Originally Posted by rlinden86
(Post 1454733)
thats fuckin retarded i would spend the 20 bucks for it to be done right.
ryna. |
im doin this tomorrow
Let us know how it turned out, and out of curiosity, what length you cut it to...
very nice, im doin myne this weekend. ill post a pic then..
Originally Posted by weavagra
(Post 1494823)
Originally Posted by Black07LS
(Post 1495744)
how long is that? It looks shorter than mine and mine's about 8".
(Post 1221766)
Why pay $20 for an antenna when you can cut yours down to size?
1:Remove antenna from car. 2:Wrap antenna with electricle tape just below were you want to cut.(This helps keep the small wire attached) 3:Cut antenna flush with top of tape with a cut off wheel. A hacksaw should also work. 4:Use 1/8" rubber vacuum cap ($1.49 for 5 at AutoZone) as a tip. Twist cap as you push it on antenna. (this will push the tape down) 5:Remove tape. 6:Reinstall. 7:ENJOY your shorty.:beer: :cssNET: |
great write-up, its easy and it works just as well as the normal length (at least in Indy). i still need to buy a cap for the end, right now i just made my own using electrical tape haha it actually doesnt look bad at all
Great How To Cut My Antenna To 12" Works Fine Looks Much Better To
I'm going to do this today
I'll post a pic of the end result. |
eh... i will leave mine UNcut.
nice write up
Did mine the same way as OP, the wire wrap came off so I just sprayed it with black paint. Reception got worse without the wire and shorter antenna but I don't really listen to the radio.
I havent had time to do mine yet. I will try this week when I am givin the opportunity. mos likely this weekend
I am DEFINATELY going to do this that stocker just seems soooooooooooo BIG and gaudy. Thanks for the info
well that was a bitch...haha
Originally Posted by shawn672
(Post 1452711)
what is everyone using to cut this? i dont wanna go attempt to cut it and end up just making a big mark on it ;( i got some wire cutters but idk how strong the metal on the antenna is?
I need to do this, this weekend. I tried buying the $5 shorty antenna from Advance Auto Parts and it didn't fit my car. Good thing it didn't cost me a dime to find out. lol
Just did it. Looks a lot better. Easiest mod I've ever done.
Just a thought: Wouldn't it be a good idea to cut the wire wrap first with a pair of wire cutters just to be sure it doesn't come undone? I'm in the Phoenix Metro area of Az and I'm sure I wouldn't have any reception probs. The first thing I thought when I got my car was "Man that antenna is UG-LY!"
I used a good set of bolt cutters and it worked perfectly, didn't tear the wire or anything.
Here is mine without the antenna:
https://www.cobaltss.net/gallery/fil...328081744a.jpg https://www.cobaltss.net/gallery/fil...0328081744.jpg Not sure if I like it gone. I am gonna shorten the mast when I get to work tomorrow. I'll post pics. |
