Electrical: How To: Factory Cruise Control and Remote Radio Control Installation (2007- 2010)
Old 05-02-2010, 10:38 PM
  #101
speed_freak5150's Avatar
Originally Posted by crazydude
for anyone that read the post I had requesting advice more troubles... i solved the problem. The sir coil connector was not plugged in all the way.
Well, I have installed my cruise control. I am going to get the tech 2 flash sometime this week.
If anyone needs the connector wires/pins for the bcm or for the sir coil connector, let me know and I can mail you some. I have a whole bcm harness for spare parts. Something to keep in mind, is you can use the pins from your existing sir coil harness used on your stock info/enter button... so you really should'nt need any of those from me... the bcm harness pins you will still need.
I sent you a pm about those pins. I could really use some.
Old 05-03-2010, 12:36 AM
  #102
PsychoCam's Avatar
just read the thread ignore my pm now lol
good to hear man
btw cost me 66 after tax for 1 hr of labor for tech 2
Old 05-09-2010, 12:08 PM
  #103
crazydude's Avatar
Successfully did this mod with a 09LS using parts from a 09SS.
My 09LS did not have the 61 pin pre-wired.
Old 05-18-2010, 04:26 PM
  #104
N174MT's Avatar
GM stopped Reprograming for Cruise Control
Hay .. just got back from my local Pont dealer .... I Installed the Cruse Control Buttons and wire harnes, wanted them to "turn me on" .. well they told me that it can't be done.
I gave them the instructions as stated earlier in this tread, but the Tech told me the Cruse button is not active in the Tech II.
He then went and called GM and they sent him Service bulitin #PIT4837A.. It is dated 6 May 2010. It states you can no longer do an ADD on Style Cruise Control on 2005-2010 Cobalts and 2007 to 2009 G5's.
Now what dio I do???
Old 05-19-2010, 12:22 AM
  #105
crazydude's Avatar
try another dealership....
Call your local car audio shops that install aftermarket cruise. They should be able to tell you what dealership they send their customers to after they install an aftermarket unit.
i had to argue with my local gm dealership. They didnt understand would not believe me that it would work. Although, they never thru a service bulletin in my face. I did mine on may 8th i think... I am in Canada
Old 05-19-2010, 04:59 PM
  #106
Maven's Avatar
That PI doesnt mean what they are telling you it does.....its just a way for GM and the dealer to say "no" you cant add cruise.....it doesnt mean that it cant physically be done anymore, just that it shouldnt be done and GM will offer no assistance in how to do it. It actually states there are "no provisions" to add cruise......and there arent in many cars, thats why you need to install wires.
Old 05-20-2010, 08:19 AM
  #107
crazydude's Avatar
touche
Old 08-02-2010, 12:42 PM
  #108
rwifan's Avatar
Just completed this how-to on a 2007 LS. Thanks to 'Maven' & 'Kafer79" for the info here.
Had to run wires for radio and cruise as none were there from the factory. One tip I could offer though - when you push the micro-connectors out of the old plug obtained from salvage yard, make sure you don't spread the connector out. I had one I used in the radio plug that was not making connection because it was spread out too far but still snapped into plug. Had fun figuring out that one. Once I discovered the problem I just pushed it back out and squeezed together with needle nose and reinstalled. Radio controls work now.
Cruise was activated at a GMC dealer and cost $89 plus tax for a hour of labor. Maybe took 20 minutes. For all those having problem finding someone to do the programming change, just keep looking. Someone out there will do it. Not many are going to turn down money right now.
Old 09-28-2010, 12:55 PM
  #109
LilHaile's Avatar
I just had my local dealer tell me the same thing and then try to charge me 45 bucks.. They were like we tried but your car isn't wired for it.. My response was well I'd suggest your tech to actually look at it this time and he will see that it us wired... I'm currently waitin for the Regional GM to give me a call cause now I apparently can't get my car back until I pay them 45 for running my vin number.
Old 09-28-2010, 11:30 PM
  #110
crazydude's Avatar
If you go to a stereo shop that installs aftermarket cruise controls...they might be able to help direct you to where they send their clients to get their computers reflashed.
Old 11-04-2010, 01:57 PM
  #111
RedStil's Avatar
Can we do that even if we have a none pioneer factory radio ?(without usb)
Cause what os making the cruze work in the car, is it the computer or the radio?
Old 11-04-2010, 08:58 PM
  #112
crazydude's Avatar
I have the most basic cd player that you can get in a 2009 cobalt. and my cruise works just fine. I did not install the radio controls on the steering wheel.
Try it and see if it works
Old 11-05-2010, 04:34 AM
  #113
Nighthawk243's Avatar
GM caught on about the kits and factory add on method and have made a move to block it. The only thing I can think of is to just keep trying dealers until you find one that doesn't know about the bulletin.
Old 11-05-2010, 12:50 PM
  #114
RedStil's Avatar
but it still works right? Is it true you can no longer do it?
Old 11-19-2010, 08:56 PM
  #115
thefinalgamer's Avatar
Originally Posted by Nighthawk243
I'd like to make a note: make sure before doing this to disable your airbag system. It'd be a bad day if something should go off with the module in your lap.
Edit: I did some looking at that HHR forum thread. Apparently, the pins on that harness may differ for the post 2007 cars. Not sure if this applies to the Slobalt/G5, but it might.
OK, Possible part numbers for the harness for 2007+:
Chevy HHR Network - View Single Post - Adding radio buttons on steering wheel
*edited to remove question... I found the answer to it already*.
so are these the right part numbers for a 2010 model? just wanting to be sure before i order. and does anyone have the part numbers for the cruise control part?
quote from link:
"Switch 25862239 $26.46 “Raised Buttons” match the cruise control buttons
Harness 25816515 $10.81 “Correctly" configured, no pins to move
Cover 25812392 $19.39 “Switch cover”"
Old 11-21-2010, 04:05 AM
  #116
RedStil's Avatar
quote from link:
whats the switch cover? do you try to do a cruise with the base model steering wheel?
Old 11-21-2010, 04:09 AM
  #117
i have a base model steering wheel, and i would like to add cruise. my guess is that the switch cover is the silver cover that goes with the buttons.
Old 11-23-2010, 05:37 PM
  #118
mikehaase1norse's Avatar
hey guys newb here so if my question has already been answered and i missed it im sorry,
but
i just bought an 07 g5. options includes power mirrows windows locks remote start and keyless
BUT
it doesnt have cruise control or steering wheel radios controls..
If i were to buy an entire steering column with wheel and air bag would this be a direct plug and play swap?
i can get the entire thing for 200 bucks or so and seems if that would work that it would be the fasts way of doing it.
thanks guys!
Old 12-29-2010, 08:23 PM
  #119
Jookycola's Avatar
I think I read everything completely, But in case I missed it somewhere. Did any of this make the Bluetooth button on the wheel work????
Old 01-11-2011, 08:35 PM
  #120
rabidracin's Avatar
I just want to let everyone know I just added cruise and audio switches in my 09 XFE and everything works great. Thanks for the great thread.
Old 01-12-2011, 03:36 AM
  #121
goeckeritz123's Avatar
You guys think that tech2 tool would fix some of us that can use our cruise
Old 01-12-2011, 03:37 AM
  #122
Can't *
Old 01-12-2011, 10:30 PM
  #123
rabidracin's Avatar
Yes you definitely need TECH 2 to turn cruise on in BCM.
Old 01-29-2011, 06:55 PM
  #124
royce777's Avatar
PISSED OFFF! broke my clock spring going to install my new steering wheel what do i do?! i have a air bag warning. i need help with the install of the new clock spring ill pay someone to do it
Old 02-13-2011, 03:49 PM
  #125
Jookycola's Avatar
Well I installed the leather wheel with full controls on my 2010 Cobalt base. Nothing on it works but the driver display buttons. No volume up/down, no BT, nada.
It looks awesome and i will most likely do the CC mod to mine later. But I thought i'd let any 2010 base/LS folks know ahead of time, If you just plug and play you won't gain anything out of it you will need to re-wire all the stuff to get (Cruise, radio controls) to work.
Quick Reply: Electrical: How To: Factory Cruise Control and Remote Radio Control Installation (2007- 2010)
