2.2 L61 Engine: 2.4l/2.2l CAI install with PICS!!!!! (56K at your own risk)
Old 04-16-2008, 10:17 PM
boostaddict's Avatar
is a hydroshield totally necessary? or is it just piece of mind for those of us who are ****?
edit: sorry I didn't read page 2. now I just saw the very last post prior to mine. Thanks
Old 04-17-2008, 03:28 PM
monkeiboy's Avatar
If you drive AT ALL in rain, snow, mist, heavy fog, whatever, your dry filter will get soaking wet. I didn't believe it until I pulled mine out a week after I had drove in heavy rain. It was still wet.
Old 05-26-2008, 10:47 PM
dman090's Avatar
Subscribed..MY CAI/SRI should be here the 29th!
Old 05-28-2008, 09:54 PM
mike25's Avatar
shouldnt your clamp tighteners(tbolt or worm i cant tell) be positioned at opposite sides? thought i heard this some where
Old 05-29-2008, 10:35 AM
monkeiboy's Avatar
You mean faced in opposite directions?
Old 08-17-2008, 07:56 PM
tambrico's Avatar
Originally Posted by monkeiboy
Less weight. and ALOT more air flow up into the engine with the gap opened up.
Is that the tube below the air filter that just seems open, and not being used?
Old 08-18-2008, 10:08 AM
monkeiboy's Avatar
It generally doesn't look like a tube. More like a boxy attachment with a tube on one end and a belled pipe on the other. You CAN'T have it in there and have a CAI. We were talking about leaving it in there for a SRI, and I was telling him that he should take it out anyway to get a little more airflow.
Old 08-18-2008, 10:21 AM
tambrico's Avatar
Yeah, I just installed my SRI. What's the best way to take it out?
Old 08-18-2008, 10:45 AM
monkeiboy's Avatar
Either go through the plastic Wheel well liner and under body liner like in this How to. Or you can "possibly" remove the headlight and headlight mount and get that thing out through there. I don't know if the second one is possible though. It doesn't look like it will fit through. That's why I did the How to the way that I did it.
Old 08-18-2008, 03:42 PM
tambrico's Avatar
Thanks. I just took it out. That thing was a bitch to get out.
Old 10-13-2008, 07:16 AM
  #36
cobaltss86's Avatar
i will be useing this today im ready for my intake
Old 10-13-2008, 09:41 AM
  #37
monkeiboy's Avatar
cool deal, what kind?
Old 04-27-2009, 08:30 AM
  #38
DCOBALTSS's Avatar
great
Old 04-29-2009, 07:25 PM
  #39
Cobalt2921's Avatar
Saved this write up for tomorrow! My injen intake from Brandon97Z is coming tomorrow, 4/30 and i'm for sure installing it after work. Great how to!
Old 04-30-2009, 09:42 AM
  #40
monkeiboy's Avatar
edit- Just so your aware, It IS a Torx bit, not a hex head bolt. BUT, I didn't realize that at the time (It was getting dark) and I made it happen with an allen wrench without realizing. So it can be done without picking up a T-30 sized Torx wrench from whereever.
Old 09-14-2009, 02:00 AM
  #41
wilson79's Avatar
Old 03-30-2010, 01:10 AM
  #42
zerosk8ter83's Avatar
Thumbs up
Originally Posted by wilson79
so how much hp do you think you get out of the intake?
Old 03-30-2010, 02:12 AM
  #43
outtamymind's Avatar
won't be more then 5hp realistically
Old 04-12-2010, 01:05 AM
  #44
Talking hmmm
so whats better a short ram or cold air? cuz im debating on how the cold air intake can gimme more power then a short ram if the filter is located in the bottom corner were hardly any air goes through.
Old 04-12-2010, 01:28 AM
  #45
mrgrinch's Avatar
anyone have problems with throwing codes after installing a CAI?? bought 1 for my 2.4L runs good for a bit then starts making the car run shitty....
has a ram air thing which i havent hooked up yet, that make a difference?
everyone remove the lower air box part?
it is an oil filter, do they come oiled or do you have to oil them?
its a Weapon R intake, figured i'd try them out but so far disappointed.....
Old 04-12-2010, 01:37 AM
  #46
conerboner's Avatar
the oil may have messed up the maf...
Old 04-13-2010, 12:51 AM
  #47
mrgrinch's Avatar
doesnt mess up nothing once i reinstall the stock intake, have thought the same.. but if it dont mess up with the stock one then that shouldnt be it.
Old 04-13-2010, 01:00 AM
  #48
depends on what your looking for. a short ram will generally give you better low end response where a CAI will tend to give you more of a mid to high range effect
find out what the code is. the oil may have done something to the maf but if it doesn't do it when you put the stock on then chances are you have a leak after the maf, which will cause a run lean code to pop up
Old 05-27-2010, 01:22 PM
  #49
cgrealy2006's Avatar
Why r there so many threads that have 56k beware and other things like that about 56k?
Old 05-27-2010, 02:06 PM
  #50
apathy311's Avatar
Because the thread has large pictures that would take a modem user a long time to downlaod.
Quick Reply: 2.2 L61 Engine: 2.4l/2.2l CAI install with PICS!!!!! (56K at your own risk)
