Interior: How to: Install Interior Neon Accent Lights for Wiring Noobs
Old Feb 18, 2008 | 02:15 PM
Littlegoose's Avatar
Difficulty for 1st timers: 3/10.
For those that are intimidated by electrical and wiring, don't be. I was at first when i started this as a learning project and it went perfectly. For ~32$ I got nice, subtle interior accent lighting and a little experience with wiring.
You will need:
- Neon or LED Tubes (doesn't matter if it has the cigarette lighter connector) ($27.98 shipped for 15" Neon Tubes off ebay)
- Wire crimps (16 Gauge) ($1.99 @ Radioshack)
- Maybe some extra 16 Gauge Wire (If your lights come with around 4-6ft of wire each, it should be plenty)
- An on/off switch ($1.99 @ Radioshack) Make sure its an on/off switch and not a momentary switch, as a momentary switch will only give power while the button is pushed down)(If following this how-to, the switch must be rated for less than 15 amps)
For the noobs of wiring and electrical like myself:
- Black is typically your ground for wiring. Red is typically your hot, or your wire that that carries the power.
  1. I found it was easiest to start by mounting the lights where you want them. I mounted mine under the dash above where your feet stay. I had to use zip ties and carefully mount them up under, as mounting them on the plastic of the dash itself reveals the light tube(which is distracting and cheap looking imo). Also, on the passengers side, if you attempt to mount it to the plastic, it is your glove box and may cause problems for wiring/passengers etc.
  2. Next, remove the drivers side and passengers side panels from the center console where your feet are. This will give you access to your interior fuse box and a grounding location. Route the wires from the passengers side light tube to the drivers side by going through the compartment you just opened up. For help removing panels refer here.
  3. You are now going to combine drivers red wire with the passengers red wire (hots) by putting them both into one end of the crimp, and the same for the black wires (grounds). You will need to cut the wires from the cigarette lighter plug if they came with one. Now with the two hots from your lights in one side of the crimp, take another red wire you have and put that in the other side of the crimp. Do the same for the grounds. You should now have your two hots from the lights, running to a single wire and the same for the grounds.
  4. Now you will take the single hot wire and run it to one side of the push-button on/off switch. Secure the wire to the switch using electrical tape or solder if possible. You will now need another piece of red wire which will run from the OTHER pole of the switch to your fuse. Essentially the switch makes or breaks the connection. When on, the circuit is complete allowing power and when off the circuit is broken and power does not reach the lights.
  5. You will want to run your single black wire now to a ground, so pick an unpainted metal surface to secure the ground to and go from there. I used the bolt in the drivers side compartment. Next, for ease of completion, we will tap into the sunroof fuse for power. The sunroof is a good choice because it does not receive power all the time like your door locks and will not leave your lights on if you forget to turn them off. Simply wrap your single red wire around one post of the fuse and insert the fuse back into the slot or use a fuse tap. (To find out which fuse is your sunroof's look on page 5-99 to 5-100 of your owners manual or look at the diagram on the back of the passengers side compartment panel)
  6. You're Done. Test to make sure everything's working correctly. When the button/switch is in the on position, your lights should be off until you run your accessories, or turn the car on. If you decide to leave it on all the time, then they should stay on only when your sunroof works (which is nice, because they will stay on until you open the door).
Notes: I was able to wire my entire setup with the ~5ft of wire that came with a single light tube. I had the entire length of the wire from the other light tube as extra in case i messed anything up. The radio fuse is another good choice, however it IS powered all the time. I tried to run it there first but even with the car off and the radio off the lights still received power, so sunroof it was. Also be sure to find a switch that is rated for LESS amps than the fuse you will be tapping into, otherwise you will constantly blow your fuse. Pics will be posted later, night pics later tonight.
Search terms for future reference: neon, light, wiring, fuse, fusebox, how-to, interior, accent, LED, tube
Old Aug 11, 2012 | 03:42 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
This helped.. I went with the sunroof as well, so it's an always on feature when the keys are turned to accessory. I like it.. The light is subtle and not too bright .
Old Aug 18, 2012 | 06:24 PM
08baltls's Avatar
Any pictures of this?
Old Aug 19, 2012 | 10:23 AM
umn.. yeah but it's very hard to to tell
I'm going to replace the blue with red soon.. it will flow with the car better. . . since I have red halo's, the car is red.. red gauges.. etc.
Last edited by tylerjclance; Aug 19, 2012 at 10:23 AM. Reason: Automerged Doublepost
Old Aug 19, 2012 | 10:40 PM
08baltls's Avatar
Looks good though. It's subtle and not over bearing. I may end up doing this in the front and rear when I get a chance. Where ate y'all buying y'alls neon tubes?
Old Aug 20, 2012 | 01:11 AM
i got mine for free
they're really cheap on ebay
Old Sep 16, 2012 | 02:46 PM
b00sted06ss's Avatar
Thinking about doing this sometime soon, would you guys recommend tubes or the led strips? thinking about going with these Link
Old Sep 16, 2012 | 02:48 PM
574's Avatar
574
Get the led strips
Old Sep 27, 2012 | 12:41 AM
Squints's Avatar
I do these professionally in Baytown. IMO go with led strips. There is less risk of them breaking vs tubes. You can get a better look from LEDs
Old Sep 27, 2012 | 02:14 AM
xxenjoi11's Avatar
i got neon tubes for free but the wire arnt red and black.. rather both clear and one has an white stripe down it.. im guessing just keep the wires coordinated when i install them?
Old Sep 27, 2012 | 02:45 AM
Reklo87's Avatar
Agreed. I have some from LED Glow's web site.
Old Sep 27, 2012 | 03:04 PM
Squints's Avatar
I get mine from ozium.com for my personal cars customers usually want something. Heaped so I have a guy in pasadena I get them from you can get everything you need for about 50 shipped
Old Oct 25, 2012 | 04:20 AM
Squints's Avatar
You will need:
The only thing i would add is to incorporate a fuse block on your hot wire between the switch and the fuse panel other than that good write up
Old Oct 31, 2012 | 03:27 PM
Whoa, just saw all the comments on this since I wrote it a long time ago. Yeah, I ended up using an Add-A-Fuse Mini.
Regarding other questions above, I used Neon tubes from eBay, but would recommend LEDs. Not only is there better light output with LEDs, you get longer life typically and neons sometimes take a second (or less) to warm up before full output. Not a big deal at all, most people probably wouldn't notice, but it bothers me sometimes so either work, but Ill go LED next time.
Old Oct 31, 2012 | 03:28 PM
makes me consider donig red accent lights.... idk though, its not 2004 anymore
Old Nov 1, 2012 | 11:09 AM
Good one
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
Sep 27, 2015 08:53 PM
jmelton327
Sep 26, 2015 10:04 PM
