LNF: Installing Bad-Mab Catless downpipe
How to install a Bad-Mab catless dp or any dp really Minimum tools required 15mm medium to deep socket knuckle adapter 8"-12" long extension ratchet or impact gun 7/8 or 22mm wrench (if you prefer a O2 sensor socket) 15mm box end wrench Extra things to have Penetrating spray oil (Wd-40, PB's, Liquid Wrench, ect) Anti-seize A Lift (makes life way easier) If your cant see the pictures this how to is useless First get the car in the air and spray the exhaust studs on the dp with penetrating spray oil http://i1231.photobucket.com/albums/...g?t=1289788283 Using a 15mm medium or deep socket, knuckle adapter, ratchet/Impact, and a 8"-12" long extension remove the 4 for nuts from the studs on the turbo side of the dp. Then pull down the turbo side of dp onto the subframe http://i1231.photobucket.com/albums/...l/IMAG0017.jpg http://i1231.photobucket.com/albums/...l/IMAG0016.jpg Drop the dp down and finish unscrewing the O2 sensor. Remove the old exhaust gaskets and install the new gaskets that came with the Bad-Mab dp. Also put a light amount of anti-seize on the exhaust studs threads if you want. Put a light amount of anti-seize on the O2 sensor threads. Then screw the O2 sensor into the Bad-Mab dp. (I recommend that you install a O2 defouler which is necessary with most catless dp's unless you want a CEL in the near future) Slide the new dp on the turbo exhaust studs first and then the back studs. Tighten the nuts evenly on all the studs. http://i1231.photobucket.com/albums/...l/IMAG0019.jpg Start the car, check for leaks and your done. Enjoy :twothumbs |
Cool thanks just got mine in today and put it on... sounds great by the way!!!!!!
Originally Posted by ixxgh0stxxi
(Post 5415868)
Also I like how it helps the turbo spool faster and makes the turbo whistle louder. I'm sure you have noticed. Bad-Mab builds a great down pipe and you cant beat it for the price.:spam: :lol: |
ohh yea i got the muffler delete too and man when boost hits it sounds ridiculous lol some guy thought i spend like 1 grand on my exhaust couse he said it sound sick lmao
i am seriously considering buying this and selling the one i just put on b/c it looks so badass
(Post 5424905)
Originally Posted by JacBlackSS/TC
(Post 5425229)
i just put mine on and i got the same defouler but mine comes really close to the heat shield and when im pulling out it vibrates yours dont even look like it comes close mine barely fit
Originally Posted by silver-ss/tc
(Post 5458588)
I can't wait to put mine on. hopefully it is not to loud with the stock cat back during normal driving.:)
I'm buying this tomorrow, now does the defouler come standard or what i didn't see anything about it on the site??
i have the megan one and it looks identical had it on almost a month and no cel yet
Originally Posted by bspeed
(Post 5479989)
you will need to order this |
Originally Posted by xcross
(Post 5480410)
alright thanks man ordered this aswell |
i got mine in my moms house waiting for me 2, i am not using a defouler though, i just had vince tune out my CEL for the DP but i can still read the 02 sensor on my Dashhawk
a lift makes it way easier!................floor jacks, fail! I found out the hard way smh
good right up!!! helped me out when installing mine...
Any videos with the muffler delete???
I like it.. looks great, sounds great :twothumbs but doin the install on jack stands is a bitchhhhhhhhh :thumbsdow
besides the light what will the cel do?
i dont need to pass inspection for a tag or anything |
no inspection? youre lucky
my gift came on wednesday bad-mab it is fucking sexy i cant wait to put it on and see the power gains good work! you guys should def make more parts |
oh and also to kid above^
This CEL wont do anything to your car, it'll just tell you that you dont have a cat nothing big you get more power because of no back pressure |
Wait im confused, it looks like the 02 sensor is screwed into the heat shield with the bad mab installed?
Im installing my zzp catless dp Wednesday! |
Originally Posted by seeyaass
(Post 5610910)
Oh ok thanks !
how much is the badmab? the site wont seem to load for some reason
