Urgent: Dash Removal
Old Apr 24, 2005 | 10:52 PM
tiny's Avatar
does anyone know how to remove the dashboard on the Cobalts? does it just pull apart or what? im getting my system installed by my friend who works at Best Buy, and I wanna make sure there are no tricks
Anyone? i appreciate it
Old May 16, 2005 | 12:09 PM
greenwidowcustoms's Avatar
i was wondering the same thing. I looked at mine but I dont want to mess up the dash so i think i am going to take to the dealer and have them pull it off for me.
Old May 16, 2005 | 12:46 PM
DarthDalla's Avatar
System Specs
Tiny,
What are your system specs? just new HU or new speakers amps and subs? brands models?
Old May 16, 2005 | 01:18 PM
plyboy-illest's Avatar
i would like to know as wel hwo it comes off...
Old May 16, 2005 | 03:16 PM
tiny's Avatar
Originally Posted by DarthDalla
Tiny,
i got a 12" kicker Solobaric with just an 1.8 cu ft ported box tuned to 38hz, runnin at 700w at 2 ohms
stock HU, and speakers
dashboard is all pull clips, its just a big puzzle
Old May 16, 2005 | 05:53 PM
mken's Avatar
I've already tried prying the trim plate around the hu off with far more force than I would of liked. That sucker is on tight if it's just pull clips! The trim above the glove box pulls right off with hardly any effort, is it the same kind of pull clips on the hu trim plate? If it is, something is screwed up on mine.
Old May 16, 2005 | 08:56 PM
homewrecker's Avatar
So you're running a separate amp off the stock HU? Did you just convert the high level sub wires to line level inputs and then run them to the new amp?
Old Jul 7, 2008 | 09:41 PM
tru2nrtt777's Avatar
to take apart the dash:
1. remove all trim pieces(radiobezel and color matched parts)
2. remove A-pillar covers
3. remove front most part of dash under the windshield where the light sensor is(unhook, cable only stretches to about 8")
4. unbolt all the 9/32 bolts holding it down(should be 6 at the cowl and about 5 or 6 under the trim.
5. remove the air bag cover(held with metal hooks)
6. lift up and remove towards the passenger side
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Turbo Johnny
Feb 21, 2019 09:41 AM
Extreme Dimensions
Sep 24, 2015 05:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
