All Engines: How-to Install header and downpipe
#106
took me 3 for my downpipe only lolz. first time ive every done anything to exhaust and my motor was hot not i think i could have dont it in 1hr. i should have waited till i got header and catback tho lol o well.
#109
Amazing right up. I'm going to attempt this on the weekend (long weekend for us Canadians :P)
Great pictures, I've got an '05 SC, with a ZZP 3" to 2.5" header/downpipe. I'm very excited to try this.
Any performance gains (before tune) on 100% stock car? (doing all bolt on's before i go stage 2 and need a tune)
#110
BTW if anybody needs any magnaflow exhausts, I have THE hook up. Guaranteed lowest price out there! Pm me
#115
#117
Thanks guys! Glad i could help out the community!
#119
Personally I say yes. It reduces your under hood temps on the back side of the engine by a lot. You can't see the header anyway so just put the shield back on after bending it to fit and save yourself from getting things hotter then they need to be back there.
It also quiets the header noise some. Yes headers can make a wooshing noise that sounds kinda like an exhaust leak but isn't. They are tube stainless steel and don't block out sound like a thick manifold.
By the way you might want to note that the 2.4 auto is all done through the top side and is easy to do up there. You can't get to anything from the bottom on mine.
Ok guys this is a great write up... just installed the bad-mab headers with my stock lsj dp makes a buzzing sound under acceleration is it suposed to or is it a leak idk wat it is ....
Thanks for you advice
#122
One thing I've found, if you have them, is a 13mm ratcheting wrench, particularly with the swiveling head, makes the job super easy from the top, as you can get to all 10 bolts and knock them out pretty quick that way. Only one this doesn't work for is that JBP fuckup of a header, but if you're installing that you deserve whatever it takes to put it on.
#123
Nice write up.. I ordered my BadMab and ZZP DP and theyre on the way.. Just hope this walkthrough gets me through the install.. Gonna attempt this next weekend when both parts arrive..
#124
I got badmab header for 165 and a fully catted widebanded bolt up dp for like $230ish total of 404 from badnews racing/performance/something like that.... look it up.... parts were here super quick.... i couldnt believe it.... im a stickler for doing business with good companies with good customer service and these guys blew me away.... for 50 bucks more than most people are looking to sell theres for used it was well worth it to me
#125
Awesome
Cant wait to install my new Longtube headers and downpipe from RacingSolution.com when I get home from Iraq, I will most likely use this DIY guide!
