Drivetrain: HOW TO Fix Linkage Roll Pin on Transmission
#108
#109
nothing special. i got some plyers and pulled on the pin, that half came out no prob. the other half wouldnt budge, so i just put the other pin in there and tried to tap it till it pushed it out. theres not much room to get the punch in there, so i put the new pin in as far as it could go and took a wrench and kinda pryed against it and hit the top part with a hammer. that worked best for me.
#112
Hers what you do...when said roll pin breaks. Fix it on the side of the road. Once fixed, start car and drive to the nearest Ford dealer and trade it in on a mustang GT...well at least that's what I did...LOL Problem fixed and I have not looked back.
Seriousley though. When I had my Coby I kept a kit in my trunk with everything I needed to fix that pin. I got so good at it, it would take me less than 20 minutes to fix. With the amount of times that thing broke I just did not want to be anywhere without my kit.
#113
LOL. I have my 07 GT w/ the TR-3650 5-speed manual. It's definitely a different car from the SS/TC, but the SS/TC still handles better and is just as fast in the straight.
#114
#115
Short storey for you: I came up on a 350 Z the other day and we went from a 50 roll. He was turbo'd and I still took him by two car lengths before we shut her down. We pulled off to the side of the road and had a bit of a discussion about our two cars. The only reason I took him is because of torque and gearing. He had a very nice car and we both complimented each other and went our separate ways with no hard feelings. That is what it is to be a real car enthusiast. It's a passion for all things on four wheels. my previous comment was only a joke if you kept reading you would of realized that.
Learn your facts before putting your foot in your mouth.
Yes, I would have to agree with you that the TC does handle better but the mustang was never meant as a track car it was meant to go in a straight line unless you put the ford performance handling pack on the car.. Stock for stock I would say they are close, taking in power to weight. Now I would say that the TC staged would be a formidable car to race and yes would probably take a stock GT hands down but I would still take my stang over a Coby any day. Just my personal preference. Enjoy both your cars.
#119
I used to think the 3650 in my GT was a POS, but after driving the SS/TC and going back, the 3650 is a much much better gearbox. I can hear a "snickt" whenever I shift through the gates and the shifter itself feels very solid.
The worst shifter feel has to be those 6-speed gearboxes with the push-down safety mechanism for reverse (ala the Mazdaspeed3). It feels very flimsy, like I would snap the shifter off at any time. At least the F35 shifter just feels rubbery, and not as flimsy as the MS3 shifter.
#120
tighten up the bolts on the tranny mount and the rubbery feel decreases alot too a more solid feel
like a new sts
like a new sts
#121
I just switched out my stock shifter and replaced it with a B&M sport shifter with 30% less throw and I have to admit that it is bang on compared to the OEM. Nice short shifts with a spring loaded 2nd to 3rd shift. from second all I have to do is push directly up and the shifter will automatically slide right into third. Gone is the miss shift. I found that that was the same with my B&M I had in the Coby as long as the roll pin was new. I used to swap out the roll pin before race night.
The other thing here is we are talking two totally diferent trans. The F35 shifter mechanism is guided by wire linkage and that is where the soft feeling lies as the cables will stretch under extreme tension. The TR 3650 shift linkage is solid steel and that is why the shift feels firm and more precise. It will always be hard to launch a front wheel car vs a rear wheel set up. I also find that front wheel transaxles just don't hold up under stress. I have seen a fare share of snapped axles and cracked transaxle cases on the Coby SS/SC. I am not sure what the new TC driveline is like so I can't comment much on that. (Just my own opinion.)
You should swap out your stock shifter in the stang for a short throw. You will absolutely be amased by the shift and trani performance.
Cheers
Cheers
#122
Found my new roll pin replacement today buying a new mailbox at Lowes.... 3/16" x 36" steel rod... now time to cut to 1 1/4" increments, replace and enjoy. by the way, it was only $2.46
#123
i just fixed mine twice last week ,i got mad the second time so i just put a small bolt, lock washer ,and some thread locker on there. I like to see that fall out or break
#125
sorry don't be mad at the newb.. but here's the story.. coming home from dinner... stoplight.. go... can't shift into 2nd.. drove around to figure out the issue.. lost 4th.. by the time i got to my driveway i had no gears and could go in circles with my shifter. checked the forums (yep the newb did his homework before asking q's) and the cables are connected on both ends, no plastic connections broken, just no gears, and i think it's the roll pin.
actually quite some time ago i started missing 2nd and sometimes 4th... i thought it was driver error. which was weird cause i'm actually a talented driver - not looking for roasting - i'm just an enthusiast who loves to learn and apply techniques. but could that have been warning signs for now being able to spell your name with the shifter?
sound about right?
sound about right?
