All Engines: Fuel Filter Change How-To with pictures
Old 08-28-2010, 10:09 AM
  #276
trashline's Avatar
the best thing about changing this filter??? Is you dont even have to jack the car up. Slide underneath and it can be changed in 10 minutes.
Old 10-01-2010, 04:53 PM
  #277
MyOtherSS's Avatar
Just changed my fuel filter, excellent how-to. The quick disconnect is size 3/8.
Old 10-02-2010, 01:28 AM
  #278
c4w18's Avatar
lol 63k on my car and still haven't changed...guess i should do that LOL
Old 10-05-2010, 10:38 PM
  #279
RHZ
RHZ's Avatar
No fuel filter on LNF??
Old 10-06-2010, 03:03 AM
  #280
outtamymind's Avatar
the lnf fuel filter is part of the fuel pump in the tank. non-serviceable
Old 10-06-2010, 03:18 AM
  #281
Traviper's Avatar
awesome write up. doing this when i get moneys!
Old 10-19-2010, 09:36 AM
  #282
05Blackss.sc's Avatar
64k. bought it at 52....dont believe its ever been changed.....wow fml lol i got so many things to change and replace cuz the guy b4 me did absolutely no work himself. oil changed by the dealership when needed and that was it. *sadface*
Old 10-27-2010, 01:37 AM
  #283
warrenb213's Avatar
did this tonight.
as previously reported, expect about 2-3 cups of gasoline to get on a good amount of the underbody and eventually on the ground(unless you were smart line me and got a oil pan to catch the debris in).
At 72k miles mine did not appear extremely dirty, but that is probably because I've been running premium the last 50k miles or so from Chevron or Shell. The debris that was in there however just appeared to be some fine mineral with large amounts of refined oil(thicker than fuel, still very crudeish looking).
Old 10-27-2010, 07:42 PM
  #284
devon9832's Avatar
I had 98k miles before I changed mine then I got the P0230 code
Old 10-28-2010, 04:19 AM
  #285
Glowbalt's Avatar
so how would I know if I need to change this? any signs?
Old 10-28-2010, 11:26 AM
  #286
rnjmur's Avatar
This is just "maintenance", like changing your oil. If you wait to change it until there is a "problem" then it is too late.
There are many factors as to how often you should change it. I always did mine every 30K - 40K miles. If you have really shitty gas in your area then I would change it more often.
Old 10-28-2010, 01:40 PM
  #287
Glowbalt's Avatar
yea Im having rough starts after filling up with gas and also rough ridles while at a stop light til the point where it wants to stall if I dont hold the gas
Old 10-28-2010, 02:15 PM
  #288
could be a bad evap canister if the rough starts are only after you fill it up. cheaper to replace your fuel filter and try that anyways glowbalt
Old 10-28-2010, 02:19 PM
  #289
Glowbalt's Avatar
well I can do both, I have an extra evap canister somehow. lol.
Old 10-28-2010, 02:20 PM
  #290
lol nice. ya i would do the filter first and see if anything changes
Old 11-06-2010, 12:33 AM
  #291
Glowbalt's Avatar
hmm bought it at almost 45k, at 73k never changed this. maybe it's time? lol
Old 11-11-2010, 04:36 PM
  #292
ilovecars's Avatar
ok this was seriously easy. I used the plastic ones and had no problem and its still in reusable shape. i guess cuz i changed it at 30k it was easier. not as dirtyd up.
but yea gas pours everwhere. freaked me out. but cant stop it.
thanks op for the write up.
Old 11-29-2010, 01:00 PM
  #293
kevinj4891's Avatar
sub'd, doing this on my 32,000 mile oil change
Old 12-23-2010, 11:47 PM
  #294
juice3's Avatar
Doing this soon
Old 03-01-2011, 02:10 PM
  #295
nickadolph's Avatar
Just did this but know I've got a CEL. Is this most likely just because I stalled out the car from pulling the fuse? I was also considering that I may have gotten the hoses on the 2 pronged side of the filter switched, is it possible to mix these up or do they only fit on one way?
Old 03-01-2011, 02:25 PM
  #296
nickadolph's Avatar
Never mind did a little more searching and found my answer.
Old 03-01-2011, 05:42 PM
  #297
juice3's Avatar
It was just a CEL due to the difference in pressure right? Or something like that... I remember I did mine had a CEL for a short time and it went away....
Old 03-01-2011, 06:08 PM
  #298
nickadolph's Avatar
I think it was from when I made it stall out. I disconnected the battery, and all is good now.
Old 03-01-2011, 07:24 PM
  #299
ilovecars's Avatar
good to hear. but yea you cant flip em. they only fit one way.
Old 03-16-2011, 11:07 PM
  #300
CruzinYellow's Avatar
Just finally changed my fuel filter after 69000 miles...it doesn't seem to be dirty from what I can see. I've never had any problems. I fought with the single fuel line for like 30 mins trying to use the 3/8th's plastic fuel line disconnect. Then I tried the smaller 5/16th's of an inch disconnect tool and it popped right off. I used an inexpensive WIX fuel filter part #33980 from O'Reilly's. They usually have good products so I trust them enough to use their fuel filter rather than going to the dealership for one.
Only thing I may do different than most other people is that I use AMSOIL Performance Improver in my fuel tank once in a while (I have always used 93 octane or better fuel). Yes I do sell this product and I am an authorized dealer. Honestly, the first time I used it in my Stage 2 Cobalt I noticed a major difference in gas mileage. Before I put it in my fuel tank I was averaging 26/29mpg (town/hwy). The very next tank and from then on after using this product I have been getting 30/34.5 (town/highway).
Anyways even after I removed the fuel pump relay, turned on engine and let it die, I still had like a 1/2 a quart or so of fuel drain out of the lines and the old filter. No dirt or discolored fuel whatsoever. Got it all over my hands but thankfully I didn't stand right underneath the filter. I just knew there would still be fuel in the lines. At least now, next time I know to use the 5/16th's fuel line disconnect instead of the 3/8th's one that a lot of people had recommended.
Quick Reply: All Engines: Fuel Filter Change How-To with pictures
