Drivetrain: How to Install Clutch/Flywheel
Old 05-23-2010, 04:44 PM
06blackg85ss's Avatar
I've done em in a little over 4 hours on jackstands in my driveway, not fun, but doable
Old 05-23-2010, 07:06 PM
chris88z24's Avatar
When mine fails you should help me out. I'll bring liquor, beer, and ho's.
Old 05-23-2010, 08:01 PM
that sounds like a plan, I got everything set up in my garage now, and closer than the other spot you met me at.
Old 05-23-2010, 08:49 PM
chris88z24's Avatar
Nice man, I'll have to check out your new place sometime. As a matter of fact I am headed to long island this coming weekend for some memorial day celebrations
Oh, and the tune you uploaded to my car is still holding up BEAUTIFULLY. I still can't get over the whole fiasco we dealt with uploading that tune to my wacked-out ECM.
The car literally puts a smile on my face every day I drive it. ha
Old 05-23-2010, 09:43 PM
BlackJackSS's Avatar
saying this must mean you sir know how to turn a wrench lol.
i did it in about 6 hours total on a lift at where i work. another 30 min or so tweaking lil things that were missed. took a lot of bleeding for the clutch to feel good.
Old 05-23-2010, 09:48 PM
lol that actually came up in conversation the other night. I'll actually be out in LI on sunday at my friends hot rod bbq in hicksville, be back home monday morning if you want to swing through on the way back (if it's early lol) I'm right off I87
That was rushing lol, done a few already, but usually it takes about 5-6 hours not killing myself
Last edited by 06blackg85ss; 05-23-2010 at 09:48 PM. Reason: Automerged Doublepost
Old 05-23-2010, 09:49 PM
chris88z24's Avatar
LOL!
I'll be RIGHT by you, I'm going to Levittown. I'll shoot you a text when I'm on my way back for sure
Old 05-23-2010, 09:59 PM
sounds good to me man.
I'll be out there in the good ol FD. 15.5 psi now on pump gas and meth. should be in the 430whp range as it sits right now.
Old 05-24-2010, 01:40 PM
chris88z24's Avatar
That's legit.
Old 05-29-2010, 11:03 PM
rhg1391's Avatar
how much was it??
Old 05-30-2010, 01:09 PM
  #36
how much was what?
the clutch?
Old 06-01-2010, 12:40 PM
  #37
shredout's Avatar
anyone know of a cheap place to get replacement E10 inverted torx for cheap? i stripped a few gettin the pressure plate out. dealer wants $20 for all six...
Old 02-23-2011, 12:30 PM
  #38
jakeLSJs2's Avatar
sub'd
Old 07-17-2011, 04:37 PM
  #39
silvercobalt07's Avatar
subd
Old 03-03-2012, 11:24 PM
  #40
Bleu's Avatar
Subd.
Old 03-28-2012, 04:23 PM
  #41
M.K. SS's Avatar
doing my clutch 2 sundays from now. if anyone wants to come and help feel free! ill supply the beer and food lol
Old 04-09-2012, 11:57 PM
  #42
M.K. SS's Avatar
so i did my clutch for the first time.everything went well except for getting the transmission back in. used the alignment tool but still gave me a hard time. finally got it in and i start to bleed the clutch.i look under the car as the fluid was still decreasing and this is after almost a full bottle of brake fluid. all the fluid was leaking out which my luck thats only one thing. bad clutch slave cylinder. so now i have to take everything back out! whoever is the genius that designed this car is a moron.worst clutch job ive ever dealt with in my entire life! end rant.lol
Old 11-25-2012, 09:26 PM
  #43
Joemaster70's Avatar
are new flywheel bolts REQUIRED?
Old 11-25-2012, 10:43 PM
  #44
Powell Race Parts's Avatar
I would say yes. can you get away without them? Sometimes. Did you torque and angle torque? Some people over torque the bolts and its over.
If you have trouble getting the transmission back in place, u may damage the tob/ should slide in easy. If you have to force it, then its not right.
good luck.
Old 11-25-2012, 10:54 PM
  #45
figure id ask. since 50+ bucks for 8 bolts is kinda pricey but if i have to. i guess i have 2
Old 11-26-2012, 10:49 PM
  #46
if you dont have an angle torque wrench, its 37 ft lbs + 25 degrees/ do the first torque, and mark the bolts. hex point to point. then mark the socket. put the socket on and move it one hex mark to the next = 25 degrees.
Old 12-30-2013, 02:41 AM
  #47
Manny5569's Avatar
Looks like the link with pics is gone
Old 12-30-2013, 09:30 PM
  #48
chris88z24's Avatar
PM me I have the service manual i can email to you in .pdf.
Old 03-25-2017, 05:19 PM
  #49
Kay001's Avatar
Hey Chris, Just curious if you have that service manual in PDF still?
Old 03-20-2018, 10:04 AM
  #50
Andrew Ross Chartier's Avatar
Do you still have the service manual for this?
if you still have this and don’t mind sending it to me that would be great I gotta do the clutch on a buddy’s car this weekend would be great having the info on hand and not winging it my Email is Andyc820@gmail.com
Solaris99
28
03-15-2017 01:22 PM
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
Delta coupe
09-30-2015 08:11 AM
Bohb
09-27-2015 09:11 PM
Quick Reply: Drivetrain: How to Install Clutch/Flywheel
