General Suspension: k sport coilover install(56k get a beer)
Old 10-09-2007, 12:20 AM
  #76
jimbos'ss's Avatar
Originally Posted by jerseyfatboy
ok i see it now guys thanx alot........o nd great write up jimbo
thanks
Originally Posted by 07SSCharged248
mmm.... SEX!
thanks, i thinks so too.
Originally Posted by matrixpuba
i was going to use lowering springs but i have been looking at their coilovers. they look like a nice product. would you say you are happy with them?
yes, i'm very happy with them, but there is a better product out right now that modern performance is selling. i would go with there set because the have adjustable rear struts. the ksports don't
Old 10-09-2007, 12:25 AM
  #77
madmark's Avatar
okay i just installed my ksport coilovers and i didnt use the 4 rubber washers and the 4metal rod pieces.
what are those for?
Old 10-09-2007, 12:34 AM
  #78
jimbos'ss's Avatar
what are those for?
got no clue, didn't use em either.
Old 10-09-2007, 12:38 AM
  #79
madmark's Avatar
how long has your coilovers been on? ive had mine for 3 days and everytime i let the car sit for a couple of hours, i release the ebrake and it start creaking for a few minutes....is that normal?
Old 10-09-2007, 01:00 AM
  #80
jimbos'ss's Avatar
i've had mine almost 6 months, don't have any creaking noises either, considering it's when you let off the e brake i would check the rear suspension first to see if anythings out of the ordinary
Old 01-16-2008, 06:11 PM
  #81
07BlueGranite's Avatar
do you have any pics of them all the way down? if not, how much more lower can it go then what you have it at
Old 03-04-2008, 11:40 PM
  #82
pacific cobalt's Avatar
Originally Posted by jimbos'ss
unfortunately not, only ride height is adjustable for the rear, i recently decided, i'm gonna switch to the koni struts for the rear so it will be fully adjustable .
updated info: i found that if you lower the rear as much as i have the struts will be almost bottomed out, i tried to see if the factory rear struts did the same and they do, so i'm gonna take the car to a shop and have the lower strut mounts for the rear put about an inch and a half lower. this way i'll retain the full range of motion on the rear struts like the front.
Did you ever end up switching the rear shocks for Koni's?
I have the same Ksport coilovers and I'm kinda dissapointed that the rears are not damper ajustable like with the BC Coilovers. I'd like to make the rear shock as soft as possible for long highway trips
Old 03-05-2008, 12:09 AM
  #83
jimbos'ss's Avatar
no unfortunately i have not gotten around to doing anymore work on the suspension with the current motor/turbo build. later i will do alot more, i plan on switching to the koni's as well as welding a lower bracket to mount the bottom of the shock to to get more travel out of it in the rear.
Old 03-05-2008, 10:16 AM
  #84
I got the LS cobalt so I'm wondering if I can ajust the rear height enough not to bottom out the koni shock like you mentioned.
Old 03-05-2008, 10:27 AM
  #85
sick06cobalt's Avatar
do these replace the stock struts?
Old 03-06-2008, 04:05 PM
  #86
NOS2006's Avatar
If I were to go with coilovers, would I need to get a shop to give me an alignment every time I switch the ride height?
For someone who knows nothing about suspension (but can throw together a clutch on this car in a weekend), how difficult is it to actually adjust everything correctly with these coilovers?
Old 03-07-2008, 02:01 AM
  #87
jimbos'ss's Avatar
depends on how low you want to drop the car
get a qualified performance shop to do the alignment, it's very tough to get it right with out having the alignment rack. and most tire/alignment shops don't know what the hell there doing. the install on these is easy though.
yes they do
Old 03-07-2008, 08:19 PM
  #88
yes they do
I would be willing to raise the rear height if it means I can use a Koni
Might have to try this one out only I don't want to spend $319.99 and be stuck going back to the original Ksport Rear Shock
Old 03-08-2008, 12:49 AM
  #89
jimbos'ss's Avatar
i just plan on making and welding lower brackets.
Old 03-23-2008, 04:39 PM
  #90
wongafet's Avatar
how far off was ur alignment before u had it adjusted after u put these on?
Old 04-15-2008, 03:03 PM
  #91
CobaltSS 16's Avatar
How is the ride quality with these set on the softest setting?
Old 04-15-2008, 03:25 PM
  #92
jimbos'ss's Avatar
the alignement wasn't bad, the toe and camber was though.
about as bumpy as riding on sportlines
Old 04-15-2008, 05:50 PM
  #93
madmark's Avatar
no the ride quality was ass
Old 04-15-2008, 06:58 PM
  #94
jimbos'ss's Avatar
mines not that bad, definately no worse than rolling on sportlines springs.
Old 05-18-2008, 02:13 PM
  #95
MBMCustoms's Avatar
So would these ride smoother than my SSC's? cuz i am really looking into making this a near future mod.
Old 05-29-2008, 12:05 AM
  #96
IonNinja's Avatar
just bringing this up again...do you have anymore pics of the rear?
I'm not understanding how you adjust ride height with the sleeve installed like that
Old 05-29-2008, 12:41 AM
  #97
jimbos'ss's Avatar
i don't have anymore pics right now, the sleeve has a "nut" so to speak that is adjusted up and down using a spanner wrench.
Old 05-29-2008, 12:43 AM
  #98
IonNinja's Avatar
right but I don't understand the way that you have it how its actually adjusting the height...it looks like the sleeve is just sitting on top of the spring instead of flipped over and inside the spring or having the sleeve on the bottom
also i'm assuming you still have the bump stop installed in there?
Old 05-29-2008, 12:44 AM
  #99
jimbos'ss's Avatar
right it does sit inside the spring, but the spring actually rests on the "nut"
Old 05-29-2008, 12:57 AM
  #100
IonNinja's Avatar
i'm still confused lol because i don't see your spring sitting on that nut at all...looks like the bottom of the sleeve is just sitting on top of the spring. Must just be the picture...
its cool though because you've given me an idea
Quick Reply: General Suspension: k sport coilover install(56k get a beer)
