Originally Posted by mken
I cringed when I saw the guy cutting the vinyl on your hood, computer cut vinyl would of been much better. I hope he used a REALLY sharp blade and a very light touch, otherwise you're going to have that outline cut into your paint.
Other than that, not bad looking. Although I would of eith covered the scoop with the same vinyl (of course he wouldn't of been able to do that installing the vinyl wet), or painted it blue to match the rest of the car. As for covering the scoop, that was my original intent when I thought I was going to buy a black scoop. He's done full wraps of such objects even with the wet apply technology, no problem. But when I found the carbon fiber look, I wanted that. I'm not done. I plan to add some other carbon fiber accents so the scoop doesn't stand alone. That will help integrate it into the design. |
There are a couple of posts about adding a fake scoop. Please feel free to do whatever you think looks the best on your car. The point of customizing is to get what you, the owner wants. I don't have a problem with an offset scoop. I grew up around inline 6 cylinder dragsters that did this, plus the Porsche 944 S and 924 Turbo, Mustang SVO and many others. To me it looks right. I have a real problem with non-functional scoops, and wouldn't consider adding one just for looks. |
I like it. the stripes are a bit wide for me. but overall i think the car looks great. I may have drilled a 3rd hole to make the like < because it looks loike a third would fit.
:twothumbs |
GREAT look and a nice how -to! I like it alot. The offset scoop to me shows its functionality and not like the SS hoods and such that are just for looks. Nice ride!
An HHR driver! We could do some real retro drag stuff to that. Put a long boxy scoop on the right like the old stovebold six drag trucks! :lol: I rent an HHR occasionally on business trips. Can't wait to see the SS version they're rumored to be building! |
nice work man. i like the scoop idea especially since its functional. i would have just placed my more towards the headlight but your car!
KEEP MODDING! |
I like the scoop, I like the placement of it and I like the functionality.
Good job all the way around. :twothumbs |
Good job all the way around. :twothumbs The holes were placed where they had to be functionally, which pretty much located the scoop fore-and-aft (within about 2-3 inches). They do make that scoop in a longer version which would have placed the intake much closer to the front of the hood. It's probably a matter of taste. If I had been able to test-fit both scoop sizes (3, actually - it comes in 3 sizes) at a local parts house prior to the job, who knows which way it would have went? But i didn't find any in the Denver metro, and had to order one based on a tape measure and imagination. |
Nice job, I like it. I think the offset scoop is cool. It makes it look more functional instead of just style, if that makes any sense. instead of covering the top of the box, why not get a couple of 2" rubber body plus and just stick them in the holes if you see a need?
Dennis |
Dennis -J- |
i have to say it's very innovative, and looks like you put a lot of time into it... not something i would do, but i can respect the work that was put into it...
looks friggin sweet. I love offset scoops! I don't think i have the balls to drill 2 holes in my hood though lol. Nice work.
I like it alot....Its your car and you can do what you want to it...FTW..Us 4 doors have to stick together
You mentioned adding more carbon fiber to the front, maybe a bowtie would help even it out a little? I like it overall, looks good! Although something about stick on scoops has always urked me.
-J- |
wow how did i miss this thread?? good job man, not my cup of tea but you did it well. what did the whole project set you back?
The hood scoop was about $100 - I had to buy a pair and only used the one. The local shop charged $125 for the vinyl work, very cost effective and every bit as nice as paint if not better. I've spent about $10 on weather stripping for the hood to get a good seal (I've changed it since the install - new pics to come). I had to buy a cutter for the holes since I didn't have a 2 inch steel cutter. That was about $15. So about $250 total, plus the intake. I have an SS hood blanket on order. I will use the old one to experiment on to find a good way to cut the blanket and seal the resulting edge. The tape I used looks real amateur, not my usual quality. I'll amend the post with pics of that once we figure out the best approach (staples? sewing? heat sealing?). So far it works excellent and is not prone to taking in water in the rain. Next project under the hood will be to remove the cam cover and polish it so it matches the intake pipe. I'll try to do a "how-to" of that, too. |
mad props to have the nuts to take a dremel to your hood.
Dont listen to the "everything is rice" crowd. Rice would have been sticking that scoop on the middle of your hood and calling it done. You moved it to a point where it made sense and did everything you could to help its true functionality, then made it fit in with the car. Im impressed. Great result. and great attention to detail. |
Dont listen to the "everything is rice" crowd. Rice would have been sticking that scoop on the middle of your hood and calling it done. You moved it to a point where it made sense and did everything you could to help its true functionality, then made it fit in with the car. Im impressed. Great result. and great attention to detail. Personally I like the look of an offset scoop when it's functional. One comment was that in fact being offset made it LOOK functional since it isn't there just for looks (i.e., centered), and is over the intake. I agree. |
I would save the money to have a body shop mold the scoop into the hood.
If the RK Sport hood came in CF, I would be tempted to buy one and leave it unpainted. If I were to mold in a scoop, I'd probably use a different design than the one I used, although the shape of it has certainly grown on me since I finished it. But everyone has their own preferences... Thanks for the suggestion, though! |
Maybe someone should photoshop with one on the other side..It probably wouldn't look all that great.
Looks good man. Ive actually been doing some thinking. Looking at creating my custom intake. Dont have some sketches but i dont have a functinal camera:thumbsdow I wanted to post them to see what u think but since i cant ill just describe it best i can. Off the 2.4 if your facing the intake from the front of the car it would come out and bend twords the driver side. Once you have 4ish inches the pipe would actually cut back twords the engine. Making my filter facing the engine. That way the intake is centered cause i want to put a scoop in the center of my hood. Any suggestions or serious disagreements i would love to hear. Ive taken the over sized engine cover off and i know i have the room clearance. Just curious on any ideas that might help. Was actually thinking about running the intake at about a 15 degree upwards tilt to be as close to the scoop holes as possible but im not sure. Thanks
Originally Posted by 06BlackSSNA
(Post 1036696)
Not a bad idea. If i get a short enough filter i believe it wouldnt be to close to the engine. I was run the pipe as close to the front of the car as possible then turn twords the engine. Immediatly stopping and then you have filter. Sitting here though i just though about. Ruinning the pipe along the front of the par parrallel. Taking twords the driver side a bit more then headed twords the engine. Then cut back twords the passenger side. Making the intake not actually facing the engine. If this doesnt make since, im sorry. I've been drinking a bit tonight.
