Tail lights
Old Jul 6, 2011 | 11:20 AM
nobody2u's Avatar
Tail lights
Can anyone give me any insight on tinting tail lights? Does this stuff work?: (IE look good and still have light shine through?)
VHT Niteshades Spray Tint & Quick Clearcoat Package - Lights & Bulbs
Or should I just suck it up and buy some tail lights, if so- what are some cool smoked ones?
Old Jul 6, 2011 | 11:30 AM
cobaltguy889's Avatar
If you like the stock taillights, just make sure you wet sand after you do coats of the night shade. You will have a better finish.
Old Jul 6, 2011 | 11:34 AM
Capo's Freak's Avatar
It works but IMO its a pain in the **** if you ever need to go through inspection. No inspections? then spray away, but for me its alot easier just to swap out lights then to strip and re-paint every other year (yep DE inspections suck!)
Old Jul 6, 2011 | 09:01 PM
kingmanbc's Avatar
you do not have to sand on your tail lights before using vht, imo you will be able to see the marks, just make sure you clean them very well before painting
Old Jul 6, 2011 | 09:23 PM
^^^Wrong.
Wetsand your taillights before you spray, just use a 2000 grit sand paper. and make sure you clear coat it
Old Jul 7, 2011 | 08:28 AM
themacguy's Avatar
Originally Posted by cobaltguy889
^^^Wrong.
^^ This. Get all the shiney stuff off with 1500-2000 grit. Then wash and rinse to make sure their CLEAN.
-Then 4 light coats of VHT. Let completly dry between coats.
-Then wetsand with 2000. Rinse well and let completly dry.
-Then 4 light coats of Clear. Let completly dry between coats.
I put them in the oven at 180 degress for 1/2 hour after the last coat of Clear dried (Wifey was not home). The process took a whole day.
They came out a dark cherry colour. I'm happy with the results.
Old Jul 8, 2011 | 11:02 AM
nobody2u's Avatar
Would it be worth it to just buy some aftermarket smoked ones?
Old Jul 8, 2011 | 11:42 AM
I have them and actually like them better than my old sprayed ones
Old Jul 8, 2011 | 11:50 AM
1995chevy's Avatar
i bought the smoked taillights from k2motors and sprayed the third brake light and side makers extremly happy with the results and love the leds
Old Jul 8, 2011 | 07:37 PM
^^^Spot on. Perfect.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
