Shifter
Shifter
How does the shifter come off on the 2.2L?
I want to cut it down a tiny bit, but I'm not sure on how you take it off exactly, and I really don't want to break anything; so I figured I would ask first.
go to the forum page on here and go to sponsors. look for twm. its a shifter place go to there page and download the instructions on how to take off the shifter to install the short shifter and that will help you
or heres the link
http://www.twmperformance.com/manual...n%20Manual.pdf
or heres the link
yeah... but for you you would just have to get out the shifter not cut all the other b/s that they did... but yeah... its a lotta work... if your gunna do that you mine as well just get the short shifter since your takin out your shifter anyways,,, you know???
Ghetto is cutting down the stock shifter which does nothing to shorten the shift. Not ghetto is getting a proper short shifter which actually moves the pivot point giving a shorter throw.
twist the boot where it connect to the knob shaft thingy, thwist it, u will feel a po, than pull th boot down, and pull the knob up, that will release it, but you will need another knob, b/c ur going to most likely need to cut below the little snapping spot for the stock knob, if u dont than it will stay the same ehight
I know what a damn sts is dude.
I know this won't shorten the throw.
I'm talking about just shortening the shaft because it's too high for my liking.
Christ.
Shortening the shaft will reduce travel across the shift plane. Imagine if you lengthened it... 2 ft longer would add several inches to the movement between gears (if you only moved it from the top of the shaft). Sadly, shortening a few inches doesn't yield much for result. But lemme know how it goes, I kinda wanna chop mine as well.
To get the knob off, twist the base and then pull the knob off.
But just go on ebay and find a 2002-2005 Cavalier short shifter (we have the same tranny as they do) for like $20 plus shipping. It's much better to just get a short shifter because the stalk is straight, where as on the stock shifter the stalk is bent.
Cptnslo
Sep 24, 2015 09:32 AM
The Rookie24
Sep 20, 2015 04:33 PM
