All Engines: How to install Turbo Tech Racing poly engine mount.
Old Jul 27, 2007 | 11:41 AM
cobaltstg2's Avatar
Old Jul 27, 2007 | 11:47 AM
TurboTechRacing's Avatar
Originally Posted by coleredrocket
does anybody know the gm torque specs for the bolts on the engine mounts, because you're supposed to torque them back to stock specs?
We posted the specs once, I will look it up again, otherwise if you do a search it is on this forum site.
Old Jul 27, 2007 | 11:52 AM
artawesome's Avatar
15mm bolts = 37 lbs
18mm bolts = 74 lbs torque
if i can read my writing right
Old Mar 31, 2008 | 10:12 PM
flathead0's Avatar
what do you tighten them bolts and nuts down too, nevermind
Old Mar 31, 2008 | 10:18 PM
cooljake73's Avatar
nice write up not too sure bout putting that under the oil pan but nice otherwise!!!
Old Mar 31, 2008 | 10:19 PM
deuce's Avatar
so what vibrations are you talking about? and are they bad or noticeable?
Old Aug 13, 2008 | 10:50 AM
Opi's Avatar
Opi
bumping this for those who were in the TTR motor mount group buy
will be needing this this weekend
Old Aug 14, 2008 | 06:33 PM
Yeah good call, this will help a lot
Old Aug 17, 2008 | 03:18 AM
FrankTheTank's Avatar
Now you just need to bump the prothane mount how-to's..
Old Aug 17, 2008 | 05:59 AM
steddy2112's Avatar
Just a FYI for some.
I actually had to get a piece of wood to jam between the valve cover and the inside of the engine bay, by the fender, to keep the engine from moving too far to that side...makes putting the mount in easier.
Took me ten minutes to put on both of my cobalts...SS/TC people need to be careful taking the nipple off for their air box.
Old Aug 17, 2008 | 10:35 AM
  #36
Opi's Avatar
Opi
i already had
Old Aug 29, 2008 | 08:16 PM
  #37
Black08SSTC's Avatar
Very nice. Will this motor mount work with my 08LNF?
Old Aug 29, 2008 | 11:21 PM
  #38
Yes we have one on our SS/TC project car.
Old Sep 30, 2008 | 11:34 AM
  #39
Lone1305's Avatar
I dont know why I cant see the pics that some people post on alot of the forums...
Like for this post i only see a white box with a red x in it...
Old Apr 24, 2009 | 08:55 PM
  #40
prvdoughnut's Avatar
is this also how to install on a 2.4l 2007?
Old Apr 25, 2009 | 01:31 PM
  #41
Yes, only difference is you must remove the stock air box, as it would be in the way...
Old Apr 26, 2009 | 08:36 AM
  #42
06REDGT's Avatar
i installed mine a couple weeks ago and i don't know if its just me but is seems like my car is louder.
Old Apr 26, 2009 | 08:49 AM
  #43
flobeelicious's Avatar
heh heh heh - you said nipple.
Old Aug 6, 2009 | 03:59 PM
  #44
BLACK2007LS's Avatar
was this simple? and how time consuming? with a floor jack it doesnt look TOO difficult
Old Aug 6, 2009 | 06:46 PM
  #45
10 minutes for the upper mount, and about 60 minutes for both tranny mounts together
Old Aug 6, 2009 | 09:54 PM
  #46
ill probably get an engine mount eventually, i dont have really any performance mods right now...so ill wait til i have more power to attempt to put to the wheels
Old Aug 27, 2009 | 01:03 PM
  #47
mikekoz's Avatar
Hey everybody,
I put in the upper engine mount and tranny bushings last night with my friend. The vibrations are pretty noticable/ kinda annoying. Do these lighten up at all or is just something i will have to deal with?
Old Aug 27, 2009 | 01:07 PM
  #48
Give it a few hundred miles (2 weeks or so) and then evaluate Much better...
Old Aug 5, 2010 | 02:04 PM
  #49
MP81's Avatar
Bump from the dead...
Anybody have torque specs on these bolts for the engine mount? I'm seeing 74 ft-lbs in the chilton manual...
Old Jan 20, 2012 | 05:59 PM
  #50
Bump for those to see how easy it is to install!
