Electrical: Installing the FIC6
Old Jun 3, 2010 | 01:31 PM
Axelthered05's Avatar
Installing the FIC6
Hay everyone I installed an FIC6 on to my 06 Chevy cobalt LS 2.2 L61 a few months ago and figured I should post what I learned
First you will need a pin out of the L61’s computer I found this one on the ecotec forums
http://www.ecotecforum.com/forums/sh....2L-ECU-Pinout
And here is how I have it connected
Ok first we will start with the 56 pin connector (the smaller one)
The only wire you will need from this connector is the power for the fic, so connect the power wire for the fic to the wire at pin number 28 wire colors PK/BK circuit number 1139 you will want to tap this wire
For the 73 pin connector (the larger one) I had the wires connected as follows
1) For injector number 1 look for pin number 10 wire color is TN circuit number 1744 you will want to cut this wire the wire coming from the ecu will go to the blue FIC wire labeled INJ 1 IN and the wire going to the number 1 injector will be connected to the blue FIC wire labeled INJ 1 OUT
2) For injector number 3 look for pin number 11 wire color is PK/BK circuit number 1746 you will want to cut this wire the wire coming from the ecu will go to the blue FIC wire labeled INJ 3 IN and the wire going to the number 3 injector will be connected to the blue FIC wire labeled INJ 3 OUT
3) For injector number 4 look for pin number 12 wire color is L-BU/BK circuit number 844 you will want to cut this wire the wire coming from the ecu will go to the blue FIC wire labeled INJ 4 IN and the wire going to the number 4 injector will be connected to the blue FIC wire labeled INJ 4 OUT
4) For injector number 2 look for pin number 13 wire color is L-GN/BK circuit number 1745 you will want to cut this wire the wire coming from the ecu will go to the blue FIC wire labeled INJ 2 IN and the wire going to the number 2 injector will be connected to the blue FIC wire labeled INJ 2 OUT
BE VERY CAREFUL NOT TO MIX UP (INJ # IN) WITH (INJ # OUT)
5) Next up you need to tap the TPS for the fic you only need to tap this wire, pin number 36 wire color PU circuit number 486 this will connect to a White wire from the FIC labeled TPS+ Remember to only tap this wire
6) Next is the first oxygen sensor pin number 41 wire color PU/WH circuit number 3110 since our cars have narrow band sensors we need to install a resistor before the fic wire tap, the resistor is a 1/4W 1k ohm resistor a pack of 5 is $1 at radio shack. Cut the wire Sauder in the resistor to the sensor side of the cut Sauder the PINK fic wire labeled O21+ and the ecu wire to the other end of the resistor.
7) Next is the second oxygen sensor pin number 43 wire color PU/WH circuit number 1668 since our cars have narrow band sensors we need to install a resistor before the fic wire tap, the resistor is a 1/4W 1k ohm resistor a pack of 5 is $1 at radio shack. Cut the wire Sauder in the resistor to the sensor side of the cut Sauder the PINK fic wire labeled O22+ and the ecu wire to the other end of the resistor.
8) There is no point in using the MAF wire since the FIC6 cant process a frequency based signal so you can skip that
9) Next is the MAP sensor pin number 62 wire color is L-GN circuit number is 432 cut this wire, the ecu side connects to the Gray fic wire labeled ANALOG A OUT and the sensor side connects to the Gray fic wire labeled ANALOG A IN you will need to adjust the input setting on the fic to the “offset” setting in order for it to work right
10) Next it the first crank wire pin number 66 color YE circuit number 573 cut this wire the ecu side connects the Green FIC wire labeled CRK MAGO+ and the sensor side connects the Green FIC wire labeled CRK MAGI+
11) Next is the second crank wire pin number 67 wire color PU circuit number 574 cut this wire the ecu side connects to the Green FIC wire labeled CRK MAGO- and the sensor side connects the Green FIC wire labeled CRK MAGI-
12) (WARNING if you start your car and get VIOLENT misfire between 4500-5500rpm under load (while driving) you are getting signal noise in your wire, the FIC inputs are sensitive enough that they will pick up noise and send an extra cam pulse to the ECU. The solution is to install a 2k ohm resistor with one side connected to Crank MAGI(+) and the other side connected to Crank MAGI(-) If you baught a pack of 1k resistors from radioshack you can use 2 of the remaining 3 resisrors connect them in series like this (Crank MAGI+)---0=0-----0=0---(Crank MAGI-) to create 2k resistance
13) Next is the CAM wire pin number 70 wire color BN/WH circuit number 633 cut this wire the ecu side connects to the Yellow FIC wire labeled CAM1 HALO+ the sensor side connects to the Yellow FIC wire labeled CAM1 HALI+
14) Next is the grounding I found a few ways that worked but I suggest taping into the ECU’S ground so your sharing the same reference signal as the engine the ground wire is the big Black wire you all have been staring at while wiring everything else its pin number 73 wire color is BK/WH circuit number 451 you will want to connect all 3 of the fic’s grounds to this wire Black Fic wires labeled “PWR GND” “SIG GND” “PWR GND”
What you do with the wires such as “Analog B” “Logger Trigger input” “MAF” and “12V switched” is up to you
Hope this helped feel free to tell me if I missed anything, Install the FIC at your own risk I am not responsible if you break something lol
Old Apr 2, 2018 | 07:37 PM
N.chichura4's Avatar
I just installed the same thing, thank you for the post, but after installing, my car would crank, but not start..
Old Mar 2, 2021 | 01:24 PM
slow-ecotec's Avatar
You need to tune the unit for your car. It has no idea where the car wants fuel or spark. I'm sure with some quick Google searches including the mods you have you'll be able to find a tune file
Its exactly like a brain transplant, the brain can't make sense of any information it's getting until you teach it what different signals mean and what to do when it receives them.
Axelthered05
Tuning
Oct 14, 2016 02:54 PM
acoutu
How to Guide
Jul 9, 2012 06:23 PM
bboyfreeflow
May 3, 2009 01:03 PM
Opi
Aug 4, 2008 01:23 PM
