Interior: HVAC mod...first one
Old Jun 30, 2006 | 11:24 PM
biohazard's Avatar
Get low
i think im the first one to do this.... I changed the color of my hvac controls... heres what you need
-roll of transperent celophane the color that you want to light up
-flathead screw driver
-socket/ratchet set
-scotch tape
-razor blade
-scissors
Step 1: remove dash panels
Ok so first off remove the dash panels.... i did not take pictures of this part because it can be found on this site already ....
Interior Disassemble Dashboard - Radio and related panels - Cobalt SS Network
Step 2:remove HVAC controller
This is very simple, take the socket(i forgot size) and remove the 2 screws. There is 1 on each side of the box. After this pull it out towards you slowly and disconnect the cables in back
I have extra wires in the picture because i have my toggle switch ran through the faceplate
Step 3:pop off face
There are 4 tabs to hold the HVAC box together (2 on top,2 on bottom) pry with a flathead screwdriver, or push the tabs inwards with your hand and work the face off... the fan control speed knob willl fall off
here is what you will see.... now at firs i was going to replace those lights with green ones or L.E.D.s but for one leds will not project out to the side, and 2, lights would be too much of a hastle to replace so i used some cellophane instead i got at factory card outled for $4
you can try any color but i cannot promise how good itll work... i used green, i can imagin any color but yellow working good...
Step 4: lay down the color
Start on one end and work to the other, i double layerd the cellophane to make a deeper color, i would reccomend layering it 2 times but not 3 unless its yellow then maybe 3 will make it more true...
tape the ends down to the side with scotch tape... or masking tape(scotch tape will actully hold better for this)
cover the middle like i did here.... notice the cellophane goes right up to the stud for fan speed so you cover that 1/2 circle above it, use scotch tape because the color will shine through it.
finally do the other side like the first side....You may not want to do this side though because it has blue and red on the face for the temp, only some colors may work good. next put a squar of tape of tape above the knobs for temp and ventalation type and poke a hole right above the knob and slide it through like in the pic... also if you want your 3 buttons on the bottem, a/c,defrost, and circulation to light up colored, put some on the 3 studs at the bottem this is tricky. The 3 orange lights will not be able to be recolored, i tried it. Its easy to cover them but the orange turns most colors brown.
Step 5: Re-assembally
Turn all of the knobs to the right or left to make this easier... do the same on the faceplate. Carefully put the faceplate back on and snap firmly. plug the box back in. Put it back in the dash... reinstall the trim and your set.....
Old Jul 1, 2006 | 03:44 AM
Young Money's Avatar
That looks bad ass!!! I might have to give that a try with some blue action... big ups on the write up... lookin good my dude...
$YM$
Old Jul 1, 2006 | 11:52 AM
mcphatty's Avatar
did that on my old truck, simple mod but makes things look really good.. might have to try it
Old Jul 1, 2006 | 12:33 PM
biohazard's Avatar
Get low
thnx guys, i was just sitting there one night like damn that needs to be green and i had off work yesterday.... today i have off to so im doing the gear letters if i can
Old Jul 1, 2006 | 12:34 PM
D4u2s0t's Avatar
not bad...seems pretty easy too! nice write up
Old Jul 1, 2006 | 12:50 PM
yallabalt's Avatar
I may be asking a stupid question but..... Lights produce heat, not sure how much heat those lights produce but would the cellophane melt? Just curious. Very good how too by the way.
Old Jul 1, 2006 | 03:06 PM
biohazard's Avatar
Get low
they give off heat since their ligh bulbs not l.e.d.s stupid gm lol. Funny cuz their the size of leds but are deffinalty bulbs...they get hot enough t0 burn your finger but i wasnt worried, if anyting the cellophane will shrink and crinkle but you dont see it anywaysd and the $4 roll will do about 200 of these lol so if worst comes to worst i redo it
Old Jul 1, 2006 | 03:20 PM
Ljavy17's Avatar
arroz.
Old Jul 1, 2006 | 06:11 PM
biohazard's Avatar
Get low
Originally Posted by Ljavy17
arroz.
huh? o by the way i did the shifter lights too... a how to will be up after i get home from the gfs house tonihgt
Old Jul 1, 2006 | 06:16 PM
HackAbuse's Avatar
Awesome, after a year, my shifter accents are starting to fade
Old Jul 1, 2006 | 06:21 PM
TWIZTED 2.2's Avatar
That **** looks cool.. im trying to deside.. what colors i wanna go with.. neon interior lighting and stuff,... and suggestions..
sorry to post something in here.. but dont forget to cast your vote:
https://www.cobaltss.net/forums/wheels-tires-96/poll-my-rims-24643/
Old Jul 2, 2006 | 12:45 AM
hackeragent061's Avatar
that's kool, how long did it take for u to do that
Old Jul 2, 2006 | 12:49 AM
biohazard's Avatar
Get low
20 mins once i got the dash apart
Old Jul 2, 2006 | 01:03 AM
Clmbngfrk18's Avatar
man thats cool no if onlyi hadnt painted over all that stuff i would deff do this
Old Jul 2, 2006 | 01:13 AM
BACK2GM's Avatar
Looks like a dodge/Chrysler HAVC controls now with the green.
Old Jul 2, 2006 | 01:19 AM
biohazard's Avatar
Get low
my new how to is up for the shifting lights on the autos
Old Jul 3, 2006 | 12:35 AM
CobaltLT's Avatar
Wow dude thats awesome, very nice!!!
Old Jul 3, 2006 | 12:37 AM
M88ArRamadi's Avatar
not bad.......did you sneeze everytime you took a pic?
Old Jul 3, 2006 | 09:11 PM
biohazard's Avatar
Get low
no i was too lazy to get a tripod and i had to over expose the picture b/c of the dark.... without a tripod its hard even your pulse blurs it
Old Jul 3, 2006 | 09:35 PM
lilturk1's Avatar
where did you get your carbon fiber dash kit from man
Old Jul 3, 2006 | 11:22 PM
biohazard's Avatar
Get low
www.nycdashes.com
Old Mar 28, 2007 | 12:02 PM
Nugz's Avatar
I hate to kick a dead horse here but I'm gonna do this mod today and have a question. Instead of putting the plastic over the lights, cant you just put them on the back of the light cover?
Old Mar 28, 2007 | 06:26 PM
kawategra98's Avatar
where did you get the carbon fiber parts that is so freakin bad ass please do tell!!!!
Old Mar 29, 2007 | 01:32 PM
Nugz's Avatar
Old Mar 29, 2007 | 01:45 PM
07LaserBlueSS's Avatar
dash kit is from www.nycdashes.com!
