starting issues, do i need a tune for this fuel pump??
Old May 11, 2012 | 01:54 PM
ok so last few days, especially if the car has been parked for a while, i go to start it, hear the starter for a few seconds then the car doesn't turn on. even sometimes if i let the fuel pump run. after a few tries car finally starts. leads me to believe fuel pump or solenoid is going bad.
can anyone relate to this?
and if i do replace the pump which i dont think would be hard can i run this one? its cheap on ottp's website right now. gotta know asap so i can buy it and fix this issue, dont wanna be stranded
Deatsch Werks DW200 Fuel Pump
thanks!
Old May 11, 2012 | 01:56 PM
nwss's Avatar
i have the same problem right now over thing turns over i just have to play with the gas pedal then it starts right up haha
Old May 11, 2012 | 02:06 PM
its wierd! not sure if its the fuel pump because it sounds normal and runs normal (once it starts that is lol)
if it was a solenoid it would have not worked at all
i think my injectors are fine (only 10k old) so yea. not sure
Old May 11, 2012 | 02:10 PM
nwss's Avatar
yeah this happened to me after i put the new clutch in so im guessing it probably started related, i put a new battery in and no help what so ever, checked all fuses and just my evap fuse was blown, so far no idea what it could be
Old May 11, 2012 | 02:14 PM
hah! wierd i just had a new clutch put in as well!
is yours throwing any codes by any chance? im getting a code for camshaft position sensor malfunction/misread.
also getting a few misfires and an exhaust code.. fmlll
Old May 11, 2012 | 02:30 PM
nwss's Avatar
ok yes had all those codes like 16 bs codes haha when i changed my blown emissions fuse and unplugged the batter for a few they havent came back since then and its been a few thousand miles lol
Old May 11, 2012 | 02:33 PM
check the other starting problem thread they are talking about evap purge solenoids... sounds kinda like my issue
Old May 11, 2012 | 02:36 PM
nwss's Avatar
yeah i replaced mine when it had problems after fueling up but i have a feeling it isnt the problem since i have a catch can and no oil would be going into the intake being sucked up by that (first one was pretty nasty from blow by and thats why it didnt work)
Old May 11, 2012 | 02:37 PM
hmm wel i dont have a catch can and i do have a cai.
where is this evap purge solenoid? i'm gonna check it out u never know.
also i'll try unplugging the battery u might be onto something there.
Old May 11, 2012 | 02:38 PM
nwss's Avatar
check all your fuses too, did you install the clutch yourself?
Old May 11, 2012 | 02:40 PM
nwss's Avatar
and sometimes the car fires right up the first time i try its weird lol
Old May 11, 2012 | 02:49 PM
will do
same here! wierding me out!!
Old May 11, 2012 | 09:43 PM
bluebalt07's Avatar
Check the fuel pressure on the rail. Should be like between 50-60. That will rule out the fuel pump.
Old May 14, 2012 | 08:35 AM
ok well yea, turns out it was my camshaft position sensor. didn't think thats what it was before, but the codes made me give it a try.. PITA to install but worth it for 30 bucks, car runs perfect again!
Turbo Johnny
Feb 21, 2019 09:41 AM
bucks121
Sep 12, 2015 07:39 PM
Sabon_SS
Sep 7, 2015 12:39 PM
