How To: Interior Lights
Tools-
~L.E.D.'s of your choice... i got 2 9in. and 2 3in. OPTX strips from Advance Auto Parts ~extra wire ~heatshrink ~wire strippers/cutters ~switch ~drill Step1- Mount your lights were u want them. https://www.cobaltss.net/gallery/fil...3/img00142.jpg I mounted both 9 inchers in my footwells and the 3 inchers under the HVAC and on the steering column Step2- get all the positives and all the negatives and twist them together. add enough wire to go to the switch and the ground. heatshrink them together after you twist them all. you should have 2 in the end (+ and ground) Step3- run a positive and a negative like this. (you will need to splice) (if u want you can ground the negative to a diffrent ground you can, i ran mine to the E-brake) Step4- Drill hole for the switch and mount the switch https://www.cobaltss.net/gallery/fil...3/untitled.gif Step5- flip switch and enjoy! https://www.cobaltss.net/gallery/fil...3/img00143.jpg https://www.cobaltss.net/gallery/fil...3/img00141.jpg |
I like this, very nice
Jay B |
they dont have my color at auto advanced but just wondering, how much did you pay for all those lights and switch? i know they are kinda expensive
A good place to get lights for not very expensive is Oznium.com
They have Cold cathodes there that are amazingly bright, and very cheap. |
i payed about... $40 for the lights and i think like $2 for the switch...
subscribed.
but Question. can you still use the cigar lighter? i use a car charger at times. |
yes as long as you dont cut the power to the lighter then yes you can use it. you just splice you dont cut off. look at the wiring diagram. and the one going to the ground on the lighter is just for the LED in the switch. if its not a LED swith you will only have 2 prongs not 3
how did you get the dash off though? i looked at the car and cant seem to figure it out lol
look just like the inside of my car cept in blue...and i wired mine the exact same way good job :twothumbs
i wired mine to the fuse box but none the less good job:guns:
I like this mod but i would only want the l.e.d.s to come on when i opened my door. Then go off when i started my car. Like a dome light you no. Do you no what wire i would wire them to, to achieve this goal?
you might want to soider the connections also, if possible before heatshinking them.
Originally Posted by jacobmprater
(Post 2445261)
you can cut off the cigarette lighter if you want... then just run the power from the lights to the accesory on the switch... so its 12v to switch, light to accesory on the switch. switch to gnd (for led) and then light to gnd. you wired it really weird IMO.. the way you wired it u need the cigarette plugged in to get power... otherwise it wont work |
you can just run a self tapping screw thru the body for ground also.
where did you find 3" LED tubes at? they seem like a good size especially for the gauges like you did! (Very Nice!) however i can't find a 3" LED tube anywhere
Originally Posted by silentd
(Post 2468621)
so its 12v to switch, light to accesory on the switch. switch to gnd (for led) and then light to gnd. you wired it really weird IMO.. the way you wired it u need the cigarette plugged in to get power... otherwise it wont work uhh no... i dont have to have aqnything plugged in... i just wired it so i can still use the plug to charge my ipod and my phone and it still works.
Originally Posted by Whitty
(Post 2473858)
and there not tubes... there adhesive strips. they wont break like tubes... |
do u have to diconect the battery when u do this?
Originally Posted by joeyblaze
(Post 2479075)
Thanks for the info on what they are! Now to find a place around here that sells them... lol
bump |
as far as having them only come on when you open the door, u'd have to figure out what fuse goes to your dome light and use tap a fuse to that. least thats a quick way to do it.
Ricers!
(Post 3079019)
Ricers!
Originally Posted by knoxbox
(Post 3079028)
your moms a ricer, GTFO
(Post 3079800)
Nope, she drives a stock Cobalt, ~ NOT RICER! ;)
