What is happening?
Old Nov 1, 2017 | 11:42 AM
Broyl1007's Avatar
What is happening?
Hello
so I just bought my 2010 Chevy cobalt ss and it had a gauge showing engine power it normally hit about 370 and then my turbo started to cut in and out and when that happened it would show around 90 when I'm flooring it so I turn it off restart it and it's all good but it continues to happen then I got a misfire code and I was running around 250 I replaced the ignition could and spark plugs and it went to 300 but I still don't have the power I use to have does anyone have an idea to why I lost that power ?
Old Nov 1, 2017 | 11:57 AM
Car is done for, burn it to the ground
Old Nov 1, 2017 | 12:37 PM
ProfDNS's Avatar
If you notice something wrong with the engine, why the hell would you floor it?
Old Nov 1, 2017 | 12:39 PM
northvibe's Avatar
Originally Posted by Broyl1007
Hello
Is your car tuned?
Do you have upgraded MAP sensors?
What fuel are you using?
Old Nov 1, 2017 | 10:15 PM
63 Nova SS's Avatar
You need to be more descriptive in what parts you used and I’m guessing you are talking about the rpd display? Read up on your car here in the forums because it sounds as though this is your first performance car. Hp cars can be quirky and it helps if you have some mechanical knowledge when getting one.
Old Nov 2, 2017 | 09:00 PM
efren6057's Avatar
Old Nov 7, 2017 | 05:44 PM
umrdyldo's Avatar
TLDR: Car is screwed, OP floors it to test malfunction status.
But seriously.
Stop beating on it. Do you have any codes? Was the Check engine light on or blinking?
