New Products at GlimmerGlass Detailing!!>>>
These are our most recent additions to the site which I think everyone will enjoy. We are constantly working to provide our customers with quality products and these new additions are examples of just that. Please let us know if you have any questions on any of these, or any of the other fine products that we carry
There was a huge response from our customers to the Victoria Wax Concours Red Wax. As a result, we have decided to add to the Victoria Wax lineup by brining on board their Collectors Wax and Quick Detail Spray.
Victoria Collectors Wax
MSRP: 42.65
Its not so much the shine but the absorbing illusion of depth, clarity and crystalline that Collectors Yellow Wax shouts out. A wax that is easier to work with by bare hand application or perfect with an applicator. The formula for Collectors Yellow Wax has been developed with more solvent and oils to facilitate a more easier application and buffing period. At Victoria Wax we would recommend Collectors Yellow Wax to anyone who is in the business and time is important. It is very hard to go wrong with Collectors Yellow Wax. Just one container will provide many years of enjoyment and gratification. The secret of this wax is in the exotic look of depth and richness visible after multiple thin coats of this great wax has been applied. Between each fresh thin coat always allow enough time for each coat to cure (at least one hour). Buff each coat of wax, and once after each application of wax (2 to 3 minutes wait) and just before the next application. It is best to do this out of the reach of harmful direct sunlight and airborne contaminants. Collectors Yellow Wax is only to be use on new or well maintained finishes. Anything else and it will be a waste of time and wax. Again, apply Collectors Wax to a clean, dry, cool surface using bare hands to work-in and spread thinly. Allow wax to come to a haze and buff to a deep rich finish. Follow with a second and third coat for even a more gorgeous look. For maximum protection keep 2, 3, or more coats of wax on the finish at all times. * Collectors Yellow Wax is an exotic blend of pure # 1 Yellow Carnauba wax blended with other waxes and a small amount of natural oils all heated together with a very safe VOC solvent. lowest VOC solvents. Storage of car care products should be at room temperature, 'not too hot or too cold' and out of direct sunlight. Prolonged exposure of any Victoria Wax's product to extremely sensitive skin and/or pre-existing skin conditions may cause redness or irritation with some people. If that occurs, thoroughly wash the area with a mild soap and discontinue using.
Victoria Wax Quick Detail Spray
MSRP: 18.00
Quick Detail spray is a very important part of keeping a vehicle looking its' best. This product dramatically boosts and intensifies all Victoria Wax's old fashion paste waxes. Quick Detail contains a optical clarifier and a gentle cleaner that removes the blues of storage and awakens to show off a great cars details. Quick Detail is an eye opener to any collector car. The finish jumps to life with a spray and a simple wipe. Highly recommended for fast cleaning of dust, water spots and light soil off surfaces, all without scratching. Quick Detail will not streak, smear, haze, dull or leave a film. Originally, Quick Detail was developed to remove the dead layer of oxidized wax due to UV damage, which brings the finish back to perfection. Now it is used before, during and after about every time the car is moved or just looked at and admired. Special Note: Quick Detail is also used for the lubricant for the Smoothing Claybar. The results are spectacular. Quick Detail is a collector car's best friend. This is Victoria Wax's easiest product to use and works best on waxed surfaces. While Quick Detail is recommended to be used on many surfaces it should not be used to clean the front windshield. Storage of car care products should be at room temperature, 'not too hot or too cold' and out of direct sunlight.
New Accessories!
EZ Detail Brush
MSRP: 21.99
One of the greatest brushes to make it on to the market! The EZ Detail Brush reaches between spokes and even between the brake caliper and the wheels edge. Even though this looks like a thick brush, the flexible bristles flatten to squeeze into openings as small as a ˝ inch. No matter what kind of wheels are on your vehicle, cleaning them is a breeze with the EZ Detail Brush! The soft Nylon Nylex bristles will not scratch any coated, painted, polished, plated, or blank metal surface. Each bristle has a unique, multi-edge structure that provides excellent cleaning power, and the bristles bounce back to their original shape after each use. Theres more! The EZ Detail Brush features an amazing, bendable stem that bends to the contours of your wheels. Its so flexible; you can bend the top half of the brush to one side and then insert it between the spokes to clean the interior rim of the wheel you know, the side that faces underneath the vehicle. A truly unique, useful and versatile product that no enthusiast or professional should be without! Brush measures 18" in total length and 4.5" at its widest point when the bristles are not compressed. The bristles will compress to a width of approximately 1/2".
More ways to dry!!!
Foam Core Waffle Weave Drying Towel
MSRP: 10.99
This 16x24 waffle weave drying towel incorporates a foam core sandwiched between two plush waffle weave microfiber towels. The silk bound edge and tagless construction make for the safest drying experience available. Due to the foam core, this towel will absorb an excessive amount of water. Even we were impressed by just how thirsty this towel is! One towel is capable of drying a entire small vehicle.
Waffle Weave Microfiber Towel
MSRP: 7.99
This ultra soft Waffle Weave Towel drying towel is an outstanding towel for drying your vehicle. The waffle weave construction traps water, better than other standard constructions, because as the towel travels across the surface the ridges of the waffle trap the water and give the microfiber more time to absorb the water. It can can absorb over 7 times its weight in water, and a single towel may dry an entire small sized car.
MSRP: 42.65
MSRP: 18.00
New Accessories!
EZ Detail Brush
MSRP: 21.99
More ways to dry!!!
MSRP: 10.99
MSRP: 7.99
