Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   How to Guide (https://www.cobaltss.net/forums/how-guide-43/)
-   -   Interior: How to: Install an Infinity Basslink (https://www.cobaltss.net/forums/how-guide-43/how-install-infinity-basslink-80521/)
daedlus Oct 15, 2007 06:06 PM
Tools you will need:
Ratchet with extension
10mm deep socket and 8mm socket
Drill with small drill bit and Phillips driver bit
Philips screw driver
Wire Stripper / Crimper
Items you will need:
Infinity Basslink (Duh)
About 10 feet of power wire
About 6 feet of grounding wire
Fuse holder and fuse
2 Ring Terminals (Link)
2 Spade Terminals (Link)
4 butt connectors
This How-to assumes that you have all the accessories that came with the Basslink. Throughout the How-to I will tell you what I have done, just make adjustments as you see necessary. Install was done on a 07 SS/SC with completly stock stereo.
Now the manual suggests at least 12 gauge wires for the install, I used 8 gauge. The manual also suggests that you use a 25amp fuse, I used a 60amp. Before you begin you will want to choose a spot for the Basslink. I put mine where the stock one was, but its all user preference.
Make sure that you turn the bass level on your head unit all the way down before installation.
https://www.cobaltss.net/gallery/fil...2/subbolts.JPG
1 – Remove the stock sub there are 4 10mm nuts holding it onto the car. Once removed, unclip the wire harness.
https://www.cobaltss.net/gallery/fil.../subscrews.JPG
2 – Unscrew the 8 Philips screws on the front and 8mm bolt on the back holding the sub in the enclosure.
3 – Pull the sub out and cut the wires from both sides of the sub and pull the wires out of the enclosure. Put the wire harness aside.
4 – Strip one end of the power wire and crimp on a ring connector. Do the same for the ground wire.
https://www.cobaltss.net/gallery/fil...2/DSC00093.JPG
5 – Measure about a foot and cut the cable. Strip both ends where you cut the cable and install your fuse holder. DO NOT install your fuse at this point.
https://www.cobaltss.net/gallery/fil...2/DSC00075.JPG
6 – Lift up the floor carpet to expose the battery. Pop open the red cover on the positive battery post. Hook your power cable on the post here and use one of the 4 10mm nuts you pulled off the car to secure it.
7 – Run your power cable to your intended mounting spot for the Basslink, hiding the cable as you go.
https://www.cobaltss.net/gallery/fil...2/DSC00076.JPG
8 – Attach the ground cable to the chassis. I used one of the mounting bolts for the stock subs. Secure it with one of the 10mm nuts previously removed. Run the cable to the mounting spot.
https://www.cobaltss.net/gallery/fil...2/DSC00090.JPG
9 – Run the provided phone cable from the mounting spot to where you want the remote bass control, hiding the cables as you go. I found you don’t have to remove the back seats or paneling to run this wire, as it’s small and flat.
10 – Infinity has provided 2 high level inputs. You only need to use one. Grab a high level input wire harness and measure from the intended mounting spot, to the stock sub connector. Cut the wire to the desired length and strip back the 4 wires and crimp the 4 butt connectors on.
https://www.cobaltss.net/gallery/fil...2/DSC00077.JPG
11 – Remember the wire harness that we set aside in step 3? Well grab that and strip back the 4 ends. Crimp the other end of the butt connector on the wires making sure that both black wires go to the striped wires and red wires go to the solid color wire. Make sure you keep the pairs together don’t cross. This will be your end result.
https://www.cobaltss.net/gallery/fil.../DSC000851.JPG
12 – Snap the two vertical mounting feet on the bottom of the Basslink. Insert the provided bolt through the hole on the foot and tighten.
13 – Snap one horizontal mounting foot to the top right of the Basslink. Insert the provided bolt through the hole on the foot and tighten.
https://www.cobaltss.net/gallery/fil...2/DSC00079.JPG
14 – Place the Basslink in the desired location and using your drill, drill a hole where the vertical mounting bracket attaches to the car (Top side). Then screw into place.
https://www.cobaltss.net/gallery/fil...2/DSC00097.JPG
15 – Connect the high level wire harness to the stock connector then into the Basslink.
16 – Cut the power wire to the desired length and crimp on a spade connector. Do the same for the ground wire.
17 – Screw the ground wire into the Basslink marked GND then screw the power wire into the B+
18 – Connect the remote bass line and turn down to min.
19 – RECHECK all your connections especially power. When you are satisfied that all connections are good, turn the gain control knobs all the way to the bottom and the other two to the middle.
20 – Put the fuse into the fuse holder and start your car. You will need to tune your new Basslink by adjusting the 3 knobs on the unit, the bass level in your head unit, and the remote bass control.
https://www.cobaltss.net/gallery/fil...2/DSC00087.JPG
21 – Once you verify that everything is working cut a slit in your carpet and feed all the wires through the hole to clean up the install.
https://www.cobaltss.net/gallery/fil...2/DSC00092.JPG
22 – Reinstall mesh and gym bag.
*Tips
- Each of the 4 bolts that holds the stock sub in has a washer behind the carpet, remove these or you will have massive rattling.
- After listening to it you may want to install a sheet of Dynamat (or other brand of sound deadening) behind the sub.
- Clean up the wires even more by wrapping them together in electrical tape, or put them into split loom.
Thats it... enjoy!
effex80 Nov 3, 2007 01:40 AM
is she loud?
steddy2112 Nov 3, 2007 01:43 AM
Not too loud, but WAY better than stock...I have one...
daedlus Nov 4, 2007 05:59 PM
Agreed... for the amount of space it takes up, it is a big improvement. If you were to supplament it with a signal processor such as a Re-q it would be even better.
sharky_9901 Nov 20, 2007 03:53 PM
does anyone know if the wiring harness is there on cars not equip'd with the sub?
06_SS_S/C Nov 21, 2007 03:49 PM
Don't need a remote wire for this?
elecblue06 Nov 21, 2007 03:54 PM
post up a sound clip if you have a nice camera i wanted one of these ages ago for my old car but went with a amp sub combo instead
outtamymind Nov 21, 2007 05:53 PM
nice write up dude. finally someone who didn't use a convertor for theirs
daedlus Nov 21, 2007 06:35 PM
Not if you do it the way I did. The speaker level inputs will sense voltage on the speaker wires and the BassLink will turn itself on.
Ill see what I can do, but I dont think it will turn out the way you want.
Thanks! The less wires the better!:twothumbs
06_SS_S/C Nov 21, 2007 06:55 PM
So how much better does it sound compared to stock?
outtamymind Nov 21, 2007 07:23 PM
your welcome. not only less wires but less money.
elecblue06 Nov 21, 2007 09:57 PM
cool i mean it depends on how much your camera sucks lol... my camera has pretty good sound recording but usually they don't
06_SS_S/C Nov 30, 2007 01:23 PM
daedlus Nov 30, 2007 06:17 PM
my bad.. sorry missed your post. Its quite a bit better then stock, definitely more bass, but you also have a small amount of control with the crossover in the sub. As I said before, if you were to use a signal processor to give you more control, it would be better. The Re-Q is on my xmas list. If I don't get it for xmas I will buy it shortly after. I will update when I get one...
IMO the Basslink is worth the $200 I paid for it.
For the record this was the stereo in my last car, so I'm a bit picky, I just wanted my trunk in this car:
http://memimage.cardomain.net/member...76_51_full.jpg
Cirrus Jan 5, 2009 03:30 AM
OLD bump on a really important, unanswered post!
Jskip27 Feb 1, 2009 10:06 PM
The basslink is created to install to cars using the stock head unit. So it can be hooked up via rca jacks but is perfectly capable to splice into stock wires. i have one and I am very happy with it and my G5 was not equipped with sub
gre23a May 11, 2009 11:49 AM
i might add one of these to my system..nice install how-to. just got done intalling a cleansweep, and kappa 6x9s working on the 6 1/2 kappas for the doors. by the sound of the 6x9s i might need some more bass.
dunit121 May 11, 2009 11:54 AM
how about adding this on top of the stock sub?
dunit121 May 12, 2009 11:22 PM
daedlus Jun 18, 2009 03:44 PM
yeah you could...
The wires coming out of the sub are red and black. Pick a pair (one red, one black from one side) and tap into them.
dunit121 Jun 18, 2009 06:24 PM
thanks i think this might just be the next mod
Cirrus Jun 18, 2009 06:54 PM
I <3 my Basslink.
kevjam79 Sep 8, 2009 01:24 AM
I have a non-Pioneer G-5. What would be the best place pick up the signal since I don't have the Pioneer sub? Any opinions?
Cirrus Sep 8, 2009 06:59 PM
I have mine just running out of the two rear speakers. Works well enough.
kevjam79 Sep 21, 2009 09:31 AM
Did you only secure the unit via the horizontal mount on top? If so, have you had any problems with it moving around?
