Very basic exhaust question needing asap answer..
Old Oct 20, 2010 | 02:08 PM
averagewhiteboy's Avatar
Hey guys,
Real quick question. What is the material the stock SS exhaust is made from? Also, what material is the GMPP exhaust made from? Considering a few options, and need to know if my friend can weld it material-wise.
Thanks!
Old Oct 20, 2010 | 02:11 PM
Mr.N00bLaR's Avatar
GMPP:
Cobalt / G5 Cat-Back Exhaust System Performance 17802111 - Crate Engine Depot
Originally Posted by CED
17802111 Cobalt / G5 Cat-Back Exhaust System-Performance.
2005-2007 All Cobalts, & G5s.
2008-2009 non LNF.
12 hp from GMPP Performance exhaust!
The GM Performance Exhaust System is constructed of T-304 stainless steel with mandrel bent tubing and features semi-polished S-type mufflers with two distinctive sounds: the Touring System has a "throaty purr", while the Performance System gives an "aggressive growl". Unique to the GM Performance Exhaust System are adjustable and interchangeable, requires fully-polished choice of two exhaust tip designs.
Note: This GM Performance Parts Cat-Back exhaust system is sold with out exhaust tip.
Select the tip that fits your style
Note:To be used with either ext pkg exhaust tail pipe 17802112 angle cut or 17802113 straight cut outlet. System comes with the following parts.
I think what your looking for is in the description. Never thought to look up the stock exhaust.
Old Oct 20, 2010 | 03:14 PM
So GMPP (current) is stainless. What about stock? Anyone?
Old Oct 20, 2010 | 07:18 PM
No one..??
Old Oct 20, 2010 | 07:19 PM
ecot3c inside's Avatar
I know where your getting at.......... your smart.
Old Oct 20, 2010 | 07:20 PM
recklessactn's Avatar
Stock is mild steel, you can weld to it easy
Old Oct 20, 2010 | 07:24 PM
So normal easy-to-weld steel? Sounds good.
Turbo Johnny
Feb 21, 2019 09:41 AM
Cobe
Sep 19, 2015 11:04 AM
n20saturn
Sep 17, 2015 01:55 AM
Rayray2781@gmail.com
Sep 9, 2015 10:40 AM
Extremespeed
Sep 1, 2015 09:05 PM
