How to: Antenna shave!!
I hate the antenna on the back of cobalt's. I think it makes them look too much
like an R/C car, so I decided I will shave it and put in a shark fin. Ok here we go. Estimated time: 4-6 hrs. Tool needed: 1. T-15 ( to take out the quarter panels) 2. T-20 (for the sun visors and clothing hooks) 3. T-30 (for the "OH CRAP" bar) 4. T-50 (for the top seatbelt bolts) 5. Socket wrench 6. Vise grips 7. Wire cutters 8. Wire stripers 9. Panel puller 10. Sanding block 11. Drill 12. Unibit 13. Orbital sander "optional" Material needed: 1. Sand paper 150 grit (for orbital sander) 600 grit 1000 grit 2000 grit 2. Painters tape 3. Prep all 4. Bondo 5. Dupli Color perfect match paint 6. Peal-N-Stick tie down (can buy a lowes) 7. Zip Ties 8. Buffing compound Part needed: 1. Metra 44-UA42 Amplified Roof Antenna Steps: https://www.cobaltss.net/gallery/files/5/8/7/1/4/1.jpg 1. With the vise grips grab the rubber surround on the old antenna and pull. Might need to wiggle is as your pulling, but it will pop out. https://www.cobaltss.net/gallery/files/5/8/7/1/4/2.jpg 2. After pulling the antenna out either cut the wire or pull with wire out of the car through the hole you just made. I chose to cut it because there is a lot of tie downs and is taped to other wires, I didn't want that hassle. I will pull this wire later. https://www.cobaltss.net/gallery/files/5/8/7/1/4/3.jpg 3. Using the painters tape, tape around the hole. Give yourself a 2'' square to work with. Then use the 150 grit sand paper scuff up the hole to give the Bondo something to grab onto. You might want to put some paper towels in the hole so the Bondo doesn't fall threw. https://www.cobaltss.net/gallery/files/5/8/7/1/4/4.jpg https://www.cobaltss.net/gallery/files/5/8/7/1/4/6.jpg 4. Mix the Bondo with the hardener and put the Bondo over the hole. Use a generous amount to ensure that you cover the entire hole. Once this has been done move to the anterior of the car. https://www.cobaltss.net/gallery/files/5/8/7/1/4/7.jpg https://www.cobaltss.net/gallery/files/5/8/7/1/4/8.jpg 5. Take pull the necessary dash pieces off to pull out the stereo and the upper passenger piece of the dash by the door. This will be the best place to run the antenna wire and its power wire. Once you pull the upper passenger you will see a hole the runs across the dash to the radio. 6. Take off the passenger A pillar using the T-15 bit and run the antenna wire up through the dash. This may be a little tricky but it will go up threw. https://www.cobaltss.net/gallery/files/5/8/7/1/4/14.jpg 7. Take out the radio and disconnect all the connectors. Run the antenna wire across the hole in the dash as in step 5. For the power wire for the new antenna tap into the accessory wire for the radio. Once this is complete hook everything back up to the radio including the new antenna wire. Put all the dash pieces back on. 8. Remove the sun visors, rear view mirror, clothing hooks with the T-20 bit, remove the "OH CRAP" bar with the T-30 bit. There is a plastic tab in the rear of the head liner that will need to come off using you panel puller. Be careful not to break it. Then remove the dome light. There are 3 tabs to remove this, and disconnect the wire. Remove the Top Bolt for the Front Seat Belts using the T-50 bit (you can buy at advanced auto parts). Remove both A, top part of B, and C pillars using the T-15 bit. There is a wire for the dome light that is taped to the head liner just remove the tap. Pull out the head liner. 9. If you in the middle of the back seat and look up you will see a hole in the roof support. This is where you will drill your hole. Using your drill and unibit drill the hole from the inside. Just enough to get the hole started. Once you get the hole started go outside the car and finish drilling. You may want to drill the hole to 13/16''. https://www.cobaltss.net/gallery/files/5/8/7/1/4/12.jpg https://www.cobaltss.net/gallery/files/5/8/7/1/4/10.jpg 10. Take the Metra 44-UA42 Amplified Roof antenna and put on the rubber gasket and take off the bolt and washer. Feed the wire connected to the antenna and feed it down through the hole. Go back into the car and put the washer on first and the bolt. Tighten the bolt just a little bit then go back out of the car to align the antenna. Might need to do this a few times. Than tighten. https://www.cobaltss.net/gallery/files/5/8/7/1/4/11.jpg 11. Connect the antenna wire and power wire to the connectors on the antenna. https://www.cobaltss.net/gallery/files/5/8/7/1/4/12.jpg 12. Using Peal -N- Stick tie downs (us as many as you want), attach them to the roofs along with zip ties and fasten the wire to them. There will be extra wire and is up to you were you want to put that. I put the excess in the dash. https://www.cobaltss.net/gallery/files/5/8/7/1/4/13.jpg 13. After all is cleaned up inside do the reverse of step 8. 14. The reason I did the Bondo first than the interior, is so the Bondo has plenty of time to dry. Put some more painters tape around were you taped to protect the paint when you're sanding. Using the 150 grit sand paper and orbital sander, sand away at the Bondo will you are roughly close to being flat. Then use the 600 grit to sand it smooth. If you feel any dips you may want to add more Bondo and re-sand till its flat. https://www.cobaltss.net/gallery/files/5/8/7/1/4/15.jpg 15. Once everything is smooth use prep all to remove wax or dirt from the car. You paper towels of paper and surround the square you made of tap to protect the car from over spray .Using very thin coats of paint, paint over the spot. Let dry. Then use water and 1000 grit sand paper sand each coat. May need to do this several times. 16. Once you are satisfied with the paint. Peel off the tape and tape a bigger square. About 4-6" and wet sand with 1000 grit sand paper the pain to blend it in with the car. 17. Once smooth use the 2000 grit sand paper and wet sand. Once that is done use buffing compound to smoothen it even more. i still need to do step 16 and 17. ill post more pix when im done. https://www.cobaltss.net/gallery/files/5/8/7/1/4/19.jpg https://www.cobaltss.net/gallery/files/5/8/7/1/4/20.jpg https://www.cobaltss.net/gallery/files/5/8/7/1/4/18.jpg https://www.cobaltss.net/gallery/files/5/8/7/1/4/16.jpg after the rainy weather let up. i resanded every thing and this is the final result!!!!!!!!!!!!!!!!!!!!!!!!!!!!! https://www.cobaltss.net/gallery/fil...7_1_723017.jpg Let me know what you think of the finished product!! |
Approved. Sounds really cool, I would certainly call this a modification for most to let a professional take care of, unless you really know your way around body work.
i paid $20 for my mpX shorty
but this is cool Good job! |
that was what i was thinking first but i liked the clean look better and any antenna i found threw that off. it wasnt to expencive of a project only $80.
did some editing now you can see the pix.
Instead of using just body filler. use fiberglass cloth and resin. One piece of cloth on the outside, one on the inside. Resin the whole thing and make sure they stay together. Then body filler, sand, prime, sand, paint, clear, wetsand, and polish. Eventually vibration is going to work that bondo plug loose and start cracking and lifting around the edges.
looks great, im glad you took the time to do this mod because i never regret since ive done it. i shaved my antenna because i took auto body and the oppurtunity was there, definately looks so much cleaner.
http://i55.tinypic.com/2n5zyh.jpg http://i54.tinypic.com/2qsxcn8.jpg |
Originally Posted by Quick92RS
(Post 5902134)
fiberglass was the first thought but i was worried that the fiber glass would be too thick on the paint and there was a support in the middle of the hole and would make it a pain in the butt so i just did the bondo. i will watch for cracks though. |
Originally Posted by Ccadet02
(Post 5902180)
that is so innovative... i never would thought of this lol.. i hate the huge antenna, a shorty looks nice but this is really clean :twothumbs
(Post 5902924)
The fiberglass would sand down just the same as the filler would. Basically you're trying to make filler have some structural integrity, which it was never meant to do. Not trying to bust your balls, just providing insight for people who look up the thread. And to those who don't know, I run a shop and am I-CAR certified.
Another thing I remembered after seeing the pictures. You should always take it back down to bare metal before putting anything on it.
(Post 5903453)
Nice job. I've been meaning to do this, just have to wait for winter so it cools down a bit...
nice, i got shorty and it looks fine as hell.
One thing, why did you pull the antenna out and cut it? Why didn't you just undo the two bracket bolts in the trunk and pull it down, then you just have the thin rubber surround still in the trunk hole and can pull that from the top by hand... Since you had to custom wire things I guess it doesn't matter but pulling from the top could dent the surface around the hole...
Just a thought. |
that looks so clean!!!
(Post 5898894)
dude you can totally see the square that you sanded and the hole in the second set, third picture.
id deff leave this to the pros |
Originally Posted by tru2nrtt777
(Post 5912348)
Just a thought. |
Originally Posted by cobaltsssc760
(Post 5912379)
paint fades, so you need to blend it with the rest of the color. or you will see where the antenna hole was
this is cool but what if you have on-star has anybody found a way to combine both antennas
Yeah. Put an antenna that stretches across the great window on the inside. Don't know details, but I've seen it before.
Originally Posted by Omnigear
(Post 5916670)
