2.2 L61 Engine: How To: Remove the Plastic Engine Cover!
I dont know if this is specific to a specific model and all, but i did this and i couldnt believe how much room it freed up, and what exactly was holding it on.
1. Pop the hood.
2. Remove the oil cap.
3. Lift on the plastic.
theres 1 pin holding it in (other than the oil cap), on the back left. it just pops off.
When you do this, it frees up a decent amount of room, and you can actualy see the engine, the engine runs about 5 degrees cooler (Thx SilverStreak), also makes it easier to do mods.
1. Pop the hood.
So there is an engine under all that plastic,,, good to know, lol
At least it's not as bad as the avalanche. I almost hit the ground I was laughing so hard when my buddy first popped the hood on his. Between the ugly facias, bumpers, and engine covers, there was like 2 feet of plastic between us and anything metal.
Originally Posted by TCarter
SS33, I work at a chevy dealership. ive never looked at a avi engine. i'll be sure to do that tomorrow.
EDIT: His was like an 01 or 02 I think it was my fresh year of college, so it was at least 4-5 years ago. I wouldn't imagine they've gotten any better though
How about the little spacer that makes the oil filler cap sit way too far up when the plastic engine cover is removed? It seems like its snapped in or something but I'm not trying very hard yet to remove it since I don't want to break it.
the spacer is just that...a spacer. its part of the engine. not the cover. trust me. where people **** up is, they try and take it off....without taking off the oil cap.
the oil cap is what holds it down in that section..
Or maybe the cap is different and won't mount that way, but I saw a reference to it earlier here on the forum and never got a response when I asked about it.
the oil cap riser can be removed as well. It is a little tighter then the oil cap itself, but it does simply screw off with a quarter turn. Use some large plyers to get a hold of it if you can't spin it off by hand. Then your stock oil cap will fit back in the hole. OR you can get an aftermarket cap like mine...
I did this "mod" today. I was in a parking lot with a friend and I just had the urge to remove the cover. Engine certainly ran much cooler and it looks better as well. Hopefully soon I'll have an intake and the other hunk of plastic will be gone as well.
I noticed zero sound difference with the cover off.
Originally Posted by Strider_2001
With the engine running 5 degrees cooler will that increase any performance at all??
Edit: should be more helpful at 1/4 tracks cuz the engine will cool faster for the next run
that looks preety good did you have it polished (the engine not the cap_)
Well I'm about 2 weeks into this "mod" and from what I've noticed there is still no difference in sound while moving, but idle is noticably louder. I think I might reattach the cover in the winter so that my engine might stay a little warmer between startups.
Originally Posted by hardtocope
has anyone elsed removed the extension on the oil cap? does it just unscrew off?
yeah i have it just screws off and you can put the oil cap where the spacer was but its held on thier real tight so using pliers is a good idea
