay/CL.
Old Jul 27, 2014 | 12:25 AM
Kregisen's Avatar
Old Jul 29, 2014 | 08:45 PM
jimbofug007's Avatar
My best advice is junk yard crawl. Ive found quiet a few pieces for cheap. Keep an eye out for guys upgrading to a short throw shifter. I got an ss shift knob, boot and the shifter rod off of a guy on here. I have a cobalt sport. so I had to cut and weld to make the rod work but I ended up with a shorter rod and more of a homemade short throw shifter.
RaginChopsuey
Oct 27, 2015 01:27 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
