How to install the "AEM intake" for your Cobalt SS/SC
By: Denny Medeiros-Cobaltss.net You read the review, now let’s get right to the install (Approx: 30 minutes) Quick note: If you already have another aftermarket Intake, you can also purchase the Filter by Itself and replace your oiled Filter. Tools needed: • Car jack • Needle nose pliers • 10mm, 8/10 Socket with wrench • Philips screwdriver • Wheel nuts tire wrench Open that box: http://i57.photobucket.com/albums/g2...eiros/aem1.jpg http://i57.photobucket.com/albums/g2...eiros/aem2.jpg First let’s open the hood and loosen the clamp from the intake. http://i57.photobucket.com/albums/g2...eiros/aem5.jpg Let’s loosen up the nuts on the Driver’s side wheel. http://i57.photobucket.com/albums/g2...eiros/aem6.jpg Now jack the car up and remove the wheel. http://i57.photobucket.com/albums/g2...eiros/aem7.jpg Remove the fender plastic by removing these screws. http://i57.photobucket.com/albums/g2...eiros/aem8.jpg Now remove these screws under the fender. http://i57.photobucket.com/albums/g2...eiros/aem9.jpg Unscrew this nut holding the stock canister in place. http://i57.photobucket.com/albums/g2...iros/aem10.jpg Unscrew these screws holding the stock filter in place. http://i57.photobucket.com/albums/g2...iros/aem11.jpg Now remove the stock filter. http://i57.photobucket.com/albums/g2...iros/aem12.jpg Unbolt these 2 nuts holding the stock canister in place. http://i57.photobucket.com/albums/g2...iros/aem13.jpg Now (blue) cut the clip holding the wiring on the stock canister, you can see the 2 nuts removed. http://i57.photobucket.com/albums/g2...iros/aem14.jpg Disconnect the MAF sensor and remove the stock canister box. http://i57.photobucket.com/albums/g2...iros/aem15.jpg The stock canister with the filter (found tons of sand in the filter, GM filter not surprised.) http://i57.photobucket.com/albums/g2...iros/aem16.jpg Now unbolt the MAF sensor (be VERY careful with it)… http://i57.photobucket.com/albums/g2...iros/aem18.jpg |
Using pliers remove the stock clamp.
http://i57.photobucket.com/albums/g2...iros/aem19.jpg Put the big clamp on the filter and attach it to the pipe. http://i57.photobucket.com/albums/g2...iros/aem22.jpg Bolt the AEM short pipe to the plastic pipe, the small arrow represents the small clamp. Don’t tighten up the clamps too much at this time… http://i57.photobucket.com/albums/g2...iros/aem23.jpg Now make sure the black arrow on the MAF point direction of airflow, use the M4 bolts supplied. http://i57.photobucket.com/albums/g2...iros/aem24.jpg Put the supplied washer on this stud on the frame. http://i57.photobucket.com/albums/g2...iros/aem25.jpg Now tighten everything, reconnect the MAF sensor and use a stock nut to bolt bracket (Green) http://i57.photobucket.com/albums/g2...iros/aem26.jpg Re-Install the plastic fender covers, Install the wheel Lower car and Voila!! You’re all done, now go and ENJOY the added power!! |
I wanna see a pic of the engine bay now :)
That's the best part !!! Nobody (especially the dealership) can tell you have a intake ;) I love my AEM :) Nice "how to " :twothumbs |
wheres the cheapest place to get it and how much?
awesome write up:cssNET:
CEL? im assuming not, but ya never know |
Denny What is the tube size of the AEM?
Any of the 3,000-4,000rpm dead spot issues with this intake?
Nice "how to " :twothumbs Why can the dealership not tell? If they open the hood don't they just see it? |
I just ordered the AEM intake today.
Now I can't decide wether to put it all in or do this :confused: Good idea though :thumb: |
hey i got a question i ordered an AEM CAI today, Does it come with a new pipe you can see in the engine bay? because it looks like it, but you guys claim it doesn't, unless i have something different? heres what i bought.. http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Nope no engine bay pipe with the aem for the lsj Thats just a generic pic
alright thanks man, I can't wait to get this! this is my first mod besides my billet grille, I'm hoping it turns out good
I'm not bashing it or anything, but isn't that just a glorified air box mod? My K&N completly raplaced everything from filter to throttle body. How much did that thing cost you?
Injen all the way!
LOL.... The K&N pipe you paid 70-80$ more for does this: 1) That shiny new pipe does not improve flow from the stock OEM pipe 2) Uses an Oiled filter that Gums up your MAF sensor 3) Gives you a CEL because check #2 A Real Horsepower increase doesnt mean new shiny new pipe. If you read my review and look closely at the Dyno Graphs you will see a real street performance increase, thats not going to cost you a fortune for no reason. |
Originally Posted by Nuclear
Injen all the way!
Originally Posted by denny
Congratulations with that. You just bought a nice and very expensive shiny new pipe that doesnt fit properly and uses a K&N oiled filter. Did you get a CEL yet, If yes then it's time to go clean that MAF sensor again. :cssNET:
wow, bashing K&N are we? I have the intake and I have no check engine lights ever! I got it once. That was because it got wet from water. dried it and it was fine.
The trick with the K&N and the rest of them is to take the whole sensor off without taking a little bit off at a time. I took the whole thing off (wire harness and sensor as one unit not seperate). Good luck with that plastic piping heat soaking all that hot air. The K&N's pipe actually reduces the heat soak you get with the plastic stock piping. So again, I paid for something shiney that has some use and looks good. That AEM intake is "not that great". That I would have to say that is the first time I've ever seen an AEM intake without a full piping. You might as well just take the stock piping off at the thorttle body and turn it into an SRI with what AEM gave you. Seriously.. you saved a whopping $80 but you only got "HAL F THE PURCHASE". Where's the rest of the intake? As for K&N over oiling the filters I agree on that but a dry filter isn't going to do you a load of wonders either. Good luck cleaning it after you have to dip it in harsh chemicals like K&N does. it's your purchase I'm just giving my input. I usually see AEM as performance but that is like removing the stock airbox and just putting a small pipe and a filter on the end. If I wanted that I would go to Murrays and buy a $30 K&N cone filter and some PCV piping :lol: because that's what you paid for. Not putting you down, good write up but bitter about people who waste money on half purchases, to each there own. EDIT: My dealership doesn't care about my intake. It's fine under the Moss Act they said. EDITED because of Moderator displeasurement of my review on the AEM Intake ... |
