Appearance: CCFL 2nd internal Modifications! cut-off + aiming
Old Apr 16, 2008 | 03:04 AM
ijak's Avatar
first how-to-guide
1) take out ur lights....bake it (275F pry off hinges..and pull) ...take off the light cover...
2) there are 3 screws to undo to remove the reflector...and after that...u must remove the wirings+ adapter for the halos
3) so now the process begins....remove the high beam reflectors....there should be 3 screws
4) now take the black piece of thingy holding the projector and the high beams....unscrew the aiming bolts for the projectors as much as possible then pop out the ball joint located on the bottom middle of the black pastic thingy
no picture....forgot...
5) take the projector apart 3 bolts
6) the original cut-off sheild is crappy....and bent...although some people with these projectors have nice cutoffs i obviously dont....so made it straight...er
7) find some kinda of aluminum plate....( i used a large old pencil box...or sunglass box...) measure out a half circle according to the size of the project and cut! (sheet metal scizzors!!!) CUT THE HALF-CIRCLE LARGER THEN TRIM TO SIZE!!!!!!!!!!
8) attach the new self-made cut off shield to the oringal one by whatever means....NO GLUEGUN OR TAPE!!! i used rivets...saw someone else use screws
9) re-assemble the projector together along with the black pastic thingy THAT HAS BEEN CUT to only hold the projectors
by doing this...u have more control of the projectors without moving the high beams at all....
10) GLUE-GUN the high beam reflectors on to the Bigger reflector....NOTE!!!! I GLUED IT RIGHT ON...BUT MY HIGH BEAMS ARENT THAT HIGH SO I ADVISE YOU TO TILT THE HIGH-Beam reflector UP 1/8 INCH or 0.5 CM THEN GLUE
11) assemble everything together and install the lights back on and aim!!
Before with halogens
after with halogens
after with HIDs
the cutoff doesnt really show here.......but i give up...they look fine....bright...and they dont blind anyone DONE DEAL!!!
Old Aug 16, 2008 | 10:02 AM
Tazmanian_Dvl's Avatar
nice write up! I'm actually thinkin of gettin some BMW projectors off ebay and swappin these out since the cutoff is so shitty. I'm plannin on goin HID over the winter and I'm not sure the cutoff from the el cheapo projectors are gonna hack it. You can get two projectors, bulbs and the HID balasts for like 300...
Old Aug 16, 2008 | 10:05 AM
originaladrian's Avatar
i really wanted the CCFL projectors, the first gens actually have the best cutoff, mine is incredibly crisp. but i want CCFLS! lol
Old Aug 16, 2008 | 11:48 AM
zay52790's Avatar
yea im actually planning on swapping in a set of valeo (audi) projectors into mine. The stock cutoff just sucks to much
theres a how to on swappin ccfl halos into the 1st gen projectors
Old Aug 17, 2008 | 11:14 AM
YelloEye's Avatar
Heres a how to just for you!
https://www.cobaltss.net/forums/how-guide-43/how-swap-ccfl-halos-1st-gen-projectors-125327/
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
riceburner
Oct 2, 2015 05:47 PM
nathan112i
Sep 30, 2015 07:12 PM
