TVS vs. Hahn
TVS vs. Hahn
So now that I know prices for both, here's the question. Should I spend $2250 on the TVS SC and $1500 on a stage 2 package, or should I dump that money into the Hahn turbo swap?
ummm...
depends for one...
and since when is a stage 2 1500?
do you like instant power or not?
Turbo can make lots of power but TVS is good and can make just as much if you get the right cooling mods.
and later down the road a twin charge would be awesome too.
depends for one...
gm stage 2
probably stage 2 clutch/axle combo? But TVS is great for maintaining the ss/sc's persona. Easy swap and very reliable. If you're goal is +/-350whp than it's a very direct route to go. Turbo will be more power, but also more complication over stock setup because of the complete reconfiguration of the f/i.
My $0.02
My $0.02
well to install a stage 2 is easy... just injectors and a pully.. both can be done in like 20 minutes.
Twin charge seems more likely to **** up but i like the idea.
Depending on how much HP you want in the long run. if you think this will be the end the a SC is fine but if you think you will keep going i say go Turbo.
also if your turbo breaks you can get a ebay turbo way cheaper than a new TVS
My $0.02
My $0.02
Also a concern of mine is which is better for launch?
no, i'm glad for the input, i didn't know. i thought i saw both on someone's mod list, but that doesn't mean anything.
man you need to do some more research your killing me with your ..........
For a tvs you need 60 lb injectors and h/e and a tune you probally wont see past 270whp with that setup. You cant install gm stage 2 and a tvs together. people upgrade from a stage 2 and go with 60lb and a tvs
Ok, here you go. http://www.cardomain.com/ride/2983827 Look at my mods. That's the minimum recommendations for the TVS
Link fixed
Link fixed
The TVS does not "add" it's the power adder. I guess to help you out with a comparison: My 2.6 pulley made 240whp on my local low-reader dyno. Swapping the TVS with a preliminary tune yielded 290whp on 11* timing on the first pull
Not totally true. You can break 300 w/o exhaust work and only a h/e as long as you have a good tune. I'd have been over 300whp (IMO) if I had dyno'd with my 18* timing and a few more tweaks to the tune instead of 11* and that was with stock h/dp, and 2.5" catback
