ZZP DP installed, aftermath problem, help?
Old Aug 9, 2007 | 05:18 PM
R&C_rallySS's Avatar
So, I finally had the time to install my high flow cat and ZZP downpipe. For the price it looked decent. After I installed it I checked for leaks. No leaks, however I did find a very very small hole on the highflow cat. Would of never noticed it without the car on and feeling around for air. Sure enough a small ammount of hot air was comming from the cat from a small hole. What do I do? Call ZZP? I know a small weld/bead would fix it for sure. However do I let ZZP know about this problem. Will they pay for it? I'm sure it would only be a small ammount to fix. Other then that the downpipe and highflow seemed good.
Old Aug 9, 2007 | 05:31 PM
XM15's Avatar
Thats weird. I would definately let them know about that. I hope everything turns out okay.
BTW, when are you heading to the track with the DR's? I can't wait to see your results.
Old Aug 9, 2007 | 05:32 PM
BriantheLion26's Avatar
Yeah I would just call them. I didn't have any problem with mine but I really didn't look really close at the cat when the car was started. I know I looked to make sure each end didn't leak.
Old Aug 9, 2007 | 07:25 PM
Jimmys2007CobaltSS/C's Avatar
would i need a 2.5 down pipe with my megan catback...i believe its 2.5 piping
Old Aug 9, 2007 | 07:36 PM
I think everyone should take a close look at their ZZP downpipe and highflow cat. I will call them tomarow. It was a real small hole, only way to find it is to be under the car when its running. Take your hands across the cat all around it and down the pipes. (DO NOT TOUCH IT, ITS HOT!) I was taught to do this by a expert race car mech. You will be able to see moisture and feel warm air flow out of any small holes or imperfections in welds.
They have options on their site. Let me find the link and update it for you.
Last edited by R&C_rallySS; Aug 9, 2007 at 07:36 PM. Reason: Automerged Doublepost
Old Aug 9, 2007 | 07:41 PM
I'll have to look the next time I have it on the lift. My cobra h/e will be here shortly and I will use the lift to put it on. It has been on for a while so I would assume if it does leak there would be black stuff on it by now.
Old Aug 9, 2007 | 07:53 PM
Yea, it will be dirty dirty! I hope you do not have the same problem. Its not that big of a deal but it should not of been a problem on a brand new part. Oh well, these things happen. See what ZZP has to say about it first thing tomarow.
Here is that link to the ZZP DP and other options:
http://www.zzperformance.com/cobalt_...=540&catid=155
As for going to the track...should not be long at all. I just need to get this cat fixed and then I can go. Would like to get my gauges set up yet too. The gauges have nothing to do with 1/4th time so no big deal if I don't get that done. Most likly I'll end up at the track in Sept. sometime.
Last edited by R&C_rallySS; Aug 9, 2007 at 07:53 PM. Reason: Automerged Doublepost
Old Aug 9, 2007 | 09:44 PM
well im getting the header dp combo...im pretty sure if my exhaist is a 2.5 wouldnt i have to get the 2.5 downpipe as well so it will fit
plus...not sure what options to get b/c im also s/c my 2.4 ss later so not sure what kinda header to get
Last edited by Jimmys2007CobaltSS/C; Aug 9, 2007 at 09:44 PM. Reason: Automerged Doublepost
Old Aug 19, 2007 | 09:19 PM
Local shop is going to fix it for 15 bucks. Not to bad, just glad I don't have to uninstall it in this hot weather were having lol.
Old Aug 19, 2007 | 09:22 PM
yea im going to shop tom to get my zzp products installed tom..couldnt find any1 in my area to installed it for me
Old Aug 19, 2007 | 09:25 PM
Element2.4's Avatar
Throw some JB weld on that **** and call it a day!
satisfied
Oct 19, 2015 12:35 AM
Cptnslo
Sep 24, 2015 09:32 AM
Jacque8080
Sep 9, 2015 09:21 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
