Would this work?
Old Sep 11, 2006 | 11:28 AM
wdsoccer's Avatar
Would this work?
Would it be possible to get a supercharged engine that came off a wrecked SS/SC and put it in a 2005 Cobalt 2.2l? Would the everything work?
Old Sep 11, 2006 | 11:29 AM
06blackg85ss's Avatar
umm... dude use the search button... there litterally more than a dozen posts on this.. until tuning is available for the 2.2 eco it won't work
Old Sep 11, 2006 | 11:30 AM
05BlackCobaltSS's Avatar
If you had the SS/SC PCM, i don't see why it wouldn't. You'd have to wire the new PCM into the old harness though. But i think that would be easier than completely replacing the old harness....that would be a bitch.
Old Sep 11, 2006 | 11:31 AM
wdsoccer's Avatar
im talking about a full engine swap. isnt the ECM located in the engine?
Old Sep 11, 2006 | 11:33 AM
No but its in the engine compartment/// I guess you could if you had time/effort/skills/money it should be possible
Old Sep 11, 2006 | 11:34 AM
wdsoccer's Avatar
What is the PCM and where is it located? would it come with a supercharged motor that came out of a wrecked cobalt SS/SC?
Old Sep 11, 2006 | 11:36 AM
wdsoccer's Avatar
I know a guy that rebuilt a 1965 mustang from just the frame for his daughter. he loves taking engines apart and all that stuff so he would be able to help me.
Old Sep 11, 2006 | 11:37 AM
these cars are a bit different, and much more challenging/complicated than the older cars// I hope he is good at electrical... but I"m all for it... keep us posted... but its not going to be easy.
Old Sep 11, 2006 | 01:22 PM
Apex's Avatar
too bad our cars arent like hondas where you can throw basically anything in
Old Sep 11, 2006 | 04:37 PM
cashstacker's Avatar
I imagine your car wouldn't like it too much... You'd want to get the engine, tranny, probably a new clutch, pcm, axles, suspension, w rated tires, I'd just get a ss/sc unless all this can be had for cheap and install done cheap.
Old Sep 11, 2006 | 04:44 PM
D4u2s0t's Avatar
same as you wre told on the "other site", it will not work... the computer controlls too many things, if you take it out your car won't work... you can't swap motors at this point
Old Sep 11, 2006 | 04:46 PM
articzap's Avatar
you could swap motors. youd need the whole front clip from the ss/sc with all the wiring. then its a matter of swapping it all over. oh ya dont forget the gague cluster.
Old Sep 11, 2006 | 04:54 PM
D4u2s0t's Avatar
ummm.... no you can't
Old Sep 11, 2006 | 09:36 PM
wdsoccer's Avatar
Anyone else have a say one this subject?
Old Sep 11, 2006 | 09:42 PM
I still don't see why if you have the SS/SC PCM, and wire it into the 2.2's wiring harness (they are the same for ALL cobalts), why it wouldn't work. The comp wouldn't go nuts, b/c it'd be the same set-up as a SS/SC's is done....It should work fine.
Old Sep 11, 2006 | 09:44 PM
articzap's Avatar
y dont u swap the whole wiring system. it would work then. y hack up a wiring harness. you ppl need to learn from honda and the jdm motor swap world
Old Sep 11, 2006 | 10:04 PM
^^That's what i'm saying. Just swap the whole thing.
Old Sep 11, 2006 | 10:08 PM
articzap's Avatar
thats y u just by the whole ss/sc wrecked and take all the parts you need.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
