What does this mean??
Old Feb 10, 2010 | 03:20 PM
vancity racer's Avatar
check engine light came on a while ago and when i went to get it looked at they said i need to replace my thermostat. now my check engine like is off :S does this mean that its not faulty anymore?
Old Feb 10, 2010 | 03:22 PM
ls1fbody's Avatar
Haz l33t wheelz.
did you get the code it threw?
you need the code.
Old Feb 10, 2010 | 03:48 PM
DarkCobalt13's Avatar
if they said thermostat, it was prolly a continuous open loop code or coolant temp sensor. Keep an eye on your coolant temp in the DIC and get back with us.
The actual code would help too if you can get it
Old Feb 10, 2010 | 04:49 PM
im still looking for the receits cuz i remember it having a few code #s on it. my coolant temp for the past week as been averaging around 65-72 Celcus
Old Feb 10, 2010 | 05:01 PM
DaBuzzard's Avatar
Thermostat is stuck open, temp should be up around 90*c.
Easy to fix yourself if you don't want to pay the dealers hourly rate
Old Feb 11, 2010 | 03:53 AM
i was told the supercharger had to be removed to get at it.
Old Feb 11, 2010 | 05:41 AM
rallyracer's Avatar
My temp has been staying around the low 170's F ...
Is that normal during the winter when its cold as hell out?
Old Feb 11, 2010 | 11:55 AM
DaBuzzard's Avatar
Not the best how to, lacks a few details, but should give you an idea http://www.justanswer.com/questions/...s-cobalt-where
Remove the blower to get at the thermostat? WTF, do they change spark plugs through the tailpipe too?
That's a bit low but unless you are getting on it, these little alloy motors don't make very much heat and they cool down very quickly compared to "old school" cast iron motors.
Steady cruise on the highway when the temps are in negative numbers, mine will drop to around 75 c (about 170 f).
Get on it to pass someone or merge and the temp pops back up - until I get off it again
Old Feb 11, 2010 | 02:17 PM
insylem's Avatar
Wink
When its really cold mine runs in the 170s also, so I guess it is normal.
Normaly it runs at about 180 though in regualar weather.
Old Feb 11, 2010 | 04:57 PM
rallyracer's Avatar
Ok, same here. Just wanted to make sure.
Old Feb 11, 2010 | 05:15 PM
Yeah, my thermostat is stuck all the way open...... Mine wont get higher that 140 in 20 degree weather. Havent hade time to get at it though......
Old Feb 12, 2010 | 12:13 PM
Nightmare9's Avatar
My brother has a F150 which did the exact same thing, when it was "warm" out the light would go out, the place he bought the truck from replaced the thermostat and that fixed the problem.
