Interior: How-to: Aftermarket seats and frames.
Old Nov 4, 2007 | 05:01 PM
uwishuhdmyecotec's Avatar
Installing aftermarket seats can be done by anybody. It is not complecated at all.
Aproximatly 60 minutes
Tools needed:
-Aftermarket seats
-Fabricated seat frame
-socket for the seat frame hardware
-15mm socket and if you lucky a electric impact. Otherwise a ratchet.
-Flat head screw driver
-Some elbow grease
-Felt tape
-Bolt, Tap & Die, and socket for bolt
-Camera so we can all see the outcome.
Step 1
Lean seat forward and find 2 plastic caps. Use flathead to remove caps. Below each cap is 1 15mm bolt. Remove the bolts. Lift the seat up and out.
Picture is of my fabricated seat frame already installed.
Step 2
Now that the seats are out, move on to the fabricated seat frame. The frame is metal and the body is metal. Metal to metal makes bad noises. Use felt tape on the front part of the frame that interlocks to body. To minimize up and down play i drilled, tapped, and installed a screw on one side of each frame where pictured. The screw is to apply a slight upward pressure on the frame. Reinstall the rear 15mm bolts. The seat belt bolted to my fabricated seat frame that i purchased from Procar by Scat. (Hint: Install seat frame seperate from seat. Its just easier)
Step 3
This step depends on how your seat bolts to your seat frame. My frame used 4 13mm bolts where pictured. Install seats. Now that seats are installed check for cleareance between the door panels and center console.
Now enjoy the fruits of your labor.
Old Nov 4, 2007 | 07:44 PM
JonyyB's Avatar
Site Founder
Thanks a ton for the HOW to
It would be awesome if you can add some info on the fabricated seat frame and what seats work for the Cobalt
Old Nov 5, 2007 | 10:27 AM
kwest's Avatar
Does anyone know of some decently priced black and red seats that bolt up to the factory seat brackets??
Old Nov 5, 2007 | 10:57 AM
The factory seat brackets wont work, you have to get new ones.
Old Nov 5, 2007 | 11:05 AM
kwest's Avatar
Where can I get new ones and what exactly do I look for?? Is there a certain type of bracket that fits our cars??
Old Nov 5, 2007 | 11:27 AM
Well scat gave me those seats. and then i asked them for brackets. it took them 6 weeks to design some and now i think they go for $140. Whatever company you buy seats from should know how to get brackets for it. or bring a picture of my bracket and your car to somebody who can fabricate brackets. the brackets slide-in in the front and bolt in the back.
Old Nov 5, 2007 | 11:32 AM
boricua s/c ss.'s Avatar
how much are those seats
Old Nov 5, 2007 | 12:34 PM
I honestly dont kno how much they are. they gave me the seats as a sort of advertising to show them off like i did. i can find out for everybody.
I found them on summit racing website $150 ea. right now. as for the brackets they dont show a listing for them but if anybody needs them just send me a pm and ill get a set for you
Old Nov 5, 2007 | 01:53 PM
hinow41's Avatar
Nice How To
Old Nov 5, 2007 | 08:34 PM
Jn2's Avatar
Jn2
spot weld it if you dont wanna go thru the hassle of getting a frame to work(<-lazy way of doin it)
Old Nov 5, 2007 | 08:46 PM
biniecki's Avatar
I would like to find a way to take advantage of the stock frame so that i could keep the ratchet height adjuster for the girl in my life so she can still drive my car when need be
Old Nov 5, 2007 | 10:08 PM
Yeh i wanted to do that also, but when looking at it, its didnt look possible with the seats i had. So i had to wait another six weeks while they fabed me some brackets. but the seats recline easily and slide front to back.
Old Nov 7, 2007 | 02:12 AM
97civichatch's Avatar
i think the seat brackets on ebay for the cobalts work for the aftermarket racing seats
Old Nov 7, 2007 | 06:38 AM
post up a link to a set, i couldnt find them.
Old Nov 7, 2007 | 06:45 AM
JRelly's Avatar
Great How To The seats look badass
Old Nov 23, 2007 | 11:29 PM
R1-Graphics's Avatar
i did pretty much the same design
check out ebay i got a set of pleather(lol) seats for 200 bucks with harnesses and shipping
Old Jan 12, 2008 | 03:07 AM
langzhihun's Avatar
Do these seats sit lower than the stock ones?
Old Jan 12, 2008 | 12:36 PM
They feel a little higher actually and i can still raise them
Old Apr 7, 2008 | 02:14 AM
gustin76's Avatar
does anyone know how to remove the back seat
thanks
Old Apr 8, 2008 | 02:33 AM
raikou's Avatar
Do you miss the heated seats??
Old Apr 8, 2008 | 06:36 AM
i believe there is a how to for removing the rear seats on here somewhere. And i never had heated seats. the only electrical connector on my seats was the seat belt buckle. and i live in south florida, heated seats is not necessary
Old Apr 8, 2008 | 07:50 AM
Jumpin Fool's Avatar
Talking Thread Jack
thanks
There is an outstanding video linked on the forum somewhere, but I couldn't find it.
There are few things on this car that are easier to do than removing the back seats. The only tool you'll need is a flathead screwdriver.
First slide your front seats all the way forward and get into the back so that you're facing the back of the car.
Put your hands on the front of the bottom section of the seats(the part that your holds your butt) at about 1/3 and 2/3 the distance across.
With a sharp shove, push it towards the rear of the car and up, it should pop out of place.
Then you'll pull the seat release from the trunk to fold down the upper section. There's a leaf clip on either side of the far left and right of the car that hold these sections in.
Once you fold them down you'll see the clips. Use the flathead to push that clip back and that side of the seat should just pull out. You'll be able to slide the section you unclipped off of the inner post once you angle it out.
Once you do it the first time, you'll be like, "That's it!?"
Old Sep 15, 2009 | 03:24 AM
06SS ALL DAY's Avatar
idk why im asking but in the middle of the bracket where those two black nozzles come out. are those coming from the a/c blower as if you had the setting on "floor" for the rear passengers?
Old Sep 16, 2009 | 01:52 AM
zillaguy07's Avatar
yepper
Old Jan 20, 2010 | 07:04 PM
alchemist1130's Avatar
anyone know where i can get some aftermarket back seats?
-thanks
