Underhood lining
Old May 6, 2008 | 10:12 PM
Renesis's Avatar
Underhood lining
Anyone removed it? do you need special tools for the clips?
I gotta remove it to try and fix a small dent..
thanks
Old May 6, 2008 | 10:13 PM
07cobalt4life's Avatar
just rip it off
boostedss26's Avatar
to save the clips yeah you can use a door panel tool but chances are their gunna break
i ripped mine off and did the same in the trunk
Old May 6, 2008 | 10:19 PM
this is the tool
Old May 6, 2008 | 10:38 PM
Renesis's Avatar
oh that's nice.. for the trunk I broke some but was able to save most I guess I'll try the same, i hate these clips
Old May 6, 2008 | 10:43 PM
venum_us_2002's Avatar
what is the benifit of taking off the hood liner?
Old May 6, 2008 | 10:44 PM
TheCaptain's Avatar
I have a screwdriver that looks like a Y, and it works good for popping them out. I pulled my trunk apart three times and reused the clips, and my hood twice, but the hood clips are much weaker. Only got two out of the hood clips.
There is also four little clips underneath the rubber guard on the top of the hoodliner in addition to the five big clips that you can see.
To put a new one on. And Renesis has to fix a dent in his.
xCobalt05x's Avatar
the hood liner traps in heat
Old May 6, 2008 | 10:47 PM
TheCaptain's Avatar
And protects the paint on your hood. (long term)
Old May 6, 2008 | 10:49 PM
xCobalt05x's Avatar
i wouldnt know about that, i have a CF hood
Old May 7, 2008 | 05:09 PM
Renesis's Avatar
thanks to all of you I'll try to find such a tool
Old May 7, 2008 | 05:23 PM
Tman58's Avatar
Use a large kitchen fork, like for barbacueing hotdogs. It needs to be 2 prong and have a fairly wide flat surface towards the back. Gently push it under each plastic securing bolt. Gently pull down and wiggle grabbing the prongs with one hand and the handle with the other. Pop each one out and the hood blanket will come right off.
Old May 7, 2008 | 05:28 PM
SSRedSC's Avatar
I believe its called a tack puller or something to that effect. That should work fine, its what I use, probably can find it at walmart or lowes.
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Cptnslo
Sep 24, 2015 09:32 AM
Cobe
Sep 19, 2015 11:04 AM
