[QUOTE=blackjack hotrods;2131826]Just a thought: Wouldn't it be a good idea to cut the wire wrap first with a pair of wire cutters just to be sure it doesn't come undone?QUOTE]
Souond like a good idea to me. Wrapping it with tape helps alot too. |
heres mine.. cut to 7" and used 2 layers of black heatshrink and i still need to get a tip for it
https://www.cobaltss.net/gallery/fil...5/img_0294.jpg |
Here is my shorty antenna finished. Taking pictures at sunset always makes the color of my car look all screwy.
https://www.cobaltss.net/gallery/fil...0403081730.jpg https://www.cobaltss.net/gallery/fil...0403081729.jpg I just used a piece of a vacuum cap for the end. I cut just the rounded tip off and glued it to the antenna with some 3M emblem adhesive gel. Reception is still great, notthat it matters with mp3 cd's and ipods nowadays. |
will this affect the radio in any way? like getting shitty signal in areas you never used to get because you shortened it.
Originally Posted by Chevy Cobalt 08
(Post 2161693)
(Post 2161693)
so you guys are just cutting the antenna and then putting on a little end piece?
bump ^^^^ please answer^^^^ |
Originally Posted by Dunkinuts
(Post 2162381)
bump ^^^^ please answer^^^^ and read the instructions. |
Yes that is correct. You just cut your existing antenna.
Cut it down to the size you'd like (I used a hacksaw), then tape up the very end (about a 1/4" worth) with electric tape, then slip on a vacuum cap (before I slipped it on, I squeezed a tiny bit of super glue into it to secure it - but I don't even think it's necessary). The vacuum caps, as mentioned above, can be purchased at Autozone and I'm sure at Wal-Mart. I forget the size I used (I know it's specified w/in the first 5 pg.s of this thread). Usually like 5 or 6 come in a packet, and the packet was around $1.99. |
cool thanks
Here is what I did.... looks fantastic..
https://www.cobaltss.net/forums/show...y+opel+antenna I just had to drill out the threads and tap it to fit the 7mm stud. BTW... if anyone wants a stock antenna already cut short let me know. I still have my old one. It looks great and you wont have to cut your own stock. |
Mine in stealthy mode. Cut to 14". Note that if you cut it to a length close to the top of your XM antenna, you are sure to get good reception. At 14" it is there.
https://www.cobaltss.net/gallery/fil...altss3_001.jpg https://www.cobaltss.net/gallery/fil...altss3_002.jpg |
i just finished mine.. i cut it to 13" and painted it metallic silver. i think it looks alot better now.
http://i11.photobucket.com/albums/a1...3/S7300394.jpg http://i11.photobucket.com/albums/a1...3/S7300395.jpg |
^ Looks good. See it wasn't hard at all was it? Not bad for free huh... ;)
i have noticed a little difference in radio reception, but that attenna needed to go...that thing was HUGE.
Cost a total of 5 dollars for me, i had to buy the end caps for the attenna and a hack saw...bought a cheap one time use hack saw. haha |
I did it!
Here's Mine!
I live just north of Orlando, Florida and the reception is just fine! https://www.cobaltss.net/forums/vbga...th=175&id=6853 https://www.cobaltss.net/forums/vbga...th=175&id=6854 |
when you drill out the threads in an antenna, there's a way to put new ones in...but what kind of bit do i need? (i mean i heard this, i'm not sure about it, but does anyone know?)
i had gotten about 3 different antenna's before i gave up on this and still have that giant ass antenna lol. |
^ what year? they changed them in 07 I believe
I went to Autozone and bought one for $4 and it threaded right on |
Originally Posted by CENTELRED
(Post 2284989)
Originally Posted by Mr_Slobalt
(Post 2285099)
I guess I'm a lucky one then.
I just did this on mine...easy as pie. Looks so much better.
i just tried to do this antenna mod and found out that my antenna housing itself just spins inside the car whenever i try to remove it, i have the panels pulled back in the truck and it seems like the antenna isnt sitting in the housing right and i've chewed the hell out of the bottom of my antenna, and ideads on how to fix the housing to get this mod done without screwing anything else up?
i cut mine too short and got bad reseption : (
(Post 2011633)
I need to do this, this weekend. I tried buying the $5 shorty antenna from Advance Auto Parts and it didn't fit my car.
(Post 2285099)
did this with mine cut to 11" and it looks great but i get horrible reception, so i went ahead andsepnt the $12 for a euro 13"
so when my XM runs out i can listen to music |
