Trunk help
Old May 10, 2008 | 02:46 PM
HunterKiller89's Avatar
Trunk help
So me and StevenFlit just swapped trunks, but we couldnt figure out how to remove the trunk lock. does anyone know how to do this? I couldnt find anything on the forum...
Old May 10, 2008 | 04:16 PM
07ls's Avatar
ok real easy swap at least on my 07 but i can't see it being any different on later years.
all you need to do is pull a metal retaing clip out and the lock will pull right out give me a min and i will get you pic
pull the metal clip off that is around the lock
should end up looking like this
then just pull it out just make sure you put it back in the same way it came out
just make sure to get that arm lined up and in the hole or you will be climbing through you trunk to try and open it the really hard way
hope this helps
Old May 10, 2008 | 04:22 PM
mkulrey13's Avatar
Just go to your dealer and mention you just tried opening your trunk with your key for the first time and it didnt work....
Old May 13, 2008 | 03:54 AM
so uhh....how do you take that metal retaining clip out...i tugged on it pretty hard straight up in the position in the picture...does it pull outward? or does it push down or something? i just dont want to break it
Old May 13, 2008 | 04:06 AM
Dead Zen's Avatar
Your not gonna break it. Just get a screwdriver and push on the end of it and it will slide off. It looks like a U. Push where the u is connected. The little hoop part. Not that hard really.
Old May 13, 2008 | 04:19 AM
EmperorJJ1's Avatar
lol never figured it out myself... my trunk has the wrong lock... for my key that is
Old May 13, 2008 | 08:59 AM
n0xid's Avatar
Don't think I've ever actually used a key for it, only used either the button or remote.
camaromanss1992
Oct 1, 2015 10:51 PM
royce777
Sep 28, 2015 07:11 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
