Stock boost on 2009 SS/TC
Old Mar 22, 2016 | 07:01 PM
cooljake73's Avatar
Ok this may sound dumb, but I've never had a turbocharged car before so I'm not sure nkw the boost works I did have a 06 supercharged and I know it hit more boost at a certain RPM. But I just bought this car two days ago and took it out tonight first time and was watching the boost gauge and I stepped on it and at about 3-3500 RPMs I was only hitting like 10.9-11 PSI. I didn't give it anymore. Will it hit the factory boost which I believe is supposed to be around 15 at a Higher RPM like the supercharged ones did or what? Sorry for a stupid question. Just a newbie on the turbos. Any help be appreciated thanks.
Old Mar 22, 2016 | 09:27 PM
cooljake73's Avatar
Must note the car wasn't warm either I read somewhere that it won't boost as high not warmed ho? Help!! Greatly appreciated!
Old Mar 23, 2016 | 08:33 AM
blueLNFftw's Avatar
WTF are you beating on a car that is not at operating temp?
Old Mar 23, 2016 | 09:08 AM
cooljake73's Avatar
Wasn't beating on it. I don't think going to 3500 RPMs is beating on it to me.
Old Mar 23, 2016 | 09:15 AM
blueLNFftw's Avatar
If you are throttling in enough to build that much boost that low; you are loading the engine too much. Aka, beating on it.
Old Mar 23, 2016 | 09:18 AM
cooljake73's Avatar
I can see your point. I'm new to turbos. I had just a supercharged before...so warmed up is when they show more boost correct and never run them unless there warmed up
Old Mar 23, 2016 | 09:36 AM
blueLNFftw's Avatar
On these cars you do not want to build high boost in the lower RPMs. You never want to get a lot of load on an engine before it is at operating temp.
Will it heating up change your boost, probably not. Get on it mid 3rd gear and run it to redline; like 3500 to 6500rpm. Report back what your boost numbers are.
Also, elevation changes boost pressures so that needs to be taken into account.
In Florida I made 16psi on my m62. In the West VA mountains it made a mere 12psi. Same tune. Same pulley.
Old Mar 23, 2016 | 10:08 AM
cooljake73's Avatar
Gotcha. Well thanks for the help. I was hoping I didn't have a boost leak...ill try it soon and let ya know.
Wtsf_hc@yahoo.com
Jun 16, 2016 01:42 AM
cobaltSSbrennan
Mar 29, 2016 10:53 PM
layne989
Mar 26, 2016 07:54 PM
Arvai
Mar 21, 2016 09:59 PM
Stumpalump
Mar 19, 2016 02:21 PM
