2.0 LSJ Engine: HOW To - Flush after cooler and heat exchanger
Old Jun 15, 2008 | 01:56 PM
  #51
Bika's Avatar
Fail Less.
now powered by aquafina
i has air pockets in my h/e.
k thx bai.
Old Jul 11, 2008 | 09:36 PM
  #52
BlkWdoSS's Avatar
in stock trim the intercooler pump will kick on after 10 secs? I cant ever recall hearing mine come on or seeing it come on.
also will it be possible for me to attach a seperate hose from the reservoir so that i dont spray the water everywhere?
and im not understanding how exactly to insure that all of the air pockets will be removed
Old Jul 12, 2008 | 12:01 AM
  #53
Bika's Avatar
Fail Less.
after you get pure water coming out, leave that water in and just add through the filler neck. you just have to let the pump run for a while and keep topping it off until the filler neck stays full. leave the cap off and the air bubbles will relieve themselves
Old Aug 11, 2008 | 09:27 PM
  #54
CobaltSS422's Avatar
k thx bai.
Didnt you know aquafina is a scam and is only "filtered" tap water
Old Aug 12, 2008 | 12:33 AM
  #55
Bika's Avatar
Fail Less.
i did not know that. cant say it surprises me though.
maybe thats why i cant get the air out of the damn lines
Old Aug 14, 2008 | 08:10 PM
  #56
BriantheLion26's Avatar
Just mixed up my own batch and flushed it.
2 gal distilled, 1 bottle of water wetter, and about 1/3 gal of straight coolant (so i can run through the winter)
That clamp is the hardest part to get off. Rest is cake. I just let it run to where my coolant looked like the color of my mix and stopped the pump. Going to let the pump run a while to make sure all the air is out.
I will check the IAT2s this Saturday, track day.
Old Oct 13, 2008 | 11:20 PM
  #57
Texas SS's Avatar
ima have to do that sometime
Old Oct 14, 2008 | 12:23 AM
  #58
HunterKiller89's Avatar
Originally Posted by Raven SS
ima dasani man myself..
careful....dasani isnt pure water. its got some sulfate in it.. like sodium disulfate or something...
ive been running straight water and water wtter since i got blown....in los angeles, our coldest temps are like 35-40....
Old Feb 12, 2009 | 04:16 PM
  #59
jasz71's Avatar
Back from the dead....(Thanks AREA)
Will be doing this in march. What IAT2 temps you guys run?
Thanks,
Jas
Old Feb 13, 2009 | 01:17 AM
  #60
EatonTVS07's Avatar
click for later
Old Feb 13, 2009 | 12:36 PM
  #61
Area47's Avatar
Rent me! per hour
Originally Posted by Cobalttc05
click for later
your ic pump is already setup to run in the on position
Old Feb 13, 2009 | 02:23 PM
  #62
EatonTVS07's Avatar
yea i saw that, i was debating on doing the "flush aftercooler and heatexchanger" maybe when it got a little warmer out, but then again i am a bum
Old Mar 25, 2009 | 12:08 AM
  #63
rico's Avatar
i guess ill try this soon since its getting warm over here. does the stock set up on the pump is 10 secs after key is turned or does it need to be changed with hpt. if so where at?
Old Feb 21, 2011 | 03:00 AM
  #64
05RLS2's Avatar
I am getting ready the flush the system on mine soon, and had a question. Does the screw on top of the passenger side of the stock aftercooler aid much at all when flushing and refilling the system? Or will refilling the system with the pump turn on release any air trapped through the the stock "t" shaped filler neck? I didn't see any mention of this, but jsut wondering if it is really necessary to take the aftercooler bleeder out
Old Mar 1, 2011 | 11:32 PM
  #65
Area47's Avatar
Rent me! per hour
it does aid a bit, it makes a bigger mess than anything else without an option b setup
Old Mar 2, 2011 | 08:01 AM
  #66
I did mine ages ago and I do not have the option B. Worst part is just getting all the air out when you are done. If you do it right you can minimize how much air gets into the system. I did use the stock bleeder to help remove some air, but you end up getting coolant down between the h/e, ac, and radiator, and you will smell coolant for days. Let the cap off and let the pump run for a while and it will bleed out eventually, just keep topping it off.
Old Mar 24, 2011 | 09:29 AM
  #67
Tropicaljoe's Avatar
Would I do this same process if I was to use dexcool?
Old Mar 24, 2011 | 01:02 PM
  #68
yes
Old Jul 26, 2011 | 09:27 AM
  #69
CobaltVenomSS's Avatar
i did this over the weekend and it wouldnt suck the water out of the gallon jug...i had to get a funnel and pour it in
Old Aug 8, 2011 | 04:23 PM
  #70
Joemaster70's Avatar
same here. car wouldn't suck it out till i turned car on. didnt mean to bring this thread back from the dead. How long does it take for the air to filter out. Does the neck filler have to have water/anti freeze in it if the car is off?
DarrenGC
Dec 24, 2021 01:55 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
