How to requests and questions Please post your requests and questions for How to Guides.
Air Bag Senser replacement on Cobalt SS 2008
Old Mar 3, 2021 | 02:25 PM
Billsoross's Avatar
Hi,
I sometimes get an error message: AIR BAG SERVICE on my Cobalt SS, 2008 (coup 2 doors, no turbocharger). If I try to restart my car several times, the error message disappears. My service repair shop recommends to replace its air bag senser but they charge me over $300. Is there any simple way to replace the senser by myself.
I appreciate any shared suggestion/guidelines/photos/videos of how to do it myself.
Thanks,
Billy
Old Mar 3, 2021 | 03:33 PM
Tdubbs's Avatar
Did they tell you what it is that actually tripped the codes?
Old Mar 3, 2021 | 09:58 PM
Billsoross's Avatar
The mechanic man did not find any code when he diagnosed the air bag system. However, they recommended to replace the air bag sense on the driver side.
is there any suggestions to replace the sense for my cobalt ss 2008, coupe, two doors, and no supercharger?
Old Mar 5, 2021 | 01:32 AM
blu3_v1p3r's Avatar
If you are getting a message or light there is a code. If there is no code, they are just guessing, wasting your time and money.
Old Mar 5, 2021 | 02:15 AM
Billsoross's Avatar
Is there any simple way to get the code on error: AIR BAG SERVICE without a code reader?
Old Mar 5, 2021 | 04:39 AM
LsCobalt07's Avatar
You will need a scan tool that can communicate with the BCM such as a GM tech 2 or equivalent. Most lower cost scan tools can only read codes from the ECM. You can try to reach out to the mechanic that diagnosed the issue and see if they found any pending, historic or current DTC codes to support their intentions. I wouldn't recommend throwing parts at it until you get a code to help diagnose the root cause.
Old Mar 5, 2021 | 09:44 AM
That error that pops up can be a number of different parts associated with the air bag system that aren't just the air bag. It should have a BCM code, you might have to take it to a GM dealer and pay a diagnostic fee to find out what sensor is actual causing the error code.
Old Mar 8, 2021 | 02:16 AM
blu3_v1p3r's Avatar
A scan tool that can read SRS. Mine can read individual modules. You can try O’Reily they will loan out there scanner our local one uses a bosche scanner that can read SRS.
Kip McClung
May 1, 2018 08:07 PM
BOOST N past you
Feb 19, 2010 09:34 PM
TrevMo
Aug 8, 2008 04:14 PM
CAI Inc.
Mar 15, 2005 02:07 AM
