2.0 LSJ Engine: How To install Cobra Heat Exchanger! 56K=DEATH
Old Dec 1, 2007 | 05:54 PM
  #101
Cobalt_Supercharged's Avatar
Did you bleed the air out using the bleeder on top of the stock HE? Turn on the IC pump and remove and reinstall the plug on the HE. You will have to slowly keep refilling the coolant resevior. It's a real pain in the ass, which is why GM suggests the S3 Surge Tank when doing the dual pass endplate.
Old Dec 2, 2007 | 12:24 PM
  #102
Scoot05RedSS's Avatar
Yes, we removed it until alittle fluid started oozing out, then we put it back in and just ran teh pump and filled for a while. And now everytime I stop the fluid level is right at the bottom of the cylinder reservoir. I think the pressure in the system is just pushing out the coolant that's in the reservoir through the overflow. Cause if I check it while running it's fine, but if I kill it the level goes down. Thanks man!
Old Apr 1, 2008 | 06:49 AM
  #103
step n up 09's Avatar
Finally..ordered a heat exchanger,good useful information guys..it should arrive in a couple days,I spent $130 on mine so everything should be with the C/H/E...I ll post the pics of the install and what problems I run into. Also quick question,now u can do this w/out disassembling the bumper right?
Old Apr 1, 2008 | 12:49 PM
  #104
No you are def. going to have to remove the bumper. It makes thing 1000000X easier and you don't have to worry about scratching, cracking, or ******* up your bumper while you are working. It's really not that hard to remove, there's a how to somewhere to look at. It takes all of 5 mins, 10 at the most.
Old May 7, 2008 | 12:52 AM
  #105
Ok finally attempted mine today,got all the hardware,l brackets,9 foot hose,hose clamps,and instead of zip ties for the brackets we used jb weld, that's right!!! It was my Dads idea for that,also the 3'4inch elbows r too long and they don't clear,they rub the a/c condensor so I'm taking them back and getting the uncoil ones.
Also we r not using self tapping screws to mount for the bumper support,we're using nuts,bolts and washers so its for sure not to fall off. With using the jb weld u won't run into steel-alluminum contact it will melt a hole in the H/E. Using jb weld looks a lot better than the zip tie method.
We're letting it dry till next week and doing the install then so it has time to harden up,plus the time it took us to get the hardware took like 4 hours!! Ouch!!!
I'll post the pics when I'm done with the install.
Old May 7, 2008 | 01:00 AM
  #106
L.P.'s Avatar
I don't see the point of taking off the bumper..I've got my bracket made and getting ready to install it here soon....looks to be if you jacked the car up it would not be hard at all.....just got to make sure to get the top L bracket mounted first and then run the lines and once everything is connected then attach the H/E...not bad at all if you ask me.
Old May 7, 2008 | 01:17 AM
  #107
BriantheLion26's Avatar
I didn't take the bumper off. There isn't much room I will tell you that but you don't need to take the bumper off. I just put it on the lift at home and went to town.
Old May 7, 2008 | 01:31 AM
  #108
R u using the dual pass or the cobra? And what fittings did u use for the bend so the hose dosent kink?
Old May 7, 2008 | 02:03 AM
  #109
L.P.'s Avatar
I picked up some E-Z coil made by good year it was kinda high price tried to get it at my local NAPA but the guy I talked too wasn't too bright so I just went to advance auto and picked that up...looks like it will work good. I just don't see the point of trying to take the bumper off seems like that may cause more damage....
How much does the Cobra H/E help anyways? pick up any MPH in the 1/4th?
Old May 7, 2008 | 02:50 AM
  #110
Its not installed yet,I was planning on installing it till my dad showed me a different method, jb weld, so it needs to dry, next tuesday is the install day,I'm going to the track tomorrow and running it at the track,should be good w/out it as much as I wanted to have it on for the quarter,I'll let u know what I run,I should run a high to mid 13,should be fun!!! But the bumper is staying on for the install!! I don't understand why people do that cause it never goes on right when u remove and it sucks!!!
Old May 7, 2008 | 02:56 AM
  #111
zackss's Avatar
^^^^^^^^^^^for sho
Old May 11, 2008 | 04:53 PM
  #112
rico's Avatar
suscribed . i should be getting a cobra heat exchanger very soon
Old May 11, 2008 | 06:04 PM
  #113
I am just running the cobra, no dual pass. I got 90 degree elbows that go right on the cobra and they barely clear the a/c. Besides that the rest was pretty simple. Just run the lines where they go and hook um up. Bleeding the air was a bit tricky. Just hot wire up the pump and let her run. Sit back and let it do all the work.
Old May 15, 2008 | 03:26 AM
  #114
Well got the Heat exchanger mounted up w/out zip ties and self tappers,looks really good,I'll post pics once I get the coolant hose connected to the H/E hose,the fitting I have won't slide onto the pump hose,I cut it too short and it needs to be flush so it don't leak out.
Just a little FYI..use J/B weld,not zip ties,works and looks a lot better!!!
Also didn't have to remove the front bumper,just flexed the hood cover and worked just fine.
Old May 23, 2008 | 09:28 PM
  #115
valentino0214's Avatar
A++++++++++++++ awsome helped me out a lot thanx
Old Jun 9, 2008 | 12:22 AM
  #116
falke401's Avatar
It helped me too. It was a LOT easier than I thought it would be. The hardest for me was mounting the brackets to the bottom of the bumper. Took about 3 hours from start to finish.
Old Jun 15, 2008 | 03:53 AM
  #117
With a lil help from MUAH!!
Old Jun 30, 2008 | 11:25 PM
  #118
Dead Zen's Avatar
so is the 3/4 hose inner diameter or outer??
Old Jun 30, 2008 | 11:40 PM
  #119
Inner I believe,don't quote me on that Rick.
Old Jun 30, 2008 | 11:50 PM
  #120
Dead Zen's Avatar
i bought 3/4 inner. seemed huge. just wanted to make sure. thanks AJ
Old Jun 30, 2008 | 11:57 PM
  #121
not a problem man,heres mine!!
Old Jul 15, 2008 | 09:40 PM
  #122
Bansheetf107's Avatar
so you kept the stock H/E on the car?
Old Aug 16, 2008 | 09:03 PM
  #123
Dead Zen's Avatar
ok mines in and i jumpered the ic pump relay. any idea how much fluid a cobra he takes?
Old Aug 17, 2008 | 10:32 AM
  #124
Drakonen2000's Avatar
just did mine the other day, took a couple hours in the driveway...but i have to say, those stock clamps are a pain in the ass!!!! i had to bust out the dremel and cut them in half, they just would NOT come off. All in all, good mod...i work in a machine shop, so i fab'd some brackets out of quarter steel plate, its not going anywhere. I also decided to go a different route with the 90 degree bends. I took the stock hose off, and used the pressed in bends and some strait pieces of copper to tie them to the new hose. The IAT2 temps went from ~135 to ~116 (consistantly, hasnt gone over 120)
Old Aug 19, 2008 | 03:09 AM
  #125
Thats good man!! I love mine.
Yes you keep the stock one on and you run your hoses and fittings and cross them.
Last edited by step n up 09; Aug 19, 2008 at 03:09 AM. Reason: Automerged Doublepost
