Use pcm install
Old May 25, 2022 | 08:51 PM
Raphss's Avatar
Use pcm install
Hii, i just install a use pcm from a 2008 and my car is a 2009 and now it wont crank and i have a traction contol light and abs light in the dash. I know i will need a reflash but is the the only reason to the problem? Thanks
Old May 26, 2022 | 12:23 AM
slapbetcommissioner's Avatar
Should be. Needs the vin to match.
Old May 26, 2022 | 06:50 AM
Raphss's Avatar
It is like no pcm was connected to my car. I broke the one that was in my car before and when i connect the other one there is nothing more.
If the vin match is the only thing needed its great.
Old May 30, 2022 | 02:24 PM
soundjunky's Avatar
as i have understood it, before the engine cranks, the BCM & ECM communicate with each other;
If there is a vin issue, you will get nothing.
You need a TechII or similar tool to change the vin in the ECM;
alternately, HP Tuners VCM has the ability to change the vin.
I have heard of ECM's getting locked if the car has an attempted start without the vin correct - hopefully that isn't your case.
Old May 30, 2022 | 02:38 PM
Raphss's Avatar
Thanks for your answers i found the problem friday. My PCM was finally not bad, all of my ground for it was cut on the trans so thats why i was not able to connect my autel maxysis to it. Now it work find.
Raphss
May 25, 2022 08:53 PM
paintballerr78
May 20, 2014 05:12 PM
ss199
Feb 17, 2011 08:13 PM
elocr87
Nov 7, 2009 04:34 PM
NewBaltOnTheBlock
Tuning
Sep 26, 2009 01:10 AM
