Thoughts?
Old Mar 28, 2011 | 09:33 PM
UWISHU1's Avatar
Thoughts?
was thinking about checking this out this weekend. Was wondering what I should look for when checking it out/test driving it.
Chevrolet : Cobalt - eBay (item 330546218318 end time Mar-31-11 11:07:20 PDT)
Thanks
Old Mar 28, 2011 | 11:07 PM
1angry_cichlid's Avatar
Sweet. I would just check it out and see if you get good vibes from it- hope it works out for you.
Old Mar 28, 2011 | 11:11 PM
CanadianCobalt's Avatar
A 50 shot of nitrous used for purging only? I'm guessing the SC with Stage 2 was for getting through the mountains easier too.
That car has probably had a rough life but they are pretty durable. Take it for a drive if possible, feel for play/binding in steering, smoothness of tranny, that is doesn't grind going into gears, roll pin is good, clunks etc.
Joel
Old Mar 29, 2011 | 08:03 PM
Nighthawk243's Avatar
See if you can find one with G85.
Old Mar 29, 2011 | 08:22 PM
UWISHU1's Avatar
that's the one with LSD and the Recaro's, yes? For the price and mileage I don't think I will find one.
Old Apr 1, 2011 | 04:48 PM
insylem's Avatar
Check to see if its modified or stock
Stock Injectors = Green
Stock pulley = 3.3"
Check the PCM for stock as well.
Check for compliance with the Power Steering Recall
Check for worn out Control Arm Bushings
Other then that, all I can think of is check the tire tread wear for abnormalities, vaccume hoses...
Check to see that the IC Pump is working.
With the vehical running, open the IC Pump cap, and stick in a flat screw driver, if the pump is working it will pull the screwdriver to one side...
Old Apr 1, 2011 | 04:49 PM
insylem's Avatar
... also
While driving it, rev it up past 5500 RPM..
Then check for a stiff clutch. This indicates
a failing TOB from what I understand.
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
