wtf!?
Old Oct 7, 2013 | 01:11 AM
TheSlowGT's Avatar
wtf!?
so my effin passenger door decided not to work today, meaning it wont open when you pull the handle. anyone have this issue before or heard of it happening? need some help here. and yes it is unlocked when i try to open it
Old Oct 7, 2013 | 01:14 AM
andrewcarr1993's Avatar
Common problem I've heard banging where the latch is helps and when you finally get it open just lubricate the latch.
Old Oct 7, 2013 | 01:18 AM
That seems to be the usual problem ^
Old Oct 7, 2013 | 01:58 AM
jp1600's Avatar
Spray the **** outta it with penetrating lube, then douse it in grease, worked for me
Old Oct 7, 2013 | 07:20 AM
sLAsh's Avatar
Fix it while you can.
My passenger side would do it every now and then but I didnt worry about it because it would eventually start working again and I mainly use this car for driving to work. Then one day when the passenger side wasnt working the drivers side decided to stop working as well.
Trust me you only have to crawl out your window once before you decide it is time to fix the door .
Old Oct 7, 2013 | 07:41 AM
jHarris8822's Avatar
Lol every now and then my drivers door just says **** you I'm not gonna open for a couple months, then it'll randomly start working again haha
Old Oct 7, 2013 | 07:43 AM
theandies's Avatar
Inside latch or outside?
Old Oct 7, 2013 | 07:50 AM
Both. Won't open from either one until it wants too. Luckily it hasn't done that in over 6 months. But yeah it was pissing me off cuz I took the door apart and there was literally nothing wrong with it. Everything was as it should be, yet it didn't open lol
Old Oct 7, 2013 | 08:24 AM
did you lube it all when you inspected everything?
Old Oct 7, 2013 | 09:56 AM
insylem's Avatar
I had that issue a few times,
Fixed it every time by unlocking the door. There is a setting in the car where you can get just your driver door to unlock when you shut the car off vs having both unlock.
Old Oct 7, 2013 | 05:34 PM
If you're asking me, yes I did. I bought all new parts for the door handle assembly and lube and had it all on standby.
Old Oct 8, 2013 | 01:46 PM
coolbalt1's Avatar
Had the same problem. Fix it while u can open the door. Just take out the latch, you'll find the problem once its outside trust me.
Old Oct 8, 2013 | 09:16 PM
TheSlowGT's Avatar
so I tried pushing the door in while pulling on the handle, no luck... I was pushing on it to the point I was afraid I might dent the door itself..
Old Oct 8, 2013 | 11:02 PM
insylem's Avatar
Just take the door off and go doorless,
oh wait, this is cobaltss forum and not wranglerforum my bad
Old Oct 10, 2013 | 05:45 PM
TheSlowGT's Avatar
i got it, pretty much punched the door under the handle. boom opened!
Old Oct 11, 2013 | 03:26 PM
Evilfrog's Avatar
Both my doors stopped working for me at the same time a few months ago. The link in the second post solved it. But man, that sucked. I was stuck in my car at work.
Old Oct 14, 2013 | 08:26 PM
TheSlowGT's Avatar
its such crap, im surprised this hasnt become a recall, especially with how often it seems to happen. i was seriosuly like waaaaaaaaaahhhhh boom! felt like chuck norris lol.
Old Oct 14, 2013 | 08:29 PM
Wired's Avatar
My last SS had this problem but only when a passenger would pull on the door handle (interior) as I was engaging the unlock switch. It's almost as if the handle unhooked itself from the locking mechanism. Having them let go and then cycling the lock a couple times fixed it.
Not exactly what you experienced though...
Old Oct 14, 2013 | 08:31 PM
TheSlowGT's Avatar
it was just shut the door, then it went like this. "you want your gf to get in?? **** you "
Old Nov 2, 2013 | 01:26 PM
Infamous SC/SS's Avatar
All I have to say is THANK YOU! I have spent the last two days trying to figure this problem with my drivers side door out. Finally she opened after about 20 seconds of me trying using the technique above. Thanks guys again!
Cobalt08LS
Jun 19, 2016 07:29 PM
Getaway_Driver
13
Aug 30, 2015 02:44 PM
Blackey2005
Sep 11, 2011 01:06 AM
