Sunroof Button Frame
I highly recommend not using glue. If for any reason you ever need to remove the sunroof button or anything in that region, having the trim glued up there will be pretty pointless. Just remove the sunroof rubber trim and pull the headliner down a little in the middle. You will be able to see the metal piece that the button trim clicks on to and you should be able to figure out how to bend the metal tabs back down enough to keep the trim from falling. It's such an easy thing to do it boggles my mind why so many people resort to glue and potentially screwing up a lot more than the little button trim.
