Interior: So You Want To Remove Your Radio : A How-To Guide For Removing 05-07 Cobalt Radios
Old Aug 23, 2007 | 04:05 PM
pdub's Avatar
Please follow directions carefully. Originator and author not responsible for losses or damages.
Tips:
Patience will get you there.
Use Microfiber Towels to lay things down on, not the seats or pavement as you may attract dirt or scratch things.
Proper tools will ensure an easy process. Rigging things is not recommended.
Okay, here you go.
This is your radio. If you want to remove it, please read.
Open glove box.
Gently pry left edge trim panel from above glove box opening from dash releasing clips. All clips release with pressure.
Work your way across dash releasing clips on trip panel.
Remove trim panel from dash. Check dash for any remaining trim panel clips.
With needle nose pliers, squeeze center two tabs together.
Squeezing center tabs releases clip.
Remove clip from dash. Inspect clip closely, you will have to bend small pointed tabs back into place.
Place clip back onto trim panel ready for re installation.
Driver's side, grasp bottom edge of trim panel next to center console.
Pull bottom edge of panel straight down to release one lower clip.
Pull entire panel forward, away from dash to release one upper clip.
PART 2 In Following Post
Old Aug 23, 2007 | 04:12 PM
pdub's Avatar
Check clips, this releases the entire right side of lower trim panel from dash.
Gently pry upper trim panel from dash releasing two clips.
Pull trim panel slightly from dash. Allow trim panel to hang in place from connectors and wires.
Gently pry top left edge of car stereo trim panel from dash releasing clip.
Gently pry top right edge of car stereo trim panel from dash releasing clip.
Work your way down right edge of panel releasing clips, then down left edge of panel releasing clips.
Pull top edge of trim panel down to allow entire panel to lay onto center console.
Remove two screws right side of car stereo.
Remove two screws left side of car stereo.
Pull car stereo from dash.
Remove antenna and release trigger on connector to disconnect.
The End.
Old Aug 23, 2007 | 05:45 PM
Halfcent's Avatar
I'm old school
Merged, edited, and approved.
Old Aug 23, 2007 | 09:11 PM
pdub's Avatar
Mod, can you please remove P1 and P2 from the titles, and just change P2 to "Continued" or "Cont'd"
Thnk you.
Old Aug 23, 2007 | 10:31 PM
Mr_Slobalt's Avatar
wow, that couldn't be any easier
Old Aug 24, 2007 | 01:09 PM
williamhvx1's Avatar
does is possible to install a 2007 cobalt factory radio on 2006 cobalt ??? i think the 07 radio is more neat and got mp3 jacks
Old Aug 24, 2007 | 02:03 PM
EmperorJJ1's Avatar
not really
Old Aug 24, 2007 | 02:15 PM
JamesJJP's Avatar
From what I've been told because of the difference in wiring you arent able to swap out - I'm not sure why but I was at a buddies place who was parting out his G5 and a friend (KasioBoy on here) has an 06 and wanted the G5's radio for the same reason - He was told by the other (whos a mechanic) that the wiring harnesses are too different and something was mentioned about the cars computer...
Sorry couldnt be more help but I was busy prying off my Exhaust at the time as we were doing a swap.
Old Aug 24, 2007 | 02:17 PM
Aaaw That Suck!!! I See Those 07 Radios On Ebay For 25 Dollars!! Damn!!
Old Aug 24, 2007 | 03:12 PM
EmperorJJ1's Avatar
pm silver ss... (with the astria lights) he tried it
Old Aug 24, 2007 | 03:29 PM
snypez221's Avatar
Is there a sub out on a LT stock head unit? It looks like its the same one as SS.
Old Aug 24, 2007 | 04:03 PM
OrngBalt's Avatar
the 07 can't be swapped out with a simple plug and play... their is a different wiring harness. I would really love to trade my silver radio from my 06 for one of them black radio's tho. I love those... crazy jealous
Old Sep 12, 2007 | 01:09 PM
scampbell's Avatar
Exclamation VIN Recognition
not only is it a different wiring harness, the factory radios that come in these cars recognizes and "remembers" a part of the cars VIN number. If you try to swap out radios from one cobalt to another the radio will not recognize the car and therefore not work. I researched this bcuz i wanted to get my girlfriends 06 LS an 07 deck like mine has in it with the aux jack.
Old Sep 21, 2007 | 01:18 AM
EmperorJJ1's Avatar
vin can be reprogrammed at a dealer easy as pie... they will charge whatever they want
Old Dec 14, 2007 | 03:47 AM
bgbearcatfan's Avatar
Thank's for the how to man, i'm sure a ton of people already used this as a great walk-through. thanks for the detailed pics
Old Dec 15, 2007 | 06:10 PM
jimmy1956's Avatar
thank you so much
im about get a new receiver thanks
Old May 16, 2008 | 05:15 PM
zetterbergfan1's Avatar
how do you disconnect the antenna?? Is it threaded??
Old May 16, 2008 | 10:21 PM
pdub's Avatar
no, just pull it out
Old May 28, 2008 | 08:19 AM
007CobaltLS's Avatar
Just a few pieces of info that I think will help some people.
Those four "screws" that hold the radio in are actually 9/32 on my 07 LS.
Also, I just did this yesterday and had my radio swapped for the upgraded (XM and MP3) radio. I went to the dealership where I bought my car because I know someone who worked there. Unfortunately that didn't help me get it reprogrammed cheaper. I paid 30 minutes labor which is $56 there.
Anyway, what I want to say is when you go to the dealer and have them work on it, make sure to tell them that you know it shouldn't take any longer than 30 minutes (it really shouldn't take 15 or 20 minutes), but I was given the line, "It takes 20-25 minutes for the Tech2 to download the info to the computer." So I just let it go at that.
Old Jun 4, 2008 | 07:49 PM
pdub's Avatar
Great info. It really depends on the tech working on it. In all honesty, the second time I had this done, the service manager had it done in 5 minutes. He literally came outside with the Tech2, plugged it in, ran the vin re-learn, and said there you go... no charge.
This is really easy money though for service departments, so I think that a no charge situation would come up less than often.
Old Jun 4, 2008 | 08:04 PM
06LSbalt's Avatar
ive done this before its like effin legos!
Old Jun 4, 2008 | 09:33 PM
The sad thing is my sister-in-law worked there for years and I bought my car there. I've given them business in the past as well (referrals for business). Yet they still want to screw me with that stuff. We've got about 5 different dealerships in the area that are GM (less than 8 miles in any direction from my house) so I'll try different dealers in the future. I know the Saturn dealer has always treated me great (when I had my last two cars which were Saturn S-Series), so I will probably go there instead.
Old Jul 22, 2008 | 02:19 PM
OrngBalt's Avatar
Can we please add removing dash trim in this heading. This is probably the best written how-to on the topic, but no one finds it because they dont think to search for removing radio.
Old Jul 23, 2008 | 02:41 PM
SunnyDay's Avatar
Also door panel (for coupe) to replace the speaker. Another thread has it but no pictures
Old Jul 26, 2008 | 01:09 PM
dvsxlt247's Avatar
Do i need to bring the 2007 HU to the dealer before install it into my 2006 LS?? or can i install it into the car and then they hook up there thing to the cars port, and not necessairily the radio directly??? from what im understanding, you guys are saying that all i need to do i bring the 2007 HU to a GM dealer or Chevy dealer and tell them that im putting it into my 2006 LS and that i need this 2007 HU programmed with my 2006 LS's Vin number???? so that the car will recognize the radio or vice versa?? and after they program it in, thats it, install it and should work normal??
