Interior: How To: Interior Lights
Old May 12, 2008 | 10:49 PM
jacobmprater's Avatar
Tools-
~L.E.D.'s of your choice... i got 2 9in. and 2 3in. OPTX strips from Advance Auto Parts
~extra wire
~heatshrink
~wire strippers/cutters
~switch
~drill
Step1- Mount your lights were u want them.
I mounted both 9 inchers in my footwells and the 3 inchers under the HVAC and on the steering column
Step2- get all the positives and all the negatives and twist them together. add enough wire to go to the switch and the ground. heatshrink them together after you twist them all. you should have 2 in the end (+ and ground)
Step3- run a positive and a negative like this. (you will need to splice) (if u want you can ground the negative to a diffrent ground you can, i ran mine to the E-brake)
Step4- Drill hole for the switch and mount the switch
Step5- flip switch and enjoy!
Old Jun 5, 2008 | 06:59 PM
JayB1127's Avatar
I like this, very nice
Jay B
Old Jun 7, 2008 | 11:14 AM
dragonkingg5's Avatar
they dont have my color at auto advanced but just wondering, how much did you pay for all those lights and switch? i know they are kinda expensive
Old Jun 7, 2008 | 11:21 AM
Joeyavhu's Avatar
A good place to get lights for not very expensive is Oznium.com
They have Cold cathodes there that are amazingly bright, and very cheap.
Old Jun 8, 2008 | 01:01 AM
i payed about... $40 for the lights and i think like $2 for the switch...
Old Jun 8, 2008 | 03:06 PM
Deathcult's Avatar
subscribed.
but Question. can you still use the cigar lighter? i use a car charger at times.
Old Jun 9, 2008 | 11:22 PM
yes as long as you dont cut the power to the lighter then yes you can use it. you just splice you dont cut off. look at the wiring diagram. and the one going to the ground on the lighter is just for the LED in the switch. if its not a LED swith you will only have 2 prongs not 3
Old Jun 14, 2008 | 10:05 AM
Deathcult's Avatar
how did you get the dash off though? i looked at the car and cant seem to figure it out lol
Old Jun 14, 2008 | 12:06 PM
CCBalla10's Avatar
look just like the inside of my car cept in blue...and i wired mine the exact same way good job
Old Jun 14, 2008 | 12:13 PM
dman090's Avatar
i wired mine to the fuse box but none the less good job
Old Jun 15, 2008 | 12:20 AM
19transam81's Avatar
I like this mod but i would only want the l.e.d.s to come on when i opened my door. Then go off when i started my car. Like a dome light you no. Do you no what wire i would wire them to, to achieve this goal?
Old Jun 15, 2008 | 12:26 AM
Frankruffolo257's Avatar
you might want to soider the connections also, if possible before heatshinking them.
Old Jun 15, 2008 | 12:52 AM
silentd's Avatar
you can cut off the cigarette lighter if you want... then just run the power from the lights to the accesory on the switch...
so its 12v to switch, light to accesory on the switch. switch to gnd (for led) and then light to gnd.
you wired it really weird IMO.. the way you wired it u need the cigarette plugged in to get power... otherwise it wont work
Old Jun 15, 2008 | 12:55 AM
you can just run a self tapping screw thru the body for ground also.
Old Jun 16, 2008 | 01:56 PM
Whitty's Avatar
where did you find 3" LED tubes at? they seem like a good size especially for the gauges like you did! (Very Nice!) however i can't find a 3" LED tube anywhere
Old Jun 17, 2008 | 01:20 AM
uhh no... i dont have to have aqnything plugged in... i just wired it so i can still use the plug to charge my ipod and my phone and it still works.
there made by OPTX and i got wm from advance autoparts. or goto streetglow.com
and there not tubes... there adhesive strips. they wont break like tubes...
Last edited by jacobmprater; Jun 17, 2008 at 01:20 AM. Reason: Automerged Doublepost
Old Jun 17, 2008 | 02:51 PM
joeyblaze's Avatar
do u have to diconect the battery when u do this?
Old Jun 18, 2008 | 12:01 AM
its good idea... i did
Old Jun 18, 2008 | 10:05 AM
Whitty's Avatar
Thanks for the info on what they are! Now to find a place around here that sells them... lol
Old Nov 8, 2008 | 11:58 PM
ericgt79's Avatar
Old Nov 9, 2008 | 03:02 AM
knoxbox's Avatar
as far as having them only come on when you open the door, u'd have to figure out what fuse goes to your dome light and use tap a fuse to that. least thats a quick way to do it.
Old Nov 9, 2008 | 03:04 AM
chris88z24's Avatar
Ricers!
Old Nov 9, 2008 | 03:07 AM
knoxbox's Avatar
Ricers!
your moms a ricer, GTFO
Old Nov 9, 2008 | 01:59 PM
chris88z24's Avatar
Nope, she drives a stock Cobalt, ~ NOT RICER!
Old Nov 9, 2008 | 09:34 PM
knoxbox's Avatar
oh so shes one of those hotties that drive a cobalt then... even better.
