2.2 L61 Engine: How To: Remove the Plastic Engine Cover!
Old Aug 27, 2006 | 03:15 PM
marerick007's Avatar
Thats pretty sweet looking
Old Sep 2, 2006 | 11:39 PM
06cobaltls's Avatar
Originally Posted by Halfcent
the oil cap riser can be removed as well. It is a little tighter then the oil cap itself, but it does simply screw off with a quarter turn. Use some large plyers to get a hold of it if you can't spin it off by hand. Then your stock oil cap will fit back in the hole. OR you can get an aftermarket cap like mine...
thats pertty i need to do this to my balt
Old Sep 3, 2006 | 01:36 AM
06CobaltssOrange's Avatar
hey
can someone plz show a picture with it gone on a cobalt ss/sc?
Old Sep 5, 2006 | 01:33 AM
Halfcent's Avatar
I'm old school
Um, an SS/SC doesn't have the engine cover to start with.
Old Oct 3, 2006 | 04:05 PM
TCarter's Avatar
Originally Posted by 1BadBlueSS
does this just work on the 2.4?
To answer your question, this tutorial was done on a 2.4L.
So the answer is yes.
Old Oct 7, 2006 | 11:30 PM
biniecki's Avatar
I just removed mine today and I was wondering if there is a way to get the risers that hold the plastice cover on off. it looks like the rear one has a nut on it to just screw off but im not sure about the front one. Anyone know?
Old Oct 9, 2006 | 10:01 PM
Halfcent's Avatar
I'm old school
I assume you are talking about the two metal pins on either end that the cover snaps on to. They just screw off, very easy.
Old Oct 10, 2006 | 03:25 PM
biniecki's Avatar
How does the one in the front come off. I was able to remove the rear one with a 10mm end wrench because it actually had a but welded onto it. The front one doesnt seem to have that. It does into steel bracket and it is tapered on both sides and both end are round so i dont know how to get it off. Any info?
Old Oct 12, 2006 | 09:24 AM
biniecki's Avatar
The front one deffinately does not come off on the 2.2L by conventional methods. If you want it off you have 2 options. 1 would be to cut it off and 2 would be to remove the bracket that it is attached to. If you remove the bracket, you have remove a tie that is holding a wiring harness on it, figure out how to remove the dipstick from it, and i believe that part of the A/C is ties to it as well. I think i may opt for option 1 because i fubared it pretty good with a pair of vice grips trying to screw it off but its not made to come off.
Old Oct 12, 2006 | 10:22 AM
LewiSS's Avatar
I was going to trim off the part of the bracket that holds the pin with a Dremel and cut-off wheel.
Old Oct 13, 2006 | 09:08 PM
  #36
biniecki's Avatar
I just used a cutting wheel to cut the pin off. Worked out great. No more cover for me.
Old Oct 13, 2006 | 09:18 PM
  #37
Boosted_SS's Avatar
POINTS AND LAUGHS HA! HA!
Old Oct 13, 2006 | 09:19 PM
  #38
NoRemorse's Avatar
umm.. what cover? THe LSJ does not have a plastic engine cover. it DOES have a fuel rail cover, but it is TINY, I would just leave it, it is just a messof tubes and wiring behind it.
Old May 7, 2007 | 06:31 PM
  #39
purplepower's Avatar
Engine Cover
I just put my engine cover in the trunk. The Engine compt. looks a lot better.I had a little trouble getting the oil cap spacer off, but it was well worth it.
Old May 23, 2007 | 10:44 PM
  #40
cobalt9123's Avatar
late post but be aware this does also keep engine heat off of the hood..which after a long while(8-10 years) will make the hoods paint look like complete **** lol, even though we do have heat protectors other than the engine cover.
Old Nov 15, 2007 | 10:53 AM
  #41
Cobalt(312)'s Avatar
I can't believe this is a thread...
Old Apr 5, 2008 | 09:41 PM
  #42
kmmartin86's Avatar
ok question, i have the 08 sport (since they decided to quit with the ss/sc) and theres one huge engine cover and like 2 or three other ones. i'll admit i dont know squat about most stuff on cars but what are they and can they be taken off?
Old Apr 5, 2008 | 11:32 PM
  #43
tru2nrtt777's Avatar
Pics of the bay?
Old Jun 9, 2008 | 06:48 PM
  #44
cobaltss86's Avatar
i painted mine
Old Jun 10, 2008 | 03:51 PM
  #45
hailcesar75's Avatar
that's a sweet looking engine you got there. How did ya get it like that
Old Jun 10, 2008 | 03:56 PM
  #46
umrdyldo's Avatar
holy jesus,
Old Jun 10, 2008 | 04:12 PM
  #47
dman090's Avatar
Originally Posted by umrdyldo
holy jesus,
lolz X2 that engine looks hideous^^^
Old Jun 10, 2008 | 04:22 PM
  #48
SilvrLT's Avatar
x3
Old Jun 18, 2008 | 12:16 PM
  #49
Whitty's Avatar
i was thinking of getting body matched spray and doing my cover when i got my intake but after seeing that... seriously questioning my idea...
Old Jan 5, 2009 | 07:47 PM
  #50
SedanMan08's Avatar
Would taking the plastic cover off be dumb if your living in a relatively cold state with periodical snow blasts and sleet? lol
