Suspension Upgrade Help! FE1-FE5
Old Aug 6, 2010 | 02:22 PM
killalee4's Avatar
Since nobody seem give me an answer in the suspension section ima try it here. I have a Pontiac G5 07 FE1 trying to upgrading to FE5. Iv read the entire section on this but I want to someone to verify this for me before I buy the parts
Sku# Name Price
TCSS FE5 Struts and Shock with Pedder Spring Pkg TCSS $594.
15782696 Cobalt TC FE5 23mm Swaybar 15782696 $85.33
20784688 (2) Cobalt FE5 Stabalizer End Link 20784688 $59.76
22722387 (2) Cobalt FE5 Swaybar Clamp 1 Hole 22722387 $27.40
25798129 (2) Cobalt FE5 23mm Swaybar Insulator 25798129 $39.98
25930725 Cobalt FE5 Lower Control Arm LH 2008 - 2010 $122.68 25930724 Cobalt FE5 Lower Control Arm RH 2008 - 2010 25930724 $118.36
SubTotal $1,048.49
Plus SS/SC 05 bushings.
Is this right? If not can someone please correct this for me?
Old Aug 6, 2010 | 07:15 PM
Malaclypse's Avatar
That's all of the parts... Buuuut there's one lingering question in my mind. Is the ball jount on the FE5 suspension the same size as the one on FE1?
If the studs coming out of the ball joints are bigger than your factory ones, you'll need new knuckles as well. Then you get to hubs, axles, brakes etc etc.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
dieGone
Oct 1, 2015 06:27 PM
DANRICKARD
Oct 1, 2015 12:08 AM
