Vendor Help! Aeroforce Interceptor Group Buy!
I'm just checking to see if any vendor wants to do a group buy for the Aeroforce Interceptor gauge.
Maybe something like $200.00 Free shipping. That would be nice.
This Interceptor gauge addresses the unique features of the supercharged Saturn Ion
Redline and Chevrolet Cobalt SS. The gauge will display boost, both primary (just past
the air intake filter) and secondary (just past the Intercooler) intake temperatures, knock
retard, engine coolant temp., ignition advance, supercharger inlet pressure,as well as a
host of others listed below. If you own one of these cars and care about its
performance, this information is invaluable, as well as unattainable in any other device
for under a couple thousand dollars. They also have a custom power up screen specific
to the vehicle. Like the standard Interceptor, these gauges are capable of displaying
the following parameters, two at a time, at a rate of approximately 20 times per second.
Parameters:
RPM
MPH
Intake Air Temperature pre intercooler
Intake Air Temperature post Intercooler *
Mass Air Flow Sensor Frequency *
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Manifold Pressure in PSI (Boost pressure)
Supercharger Inlet Pressure *
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Throttle Position Percentage
Engine Load
Instantaneous fuel economy
Horsepower
Analog input #1
Analog input #2
Parameters:
RPM
MPH
Long Term Fuel Trim
O2 Sensor Voltage
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Engine Load
Horsepower
Analog input #1
Analog input #2
Originally Posted by R33P3R007
aeroforce is a member here, just get them to do it. i'd get a second one, but i refue to put that ugly ass gauge pillar in my car.
Hopefully they chime in.
Originally Posted by Allshot
The old ones had problems. The new ones work fine.
360 L337 User
my new one works, but somtimes it turns off. todd told me to send it back but i needed it for a race 2 weekends ago for the shift light, and still have yet to send it back. The new ones get power from the ODBII port, mine does not.
Anyone come out with the dual steering column gauge pods yet?
Originally Posted by CTCOBALTSSS
Well guys it looks like NGASales might be able to do this for us. We'll see what happens. They are trying very hard to get this up and running for us.
slightly off topic but not really...does anybody have the dual guage pillar from CA? how does it look? does anybody else make one that is factory style/color? i want a dual pillar but want it to look factory
also...do these read check engine codes? no lights at the moment but it would be nice
They just take the black Autometer pillars and paint them. They look pretty good.
Way better than black.
As far as reading codes, I don't know. I found this though.
Parameters:
RPM
MPH
Long Term Fuel Trim
O2 Sensor Voltage
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Engine Load
Horsepower
Analog input #1
Analog input #2
